使用PWM输出必不可少的就是查看时钟源从而设置定时器计数值
首先,可以通过数据手册查到GPT的时钟源是由PCLKD进行分频得来的,所以配置时需要注意下PCLKD的配置
图中配置的PCLKD为64MHz(待会要用)
时钟配置完成之后,就需要配置引脚,我选用的GTP0_GPTOC0A,即P213
主要配置的就是:
通道、周期、占空比以及模式
不要忘记了将输出使能打开
这样输出方波的PWM就算配置完成了,由于没有示波器,所以选择结合ADC来一起演示
ADC的时钟和PWM一样,都是使用的PCLKD,手册上还说其高达13个输入通道(说实话,我感觉不多),结果12bit(算中规中矩吧)
和其他都一样,正常勾选上相应功能即可
主要配置的有:
对齐方式、扫描模式,还有通道勾选上,其他感觉没啥需要配置的,最后将中断打开即可。
void adc0_intrruput_callback( adc_callback_args_t* p_args )
switch ( p_args->event )
case ADC_EVENT_SCAN_COMPLETE:
adc_event_scan_complete = true;
break;
default:
break;
* main() is generated by the RA Configuration editor and is used to generate
* threads if an RTOS is used. This function is called by main() when no RTOS
*is used.
void hal_entry( void )
uint16_t voltage = 0;
uint16_t freq = 1000;
uint8_t show_str[ 20 ] = "0.000";
uint32_t second = 0;
uint32_t cnt = 0;
timer_info_t timer_info;
/* TODO: add your own code here */
oled_init();
uart9_init();
oled_showStr( 0, 0, 6, "This is a adc test" );
oled_showStr( 0, 2, 6, "adc voltage:" );
oled_showStr( 0, 4, 6, "pwm frequency:" );
oled_showStr( 0, 6, 6, "Running time:" );
R_ADC_Open( &g_adc0_ctrl, &g_adc0_cfg );
R_ADC_ScanCfg( &g_adc0_ctrl, &g_adc0_channel_cfg );
R_ADC_ScanStart( &g_adc0_ctrl );
R_GPT_Open( &g_timer0_ctrl, &g_timer0_cfg );
R_GPT_Start( &g_timer0_ctrl );
R_GPT_PeriodSet( &g_timer0_ctrl, 128000000 );
R_BSP_SoftwareDelay( 100, BSP_DELAY_UNITS_MILLISECONDS );
while ( 1 )
if ( adc_event_scan_complete )
adc_event_scan_complete = false;
R_ADC_Read( &g_adc0_ctrl, ADC_CHANNEL_0, &voltage );
sprintf( show_str, "0x%03x", voltage );
oled_showStr( 12 * 6, 2, 6, show_str );
R_GPT_InfoGet( &g_timer0_ctrl, &timer_info );
sprintf( show_str, "%d", 64000000000 / timer_info.period_counts );
oled_showStr( 14 * 6, 4, 6, show_str );
sprintf( show_str, "%d.%dS", second, cnt % 10 );
oled_showStr( 13 * 6, 6, 6, show_str );
cnt++;
if ( cnt % 10 == 0 )
second += 1;
cnt = 0;
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
着重需要注意的就是
传入的参数需要结合时钟,前面提到的PCLKD = 64MHz
那么,我想要0.5Hz的输出频率就需要传入128M
同理,输出频率 = 64M / cnt,想要多少就通过公式计算传入即可
我这段代码的效果就是屏幕显示
ADC的采样值
PWM的输出频率*1000(因为我调用sprintf转换float类型一直不成功,最后就放弃了)
运行时间
效果就是,每隔一秒ADC采样值变换依次(不知道为什么PWM输出一直有一点小跳变)
更多回帖
