# 鸿蒙 Flutter 开发中集成 Webview
## 主要有两种方案
### 使用第三方库
如 使用`flutter_inappwebview`插件,在 pubspec.lock 文件中配置:
```yaml
flutter_inappwebview:
git:
url: https://gitee.com/openharmony-sig/flutter_inappwebview.git
path: "flutter_inappwebview"
创建 entryablitiy
在 src/main/module.json5中配置ablitiy
"abilities": [
"name": "EntryAbility",
"srcEntry": "./ets/entryability/EntryAbility.ets",
"description": "$string:EntryAbility_desc",
"icon": "$media:icon",
"label": "$string:EntryAbility_label",
"startWindowIcon": "$media:icon",
"startWindowBackground": "$color:start_window_background",
"exported": true,
"skills": [
"entities": [
"entity.system.home"
"actions": [
"action.system.home"
"orientation": "landscape"
cat src/main/entryablity/CustomFactory.ets
import { BinaryMessenger } from '@ohos/flutter_ohos/src/main/ets/plugin/common/BinaryMessenger';
import MessageCodec from '@ohos/flutter_ohos/src/main/ets/plugin/common/MessageCodec';
import PlatformViewFactory from '@ohos/flutter_ohos/src/main/ets/plugin/platform/PlatformViewFactory';
import { CustomView } from './CustomView';
import common from '@ohos.app.ability.common';
import PlatformView from '@ohos/flutter_ohos/src/main/ets/plugin/platform/PlatformView';
export class CustomFactory extends PlatformViewFactory {
message: BinaryMessenger;
constructor(message: BinaryMessenger, createArgsCodes: MessageCodec<Object>) {
super(createArgsCodes);
this.message = message;
public create(context: common.Context, viewId: number, args: Object): PlatformView {
return new CustomView(context, viewId, args, this.message);
<span class="vditor-linenumber__rows"><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span></span>
cat src/main/entryablity/CustomPlugin.ets
import { FlutterPlugin,
FlutterPluginBinding } from '@ohos/flutter_ohos/src/main/ets/embedding/engine/plugins/FlutterPlugin';
import StandardMessageCodec from '@ohos/flutter_ohos/src/main/ets/plugin/common/StandardMessageCodec';
import { CustomFactory } from './CustomFactory';
export class CustomPlugin implements FlutterPlugin {
getUniqueClassName(): string {
return 'CustomPlugin';
onAttachedToEngine(binding: FlutterPluginBinding): void {
binding.getPlatformViewRegistry()?.
registerViewFactory('com.rex.custom.ohos/customView', new CustomFactory(binding.getBinaryMessenger(), StandardMessageCodec.INSTANCE));
onDetachedFromEngine(binding: FlutterPluginBinding): void {}
<span class="vditor-linenumber__rows"><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:125px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span></span>
cat src/main/entryablity/CustomView.ets
import MethodChannel, {
MethodCallHandler,
MethodResult
} from '@ohos/flutter_ohos/src/main/ets/plugin/common/MethodChannel';
import PlatformView, { Params } from '@ohos/flutter_ohos/src/main/ets/plugin/platform/PlatformView';
import StandardMethodCodec from '@ohos/flutter_ohos/src/main/ets/plugin/common/StandardMethodCodec';
import MethodCall from '@ohos/flutter_ohos/src/main/ets/plugin/common/MethodCall';
import { webview } from '@kit.ArkWeb';
@Component
struct ButtonComponent {
@Prop params: Params
customView: CustomView = this.params.platformView as CustomView
@StorageLink('numValue') storageLink: string = "first"
@State bkColor: Color = Color.Red
private webviewController: WebviewController = new webview.WebviewController()
build() {
Web({src: 'https://baidu.com', controller: this.webviewController})
.domStorageAccess(true)
.fileAccess(true)
.mixedMode(MixedMode.All)
.databaseAccess(true)
.userAgent("Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.71 Safari/537.36")
@Builder
function ButtonBuilder(params: Params) {
ButtonComponent({ params: params })
.backgroundColor(Color.Transparent)
AppStorage.setOrCreate('numValue', 'test')
@Observed
export class CustomView extends PlatformView implements MethodCallHandler {
numValue: string = "test";
methodChannel: MethodChannel;
index: number = 1;
constructor(context: common.Context, viewId: number, args: ESObject, message: BinaryMessenger) {
super();
// 注册消息通道
this.methodChannel = new MethodChannel(message, `com.rex.custom.ohos/customView${viewId}`, StandardMethodCodec.INSTANCE);
this.methodChannel.setMethodCallHandler(this);
onMethodCall(call: MethodCall, result: MethodResult): void {
// 接受Dart侧发来的消息
let method: string = call.method;
let link1: SubscribedAbstractProperty<number> = AppStorage.link('numValue');
switch (method) {
case 'getMessageFromFlutterView':
let value: ESObject = call.args;
this.numValue = value;
link1.set(value)
console.log("nodeController receive message from dart: " + this.numValue);
result.success(true);
break;
public sendMessage = () => {
console.log("nodeController sendMessage")
//向Dart侧发送消息
this.methodChannel.invokeMethod('getMessageFromOhosView', 'natvie - ' + this.index++);
getView(): WrappedBuilder<[Params]> {
return new WrappedBuilder(ButtonBuilder);
dispose(): void {
<span class="vditor-linenumber__rows"><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:100px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span></span>
cat src/main/entryablity/EntryAbility.ets
import { FlutterAbility, FlutterEngine } from '@ohos/flutter_ohos';
import { GeneratedPluginRegistrant } from '../plugins/GeneratedPluginRegistrant';
import { CustomPlugin } from './CustomPlugin';
export default class EntryAbility extends FlutterAbility {
configureFlutterEngine(flutterEngine: FlutterEngine) {
super.configureFlutterEngine(flutterEngine)
GeneratedPluginRegistrant.registerWith(flutterEngine)
this.addPlugin(new CustomPlugin())
<span class="vditor-linenumber__rows"><span style="height:50px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:75px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span></span>
创建 pages
cat src/main/ets/pages/index.ets
import { FlutterPage } from '@ohos/flutter_ohos'
let storage = LocalStorage.getShared()
const EVENT_BACK_PRESS = 'EVENT_BACK_PRESS'
@Entry(storage)
@Component
struct Index {
private context = getContext(this) as common.UIAbilityContext
@LocalStorageLink('viewId') viewId: string = "";
build() {
Column() {
FlutterPage({ viewId: this.viewId })
onBackPress(): boolean {
this.context.eventHub.emit(EVENT_BACK_PRESS)
return true
<span class="vditor-linenumber__rows"><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:50px;"></span><span style="height:50px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span><span style="height:25px;"></span></span>
在src/main/resources/base/profile/main_page.json中配置路由
"src": [
"pages/Index"
在 Dart 侧调用该 PlatformView
Scaffold(
appBar: AppBar(title: Text('code')),
body: OhosView(
viewType: 'com.rex.custom.ohos/customView',
// onPlatformViewCreated: _onPlatformViewCreated,
creationParams: const <String, dynamic>{'initParams': 'hello world'},
creationParamsCodec: const StandardMessageCodec(),
更多回帖
