TI论坛
直播中
123
11年用户 889经验值
擅长:可编程逻辑
私信 关注
[问答]
C6748通过MCBSP配置成SPI方式与ADS8326通讯实现AD转换,MCBSP的DRR寄存器值始终是0,为什么?
  • C6748通过MCBSP配置成SPI方式与ADS8326通讯实现AD转换,时钟、数据波形用示波器显示正常,但是MCBSP的DRR寄存器值始终是0,求指点.....
    void McBSP0Init(void)
    #ifdef MCBSP_ADC
    // 禁用 FRST GRST XRST RRST
    McBSP0Regs.SPCR.bit.FRST=0;
    McBSP0Regs.SPCR.bit.GRST=0;
    McBSP0Regs.SPCR.bit.XRST=0;
    McBSP0Regs.SPCR.bit.RRST=0;
    // McBSP0 串行口控制寄存器
    McBSP0Regs.SPCR.bit.DLB=0;
    McBSP0Regs.SPCR.bit.RJUST=0;
    McBSP0Regs.SPCR.bit.CLKSTP = 3; //CLKSTP = 11b; The clock stop mode.
    McBSP0Regs.SPCR.bit.DXENA = 0;
    McBSP0Regs.SPCR.bit.FREE=1;
    McBSP0Regs.SPCR.bit.SOFT=0;
    McBSP0Regs.RCR.bit.RDATDLY = 1; //接收数据延迟配置为1位数据延迟
    McBSP0Regs.RCR.bit.RPHASE = 0; //每帧设置为1相
    McBSP0Regs.RCR.bit.RFRLEN1 = 0; //每帧1个字
    McBSP0Regs.RCR.bit.RWDLEN1 = 4; //每字24位
    McBSP0Regs.RCR.bit.RWDREVRS=0; // 无数据位倒置
    McBSP0Regs.XCR.bit.XDATDLY = 1; //发送数据延迟配置为0位数据延迟
    McBSP0Regs.XCR.bit.XPHASE = 0;
    McBSP0Regs.XCR.bit.XFRLEN1 = 0;
    McBSP0Regs.XCR.bit.XWDLEN1 = 4; //24位
    McBSP0Regs.SRGR.bit.FSGM = 1; //在每个字传输期间FSX信号有效
    McBSP0Regs.SRGR.bit.GSYNC = 0;
    McBSP0Regs.SRGR.bit.CLKSM = 1; //采样率发生器的始终来源于CPU时钟
    McBSP0Regs.SRGR.bit.CLKSP = 0; //CLKS上升沿产生CLKG和FSG
    McBSP0Regs.SRGR.bit.CLKGDV = 29; //采样率发生器的始终分频系数设定为29, CLKG=CPU CLOCK/(1+CLKGDV)
    McBSP0Regs.SRGR.bit.FPER = 49; //设置帧周期为(49+1)*CLKG
    McBSP0Regs.SRGR.bit.FWID = 23; //23 设置帧宽度为(1+FWID)*CLKG
    /* 时钟开始于下降沿(有延迟),缓冲串口在CLKX下降沿前半个时钟周期发送数据,在CLKR下降沿接收数据 */
    McBSP0Regs.PCR.bit.CLKXM = 1; //设置CLKX0引脚为输出引脚
    McBSP0Regs.PCR.bit.CLKRM = 0;
    McBSP0Regs.PCR.bit.FSXM = 1; //配置FSX0引脚为输出
    McBSP0Regs.PCR.bit.FSRM = 0;
    McBSP0Regs.PCR.bit.SCLKME= 0;
    McBSP0Regs.PCR.bit.FSXP = 1;
    McBSP0Regs.PCR.bit.FSRP = 0;
    McBSP0Regs.PCR.bit.CLKRP = 0;
    McBSP0Regs.PCR.bit.CLKXP = 0; //配置FSX引脚高电平有效
    // 延时等待内部同步
    unsigned char i;
    for(i=0;i<200;i++)
    asm (" nop");
    // 使能 接收
    McBSP0Regs.SPCR.bit.RRST = 1;
    // 使能 接收帧同步信号
    McBSP0Regs.SPCR.bit.FRST = 1;
    // 使能 内部采样率生成器
    McBSP0Regs.SPCR.bit.GRST = 1;
    // 使能 发送
    McBSP0Regs.SPCR.bit.XRST = 1;
    for(i=0;i<100;i++)
    asm (" nop ");
    #endif
回帖(2)
殷谷光
2024-12-14 11:22:30
看来是发了数据, 却没有收到.
MCBSP 与 spi 接口不同, 有发送时钟引脚CLKX,接收时钟引脚CLKR,你的两个时钟脚是否连接起来?
举报
万物死
2024-12-14 15:53:05
在您提供的代码中,MCBSP0的DRR寄存器值始终为0,可能的原因有以下几点:
1. 确保MCBSP0的时钟已经正确配置。在代码中,您需要确保MCBSP0的时钟已经正确配置,以便MCBSP0能够正常工作。您可以通过配置系统时钟(如PLL)来实现这一点。
2. 确保MCBSP0的GPIO引脚已经正确配置。在代码中,您需要确保MCBSP0的GPIO引脚已经正确配置为MCBSP0功能。这可以通过配置GPIO引脚的模式寄存器来实现。
3. 确保MCBSP0的DRR寄存器已经正确配置。在代码中,您需要确保MCBSP0的DRR寄存器已经正确配置,以便能够接收数据。您可以通过设置DRR寄存器的相应位来实现这一点。
4. 检查MCBSP0的接收中断。在代码中,您需要确保MCBSP0的接收中断已经正确配置,以便在接收到数据时能够触发中断。您可以通过设置MCBSP0的接收中断使能寄存器来实现这一点。
5. 检查ADS8326的配置。确保ADS8326已经正确配置,以便能够与MCBSP0进行通信。这包括配置ADS8326的时钟、数据格式等参数。
6. 检查通信协议。确保您使用的通信协议(SPI)与ADS8326兼容,并且您已经正确实现了SPI协议。
7. 检查硬件连接。确保MCBSP0与ADS8326之间的硬件连接正确,包括时钟线、数据线、片选线等。
8. 使用调试工具。您可以使用调试工具(如仿真器)来检查MCBSP0的寄存器值,以便找出问题所在。
综上所述,您需要检查代码中的配置、硬件连接以及通信协议,以确保MCBSP0能够正确接收数据。希望这些建议能够帮助您解决问题。
举报
更多回帖
