TI论坛
直播中
恩可口
9年用户 843经验值
私信 关注
[问答]
TMS320VC5509A如何实现音频的采集并实时输出,像对着麦讲话,可以在耳机里听到?
  • 我运用的板子是5509A,想要对官方的例程进行修改,实现音频的采集并实时输出,像对着麦讲话,可以在耳机里听到。这一功能要修改这个程序的那些部分?谢谢各位大神!
    /*  Copyright 2004 by SEED Electronic Technology LTD.                         */
    /*  All rights reserved. SEED Electronic Technology LTD.                      */
    /*  Restricted rights to use, duplicate or disclose this code are             */
    /*  granted through contract.                                                 */
    /* DESCRIPtiON:    */
    /* This is an example for EMIF of C5509   */
    /* MODULE NAME... I2C and Mcbsp   */
    /* FILENAME...... codec.c      */
    /* DATE CREATED.. Mon 02/4/2004       */
    /* COMPONENT.....   */
    /* PREREQUISITS..   */
    /* DESCRIPTION:   */
    /* this example is that the codec is controled by the I2C and Mcbsp   */
    #include
    #include
    #include
    #include
    #include
    #define CODEC_ADDR 0x1A
    /*锁相环的设置*/
    PLL_Config  myConfig      = {
      0,    //IAI: the PLL locks using the same process that was underway
                    //before the idle mode was entered
      1,    //IOB: If the PLL indicates a break in the phase lock,
                    //it switches to its bypass mode and restarts the PLL phase-locking
                    //sequence
      12,    //PLL multiply value; multiply 24 times
      1             //Divide by 2 PLL divide value; it can be either PLL divide value
                    //(when PLL is enabled), or Bypass-mode divide value
                    //(PLL in bypass mode, if PLL multiply value is set to 1)
    MCBSP_Config Mcbsptest;
    /*McBSP set,we use mcbsp1 to send and recieve the data between DSP and AIC23*/
    MCBSP_Config Mcbsp1Config = {
      MCBSP_SPCR1_RMK(
        MCBSP_SPCR1_DLB_OFF,                   /* DLB    = 0,禁止自闭环方式 */
        MCBSP_SPCR1_RJUST_LZF,                 /* RJUST  = 2 */
        MCBSP_SPCR1_CLKSTP_DISABLE,            /* CLKSTP = 0 */
        MCBSP_SPCR1_DXENA_ON,                  /* DXENA  = 1 */
        0,                                     /* ABIS   = 0 */
        MCBSP_SPCR1_RINTM_RRDY,                /* RINTM  = 0 */
        0,                                     /* RSYNCER = 0 */
        MCBSP_SPCR1_RRST_DISABLE               /* RRST   = 0 */
        MCBSP_SPCR2_RMK(
        MCBSP_SPCR2_FREE_NO,                   /* FREE   = 0 */
        MCBSP_SPCR2_SOFT_NO,                   /* SOFT   = 0 */
        MCBSP_SPCR2_FRST_FSG,                  /* FRST   = 0 */
        MCBSP_SPCR2_GRST_CLKG,                 /* GRST   = 0 */
        MCBSP_SPCR2_XINTM_XRDY,                /* XINTM  = 0 */
        0,                                     /* XSYNCER = N/A */
        MCBSP_SPCR2_XRST_DISABLE               /* XRST   = 0 */
       /*单数据相,接受数据长度为16位,每相2个数据*/
      MCBSP_RCR1_RMK(
      MCBSP_RCR1_RFRLEN1_OF(1),              /* RFRLEN1 = 1 */
      MCBSP_RCR1_RWDLEN1_16BIT               /* RWDLEN1 = 2 */
      MCBSP_RCR2_RMK(
        MCBSP_RCR2_RPHASE_SINGLE,              /* RPHASE  = 0 */
        MCBSP_RCR2_RFRLEN2_OF(0),              /* RFRLEN2 = 0 */
        MCBSP_RCR2_RWDLEN2_8BIT,               /* RWDLEN2 = 0 */
        MCBSP_RCR2_RCOMPAND_MSB,               /* RCOMPAND = 0 */
        MCBSP_RCR2_RFIG_YES,                   /* RFIG    = 0 */
        MCBSP_RCR2_RDATDLY_1BIT                /* RDATDLY = 1 */
       MCBSP_XCR1_RMK(
        MCBSP_XCR1_XFRLEN1_OF(1),              /* XFRLEN1 = 1 */
        MCBSP_XCR1_XWDLEN1_16BIT               /* XWDLEN1 = 2 */
    MCBSP_XCR2_RMK(
        MCBSP_XCR2_XPHASE_SINGLE,              /* XPHASE  = 0 */
        MCBSP_XCR2_XFRLEN2_OF(0),              /* XFRLEN2 = 0 */
        MCBSP_XCR2_XWDLEN2_8BIT,               /* XWDLEN2 = 0 */
        MCBSP_XCR2_XCOMPAND_MSB,               /* XCOMPAND = 0 */
        MCBSP_XCR2_XFIG_YES,                   /* XFIG    = 0 */
        MCBSP_XCR2_XDATDLY_1BIT                /* XDATDLY = 1 */
    MCBSP_SRGR1_DEFAULT,
    MCBSP_SRGR2_DEFAULT,
    MCBSP_MCR1_DEFAULT,
    MCBSP_MCR2_DEFAULT,
    MCBSP_PCR_RMK(
       MCBSP_PCR_IDLEEN_RESET,                 /* IDLEEN   = 0   */
       MCBSP_PCR_XIOEN_SP,                     /* XIOEN    = 0   */
       MCBSP_PCR_RIOEN_SP,                     /* RIOEN    = 0   */
       MCBSP_PCR_FSXM_EXTERNAL,                /* FSXM     = 0   */
       MCBSP_PCR_FSRM_EXTERNAL,                /* FSRM     = 0   */
       0,                                      /* DXSTAT = N/A   */
       MCBSP_PCR_CLKXM_INPUT,                  /* CLKXM    = 0   */
       MCBSP_PCR_CLKRM_INPUT,                  /* CLKRM    = 0   */
       MCBSP_PCR_SCLKME_NO,                    /* SCLKME   = 0   */
       MCBSP_PCR_FSXP_ACTIVEHIGH,              /* FSXP     = 0   */
       MCBSP_PCR_FSRP_ACTIVEHIGH,              /* FSRP     = 1   */
       MCBSP_PCR_CLKXP_FALLING,                /* CLKXP    = 1   */
       MCBSP_PCR_CLKRP_RISING                  /* CLKRP    = 1   */
    MCBSP_RCERA_DEFAULT,
    MCBSP_RCERB_DEFAULT,
    MCBSP_RCERC_DEFAULT,
    MCBSP_RCERD_DEFAULT,
    MCBSP_RCERE_DEFAULT,
    MCBSP_RCERF_DEFAULT,
    MCBSP_RCERG_DEFAULT,
    MCBSP_RCERH_DEFAULT,
    MCBSP_XCERA_DEFAULT,
    MCBSP_XCERB_DEFAULT,
    MCBSP_XCERC_DEFAULT,
    MCBSP_XCERD_DEFAULT,
    MCBSP_XCERE_DEFAULT,
    MCBSP_XCERF_DEFAULT,
    MCBSP_XCERG_DEFAULT,
    MCBSP_XCERH_DEFAULT
    /* This next struct shows how to use the I2C API */
    /* Create and initialize an I2C initialization structure */
    I2C_Setup I2Cinit = {
            0,              /* 7 bit address mode */
            0,         /* own address - don't care if master */
            84,            /* clkout value (Mhz)  */
            50,            /* a number between 10 and 400*/
            0,              /* number of bits/byte to be received or transmitted (8)*/
            0,              /* DLB mode on*/
            1               /* FREE mode of operation on*/
    I2C_Config testI2C;
    /*数字音频接口格式设置
    AIC23为主模式,数据为DSP模式,数据长度16位*/
    Uint16 digital_audio_inteface_format[2]={0x0e,0x53};
    /*AIC23的波特率设置,采样率为44.1K*/
    Uint16 sample_rate_control[2] = {0x10,0x23};
    /*AIC23寄存器复位*/
    Uint16 reset[2] ={0x1e,0x00};
    /*AIC23节电方式设置,所有部分均所与工作状态*/
    Uint16 power_down_control[2] ={0x0c,0x01};
    /*AIC23模拟音频的控制
    DAC使能,ADC输入选择为Line*/
    Uint16 analog_aduio_path_control[2] ={0x08,0x14};
    /*AIC23数字音频通路的控制*/
    Uint16 digital_audio_path_control[2] ={0x0a,0x05};
    /*AIC23数字接口的使能*/
    Uint16 digital_interface_activation[2] ={0x12,0x01};
    /*AIC23左通路音频调节*/
    Uint16 left_line_input_volume_control[2] ={0x00,0x17};
    /*AIC23右通路音频调节*/
    Uint16 right_line_input_volume_control[2] ={0x02,0x17};
    /*AIC23耳机左通路音频调节*/
    Uint16 left_headphone_volume_control[2] ={0x05,0xFF};
    /*AIC23耳机右通路音频调节*/
    Uint16 right_headphone_volume_control[2] = {0x07,0xFF};
    /*定义McBSP的句柄*/
    MCBSP_Handle hMcbsp;
    Uint16 i2c_status;
    Uint16 i,temp;
    void delay(Uint32 k)
       while(k--);
    void main(void)
        Uint16 aic23data = 0;
    i2c_status = 1;
        /* Initialize CSL library - This is REQUIRED !!! */
        /*初始化CSL库*/
        CSL_init();
    /*设置系统的运行速度为140MHz*/
        PLL_config(&myConfig);
        /* Initialize I2C, using parameters in init structure */
        /*初始化I2C的格式*/
    // I2C_config(&Config);
    // I2C_start();
    // I2C_getConfig(&Config1);
    /*I2C is undet reset*/
    I2C_RSET(I2CMDR,0);
    /*设置预分频寄存器,I2C的mode clock is 10MHz*/
    delay(100);
    I2C_RSET(I2CSAR,0x001A);
    I2C_RSET(I2CMDR,0x0620);
        I2C_setup(&I2Cinit);
      /*设置I2C的Mater clock*/
    I2C_RSET(I2CCLKL,100);
    I2C_RSET(I2CCLKH,100);
        I2C_getConfig(&testI2C);
    /*初始化McBSP0*/
    hMcbsp = MCBSP_open(MCBSP_PORT0,MCBSP_OPEN_RESET);
    /*设置McBSP0*/
    MCBSP_config(hMcbsp,&Mcbsp1Config);
    /*启动McBSP0*/
    MCBSP_start(hMcbsp,
                    MCBSP_RCV_START | MCBSP_XMIT_START,
                    0);
        MCBSP_getConfig(hMcbsp,&Mcbsptest);
        /*reset AIC23*/
        i2c_status = I2C_write( reset,          //pointer to data array
                        2, //length of data to be transmitted
                        1, //master or slaver
                        CODEC_ADDR,     //slave address to transmit to
                        1, //transfer mode of operation
                        30000 //time out for bus busy
    delay(1000);
        /*设置AIC23各部分均工作*/
        i2c_status = I2C_write( power_down_control,//pointer to data array
    /*设置AIC23的数字接口*/
    i2c_status = I2C_write( digital_audio_inteface_format,//pointer to data array
    /*设置AIC23模拟通路*/
    /* i2c_status = I2C_write( analog_aduio_path_control,//pointer to data array
    /*设置数字通路*/
    i2c_status = I2C_write( digital_audio_path_control,//pointer to data array
    /*设置AIC23的采样率*/
    i2c_status = I2C_write( sample_rate_control,//pointer to data array
    /*设置耳机音量*/
    i2c_status = I2C_write( left_headphone_volume_control,//pointer to data array
    i2c_status = I2C_write( right_headphone_volume_control,//pointer to data array
    /*设置Line输入的音量*/
    i2c_status = I2C_write( left_line_input_volume_control,//pointer to data array
    i2c_status = I2C_write( right_line_input_volume_control,//pointer to data array
    /*启动AIC23*/
    i2c_status = I2C_write( digital_interface_activation,//pointer to data array
    /*回放音频*/
    while(TRUE)
    while(!MCBSP_rrdy(hMcbsp)){};
    //aic23data = MCBSP_read16(hMcbsp);
    aic23data = 5000;
    for(temp=30000;temp>0;temp-=100)
            for(i=0;i<2;i++)
              aic23data = 5000;
              MCBSP_write16(hMcbsp,aic23data);
              delay(temp);
              aic23data = 0;
              delay(temp);
    //MCBSP_write16(hMcbsp,aic23data);
    * End of i2c2.c
回帖(1)
cherry1989
2024-10-18 17:50:39
要实现音频的采集并实时输出,您需要对TMS320VC5509A的音频接口进行配置,并编写相应的音频采集和输出代码。以下是一些关键步骤和代码示例,供您参考:
1. 配置音频接口:
首先,您需要配置TMS320VC5509A的音频接口,以便从麦克风采集音频信号并将其发送到耳机。这通常涉及到设置音频接口的采样率、位深度和通道数等参数。以下是配置音频接口的示例代码:
```c
#include "DSP2833x_Device.h"  // DSP2833x Headerfile Include File
// 配置音频接口
void AudioInterfaceConfig(void)
    // 设置采样率、位深度和通道数等参数
2. 音频采集:
接下来,您需要编写音频采集代码,以便从麦克风采集音频信号。这通常涉及到读取音频接口的输入缓冲区,并将其存储在一个数组中。以下是音频采集的示例代码:
```c
// 音频采集缓冲区
short audioBuffer[1024];
// 音频采集函数
void AudioCapture(void)
    // 从音频接口读取音频信号
3. 音频输出:
最后,您需要编写音频输出代码,以便将采集到的音频信号发送到耳机。这通常涉及到将音频信号从数组中读取出来,并将其写入音频接口的输出缓冲区。以下是音频输出的示例代码:
```c
// 音频输出函数
void AudioOutput(void)
    // 将音频信号写入音频接口的输出缓冲区
4. 实时处理:
为了实现实时音频处理,您需要在主循环中不断调用音频采集和输出函数。以下是主循环的示例代码:
```c
int main(void)
    // 初始化DSP和音频接口
    InitSysCtrl();
    AudioInterfaceConfig();
    while(1)
        // 音频采集
        AudioCapture();
        // 音频输出
        AudioOutput();
通过以上步骤和代码示例,您应该能够实现音频的采集并实时输出。请注意,您可能需要根据您的具体需求和硬件配置对代码进行相应的修改和优化。
举报
更多回帖
