RT-Thread论坛
直播中
云达贞
8年用户 957经验值
私信 关注
[问答]
调试stm32的TCP服务端程序,会导致hard fault的原因?
最近调试STM32的TCP服务端程序,遇到了想不明白的问题,具体过程如下:
使用的是rt-thread4.1.0的内核;
通过串口和esp32-c3通信
启用at_socket;
建立tcp服务器;
与wifi中其他客户端通信。
总体过程如上,刚开始调试发现esp32的软件包没有实现服务端,于是我就用esp8266的软件包测试,一切OK,tcp通信很好,然后我就把缺失的驱动从8266复制到esp32中,然后就出现了问题:
psr: 0x61000000
r00: 0x08024e30
r01: 0x00000000
r02: 0x20006590
r03: 0x00000000
r04: 0x2000b198
r05: 0x2000a768
r06: 0x200001cc
r07: 0x08026080
r08: 0x08025a10
r09: 0x0000000d
r10: 0x00000000
r11: 0x00000000
r12: 0x00000000
lr: 0x0800addd
pc: 0x0800adec
hard fault on thread: at_clnt
如上,我后面多次调试,确认问题点在at_socket.c中的函数at_connect_notice_cb中,原代码如下:
#ifdef AT_USING_SOCKET_SERVER
// 屏蔽掉此处代码,解决hard fault问题
// static int (*store_at_socket_temporary)(struct at_device *device, enum at_socket_type type);
static void at_connect_notice_cb(struct at_socket *sock, at_socket_evt_t event, const char *buff, size_t bfsz)
    RT_ASSERT(buff);
    RT_ASSERT(sock == RT_NULL);
    RT_ASSERT(event == AT_SOCKET_EVT_CONNECTED);
    extern struct netdev *netdev_default;
    struct netdev *netdev = RT_NULL;
    struct at_device *device = RT_NULL;
    struct at_socket *new_sock = RT_NULL;
    rt_base_t level;
    rt_slist_t *node = RT_NULL;
    struct at_socket *at_sock = RT_NULL;
    char *socket_info = RT_NULL;
    int base_socket = 0;
    if (netdev_default && netdev_is_up(netdev_default) &&
            netdev_family_get(netdev_default) == AF_AT)
        netdev = netdev_default;
    else
        /* get network interface device by protocol family AF_AT */
        netdev = netdev_get_by_family(AF_AT);
        if (netdev == RT_NULL)
            return;
    device = at_device_get_by_name(AT_DEVICE_NAMETYPE_NETDEV, netdev->name);
    if (device == RT_NULL)
        return;
    /* avoid use bottom driver to alloc "socket" */
    // store_at_socket_temporary = device->class->socket_ops->at_socket;
    // device->class->socket_ops->at_socket = RT_NULL;
    new_sock = alloc_socket_by_device(device, AT_SOCKET_TCP);
    if (new_sock == RT_NULL)
        return;
    new_sock->type = AT_SOCKET_TCP;
    new_sock->state = AT_SOCKET_CONNECT;
    /* set AT socket receive data callback function */
    new_sock->ops->at_set_event_cb(AT_SOCKET_EVT_RECV, at_recv_notice_cb);
    new_sock->ops->at_set_event_cb(AT_SOCKET_EVT_CLOSED, at_closed_notice_cb);
    new_sock->ops->at_set_event_cb(AT_SOCKET_EVT_CONNECTED, at_connect_notice_cb);
    //device->class->socket_ops->at_socket = store_at_socket_temporary;
    /* put incoming "socket" to the listen socket receiver packet list */
    sscanf(buff, "SOCKET:%d", &base_socket);
    LOG_D("ACCEPT BASE SOCKET: %d", base_socket);
    new_sock->user_data = (void *)base_socket;
    socket_info = rt_malloc(AT_SOCKET_INFO_LEN);
    rt_memset(socket_info, 0, AT_SOCKET_INFO_LEN);
    rt_sprintf(socket_info, "SOCKET:%d", new_sock->socket);
    /* find out the listen socket */
    level = rt_hw_interrupt_disable();
    rt_slist_for_each(node, &_socket_list)
        at_sock = rt_slist_entry(node, struct at_socket, list);
        if (at_sock && at_sock->magic == AT_SOCKET_MAGIC && at_sock->listen.is_listen == RT_TRUE)
            break;
        at_sock = RT_NULL;
    rt_hw_interrupt_enable(level);
    if(at_sock == RT_NULL)
        return;
    /* wakeup the "accept" function */
    rt_mutex_take(at_sock->recv_lock, RT_WAITING_FOREVER);
    if (at_recvpkt_put(&(at_sock->recvpkt_list), socket_info, AT_SOCKET_INFO_LEN) != RT_EOK)
        rt_free((void *)buff);
        rt_mutex_release(at_sock->recv_lock);
        return;
    rt_sem_release(at_sock->recv_notice);
    at_do_event_changes(at_sock, AT_EVENT_RECV, RT_TRUE);
#endif
问题就在我注释掉的程序中,使用变量store_at_socket_temporary,每次程序执行下面这条语句
就会导致hard fault,始终没想明白什么原因,于是注释掉了和这个变量相关的语句,一切正常运行。
我后期又通过vscode对比了esp8266和esp32相关的3个驱动文件,除了有几处at指令语句因为esp at固件不同,稍微差几个字,以及变量名一个是esp8266开头,一个是esp32开头,其他的都一模一样。
大家有明白原因的吗,虽然问题解决了,但是百思不得其解啊!
回帖(1)
chunhuahua
2024-9-13 18:11:01
在调试STM32的TCP服务端程序时,可能导致Hard Fault的原因有很多。根据您提供的信息,我将尝试分析可能的原因并提供一些建议。
1. 内存访问错误:Hard Fault通常是由于内存访问错误引起的。在您的代码中,可能存在对未初始化或非法内存地址的访问。请检查您的代码,确保所有指针和数组访问都是有效的。
2. 堆栈溢出:在您的代码中,可能存在递归调用或大量局部变量,导致堆栈溢出。请检查您的代码,确保堆栈空间足够大,并且没有过多的递归调用。
3. 中断优先级配置错误:在您的代码中,可能存在中断优先级配置错误,导致中断服务例程(ISR)中的代码无法正确执行。请检查您的中断优先级配置,确保它们是正确的。
4. 硬件问题:硬件问题也可能导致Hard Fault。请检查您的STM32硬件连接,确保所有连接都是正确的,并且没有损坏的元件。
5. 驱动程序不兼容:您提到将ESP8266的驱动程序复制到ESP32中,可能导致驱动程序不兼容。请确保您使用的驱动程序与您的硬件兼容,或者尝试使用专门为ESP32编写的驱动程序。
6. 固件问题:您使用的RT-Thread 4.1.0内核可能存在一些已知的问题。请检查RT-Thread的官方文档和社区,看看是否有关于您遇到的问题的解决方案或更新。
为了进一步调试问题,您可以尝试以下步骤:
1. 使用调试器(如ST-Link)逐步执行代码,观察寄存器和内存的变化,以便找到导致Hard Fault的具体位置。
2. 在代码中添加调试信息,例如打印日志,以帮助您了解程序的执行流程和状态。
3. 尝试使用不同的TCP/IP堆栈,例如lwIP,看看是否仍然存在问题。
4. 如果可能,尝试在其他STM32硬件上运行您的代码,以排除硬件问题。
希望这些建议能帮助您找到并解决问题。
举报
更多回帖
