TI论坛
直播中
李泽明
8年用户 1282经验值
私信 关注
[问答]
在c5515中实现一个简易的MP3,预想是先将MP3转换为PCM格式,然后在aic3204中播放,怎么操作?
  • 我打算在c5515中实现一个简易的MP3,预想是先将MP3转换为PCM格式,然后在aic3204中播放,可不知该怎么配置。
    void aic3204_init_mono(void)
      SYS_EXBUSSEL = 0x6100;         // Enable I2C bus
      USBSTK5515_I2C_init( );        // Initialize I2C
       /* Configure AIC3204 */
       AIC3204_rset( 0, 0x00 );          // Select page 0
       AIC3204_rset( 1, 0x01 );          // Reset codec
       AIC3204_rset( 0, 0x01 );          // Select page 1
       AIC3204_rset( 1, 0x08 );          // Disable crude AVDD generation from DVDD
       AIC3204_rset( 2, 0x01 );          // Enable Analog Blocks, use LDO power
       AIC3204_rset( 10, 0x00 );        //#Set the input common mode to 0.9V
       AIC3204_rset( 61, 0x00 );        //#Set ADC PTM_R4
       AIC3204_rset( 71, 0x00 );        //#Set MicPGA startup delay to 3.1ms
       AIC3204_rset( 123, 0x01 );       //#Set the REF charging time to 40ms
       /* PLL and Clocks config and Power Up  */
       AIC3204_rset( 0, 0 );          // Select page 0
       AIC3204_rset( 27, 0x4d );       // BCLK and WCLK is set as o/p to AIC3204(Master)  interface DSP
       AIC3204_rset( 28, 0x02 );       //#Data offset value ( ajout de 1 BCLK's)
       AIC3204_rset( 29, 0x08 );       //# Audio interface set
       AIC3204_rset( 61, 0x01 );       //ADC Signal Processing Block Control Register
       AIC3204_rset( 60, 0x8 );        //DAC Signal Processing Block Control Register
       AIC3204_rset( 4, 3 );          // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK
       AIC3204_rset( 6, 8 );          // PLL setting: J=8
       AIC3204_rset( 7, 0x07 );       // PLL setting: HI_BYTE(D=1680)
       AIC3204_rset( 8, 0x80 );       // PLL setting: LO_BYTE(D=1680)
       AIC3204_rset( 30, 0xc0 );      // For 32 bit clocks per frame in Master mode ONLY
                                      // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs
       AIC3204_rset( 5, 0x91 );       // PLL setting: Power up PLL, P=1 and R=1
       AIC3204_rset( 13, 03 );        // Hi_Byte(DOSR) for DOSR = 768 decimal or 0x0300 DAC oversamppling
       AIC3204_rset( 14, 0x00 );      // Lo_Byte(DOSR) for DOSR = 768 decimal or 0x0300
       AIC3204_rset( 20, 0x80 );      // AOSR for AOSR = 128 decimal or 0x80 for decimation filters 1 to 6
       AIC3204_rset( 11, 0x88 );      // Power up NDAC and set NDAC value to 2
       AIC3204_rset( 12, 0x82 );      // Power up MDAC and set MDAC value to 8
       AIC3204_rset( 18, 0x88 );      // Power up NADC and set NADC value to 8
       AIC3204_rset( 19, 0x8c );      // Power up MADC and set MADC value to 12
       AIC3204_rset( 81, 0x00 );  // Power down Left and Right ADC
       AIC3204_rset( 63, 0x14 );  // Power down left,right data paths and set channel
       AIC3204_rset( 61, 2 );       // PRB_R2
       // set biquad A to low pass fc = 3628
       AIC3204_rset( 0, 8 ); // Select page 8
       AIC3204_rset( 36, 0x6A ); // Left N0 H
       AIC3204_rset( 37, 0xC3 ); // Left N0 M
       AIC3204_rset( 38, 0x6F ); // Left N0 L
       AIC3204_rset( 40, 0x35 ); // Left N1 H
       AIC3204_rset( 41, 0x61 ); // Left N1 M
       AIC3204_rset( 42, 0xB7 ); // Left N1 L
       AIC3204_rset( 44, 0x00 ); // Left N2 H
       AIC3204_rset( 45, 0x00 ); // Left N2 M
       AIC3204_rset( 46, 0x00 ); // Left N2 L
       AIC3204_rset( 48, 0xD5 ); // Left D1 H
       AIC3204_rset( 49, 0x3C ); // Left D1 M
       AIC3204_rset( 50, 0x91 ); // Left D1 L
       AIC3204_rset( 52, 0x00 ); // Left D2 H
       AIC3204_rset( 53, 0x00 ); // Left D2 M
       AIC3204_rset( 54, 0x00 ); // Left D2 L
       AIC3204_rset( 0, 9 ); // Select page 9
       AIC3204_rset( 44, 0x6F ); // Right N0 H
       AIC3204_rset( 45, 0x96 ); // Right N0 M
       AIC3204_rset( 46, 0x52 ); // Right N0 L
       AIC3204_rset( 48, 0x37 ); // Right N1 H
       AIC3204_rset( 49, 0xCB ); // Right N1 M
       AIC3204_rset( 50, 0x29 ); // Right N1 L
       AIC3204_rset( 52, 0x00 ); // Right N2 H
       AIC3204_rset( 53, 0x00 ); // Right N2 M
       AIC3204_rset( 54, 0x00 ); // Right N2 L
       AIC3204_rset( 56, 0xD0 ); // Right D1 H
       AIC3204_rset( 57, 0x69 ); // Right D1 M
       AIC3204_rset( 58, 0xAD ); // Right D1 L
       AIC3204_rset( 60, 0x00 ); // Right D2 H
       AIC3204_rset( 61, 0x00 ); // Right D2 M
       AIC3204_rset( 62, 0x00 ); // Right D2 L
       /* DAC ROUTING and Power Up */
       AIC3204_rset( 9, 0x30 );       //# OUTPUT DRIVER POWER CONTROL hp->ON lineout->OFF mixer->OFF
       AIC3204_rset( 10, 0x03 );      //#COMMON MODE CONTROL REGISTER Output of HP is powered by LDOIN
       AIC3204_rset( 11, 0x10 );      //Over Current detection is enabled for HPL & HPR
       AIC3204_rset( 12, 0x08 );      //# Left DAC (+) -> HPL
       AIC3204_rset( 13, 0x00 );      //# Left DAC (-) -> HPR
       AIC3204_rset( 14, 0x00 );      //# LOL is not routed
       AIC3204_rset( 15, 0x00 );      //# LOR is not routed
       AIC3204_rset( 16, 0x3c );      // HPL Driver gain setting register Unmute HPL , 0dB gain
       AIC3204_rset( 17, 0x3c );      // volume de sortie headphone 0x00 -> 0dB 0x3A -> -6dB 0x1d -> +29dB
       AIC3204_rset( 18, 0x40 );     //# LOL driver gain settings register
       AIC3204_rset( 19, 0x40 );     //# LOL & LOR MUTED
       AIC3204_rset( 20, 0x25 );     //#HEADPHONE DRIVER STARTUP Headphone amps power up slowly in 5.0 time constants / Headphone amps power up time is determined with 6K resistance
       AIC3204_rset( 22, 0x00 );     //# IN1L to HPL volume control bypass 0dB
       AIC3204_rset( 23, 0x00 );     //# IN1L to HPL volume control bypass 0dB
       AIC3204_rset( 24, 0x00 );     //# MIXERAMP Left volume control
       AIC3204_rset( 25, 0x00 );
       AIC3204_rset( 51, 0x50 );      //# setting du micbias micbias = Vcc
       AIC3204_rset( 64, 0x00 );      //#DAC L UNMUTED, R&L independant DAC R MUTED (mode differentiel)
                                      //# 0x00 -> 0dB 0xFF -> -0.5dB 0x81 -> -63dB
       AIC3204_rset( 65, 0x00 );      //# Left DAC channel digital volume control register
       AIC3204_rset( 66, 0x00 );      //# Right DAC Channel Digital Volume Control Register
       AIC3204_rset( 63, 0x90 );      //#DAC L switched ON, R OFF, soft-stepping enabled
       /* ADC ROUTING and Power Up */
       AIC3204_rset( 0, 1 );          // Select page 1
       AIC3204_rset( 52, 0x30 );      //# IN2L -> Left MICPGA +   40K resistance
       AIC3204_rset( 54, 0x30 );      //# IN2R -> Left MICPGA -  40K resistance
       AIC3204_rset( 55, 0x00 );      //# Right MICPGA positive terminal input routing
       AIC3204_rset( 57, 0x00 );      //# Right MICPGA negative terminal input routing
       AIC3204_rset( 58, 0xbb );      //#Floating Input Configuration register
       AIC3204_rset( 59, 0 );         // MIC_PGA_L unmute
       AIC3204_rset( 60, 0 );         // MIC_PGA_R unmute
       AIC3204_rset( 81, 0x80 );     //#ADC right OFF & left ON
       AIC3204_rset( 82, 0x08 );     //#ADC left UNMUTED right MUTED
       AIC3204_rset( 83, 0x67 );     //#ADC left & right channel volume control
       AIC3204_rset( 84, 0x67 );     //#ADC volume 20dB -- 0x28    -12dB -- 0x67
       AIC3204_rset( 85, 0x81 );     //#ADC phase adjust register
       USBSTK5515_wait( 200 );        // Wait
       // I2S settings
       I2S0_SRGR = 0x0;
       I2S0_CR = 0x8010;
       I2S0_ICMR = 0x2b;
    *  AIC3204 Tone                                                            *
    *      Output a 1 kHz tone through the HEADPHONE jack                      *
    Int16 aic3204_tone_headphone(Int16* sinetable )
        aic3204_init_mono();
        Int16 i, sample;
        /* Play Tone */
        for ( i = 0 ; i < 50000; i++ )
            while((XmitR & I2S0_IR) == 0);        // Wait for transmit interrupt to be pending
            //sample = sinetable;
            sample = ((sinetable &0xff) << 8) | ((sinetable &0xff00) >> 8);
            I2S0_W0_MSW_W = sample ; // 16 bit left channel transmit audio data
            I2S0_W1_MSW_W = sample; // 16 bit right channel transmit audio data
        /* Disble I2S */
        I2S0_CR = 0x00;
        return 0;
    这是我的配置代码和调用代码,其中sinetable数组中储存了从pcm文件中读取的数据,希望给予帮助,谢谢
回帖(1)
万物死
2025-1-13 17:16:25
要在C5515上实现一个简易的MP3播放器,并将MP3转换为PCM格式在AIC3204中播放,你需要遵循以下步骤:
1. **MP3解码**:首先,你需要一个MP3解码器,它可以将MP3文件解码为PCM格式。这通常需要一个专门的库或算法,如MP3IS或Fraunhofer MP3解码器。你需要将这个解码器集成到你的C5515项目中。
2. **配置AIC3204**:AIC3204是一个音频编解码器,你需要配置它以播放PCM数据。你已经提供了一些初始化代码,但可能需要根据你的具体需求进行调整。
3. **数据传输**:解码后的PCM数据需要从C5515传输到AIC3204。这通常通过I2S或SPI接口完成。
4. **播放控制**:你需要实现一些控制逻辑来管理播放过程,如播放、暂停、停止等。
以下是一些具体的步骤和代码示例:
### 1. MP3解码
你需要找到一个适合C5515的MP3解码库,并将其集成到你的项目中。这通常涉及到一些复杂的算法,可能需要外部库的支持。
### 2. 配置AIC3204
你的初始化代码看起来是正确的,但可能需要根据AIC3204的数据手册进行调整。以下是一些基本的配置步骤:
```c
void aic3204_init_mono(void) {
    USBSTK5515_I2C_init(); // Initialize I2C
    // Configure AIC3204
    AIC3204_rset(0, 0x00); // Select page 0
    AIC3204_rset(1, 0x01); // Power on device, no reset
    // Additional configurations based on AIC3204 datasheet
    AIC3204_rset(2, 0x00); // Set sample rate and format
    AIC3204_rset(3, 0x00); // Set volume and mute
    // ... more configurations
### 3. 数据传输
你需要配置C5515的I2S或SPI接口,以便将PCM数据传输到AIC3204。这涉及到设置正确的时钟速率和数据格式。
### 4. 播放控制
你需要实现一些函数来控制播放过程,例如:
```c
void play_pcm_data() {
    // Start playing PCM data
    // This might involve setting a flag in AIC3204 to start playback
void stop_playback() {
    // Stop playing PCM data
    // This might involve resetting the playback flag in AIC3204
### 总结
这是一个复杂的项目,涉及到音频解码、硬件接口配置和控制逻辑的实现。你需要仔细阅读C5515和AIC3204的数据手册,以及你选择的MP3解码库的文档,以确保正确配置和操作。
举报
更多回帖
