综合技术交流
直播中
1123127317
9年用户 1131经验值
擅长:制造/封装 接口/总线/驱动
私信 关注
[问答]
IR611版本2.2.0.r4616模块U8300W不能连接网络,为什么?
以下日志信息看出已经识别到模块信息(不插sim也会报错,使用的正常联通卡不是物联网卡),但是一直识别不出SIM卡信息,天线某宝买的新的4G全网通3DBI有什么方法可以测试一下,或者诊断记录可以分析出是那边的问题吗?
希望可以得到帮助  谢谢!
信息Aug 1 20:03:52redial[1305]send to modem (8): AT+CSQ^M
信息Aug 1 20:03:52redial[1305]modem response :<22>, ^M +CSQ: 99,125^M ^M OK^M
信息Aug 1 20:03:55redial[1305]modem has no signal, check the antenna!
信息Aug 1 20:03:55redial[1305]cfun resetting modem...
信息Aug 1 20:03:55redial[1305]send to modem (11): AT+CFUN=0^M
信息Aug 1 20:03:55redial[1305]modem response :<6>, ^M OK^M
信息Aug 1 20:03:57redial[1305]send to modem (11): AT+CFUN=1^M
信息Aug 1 20:03:58redial[1305]modem response :<6>, ^M OK^M
信息Aug 1 20:04:08redial[1305]scanning modem (1/120)...
信息Aug 1 20:04:08redial[1305]scanning wan1 => /dev/ttyUSB1
调试Aug 1 20:04:08redial[1305]got an attached device
调试Aug 1 20:04:08redial[1305]vendor id is 1c9e, product id is 9b05
信息Aug 1 20:04:19redial[1305]setup AT command set for usb modem!
信息Aug 1 20:04:19redial[1305]nvram set wan1_iface=/dev/ttyUSB1
信息Aug 1 20:04:19redial[1305]send to modem (5): ATH^M
信息Aug 1 20:04:19redial[1305]modem response :<6>, ^M OK^M
信息Aug 1 20:04:19redial[1305]send to modem (4): AT^M
信息Aug 1 20:04:19redial[1305]send to modem (6): ATE0^M
信息Aug 1 20:04:19redial[1305]initial modem...
信息Aug 1 20:04:19redial[1305]send to modem (10): AT+CFUN=1^M
信息Aug 1 20:04:19redial[1305]initial modem successfully!
信息Aug 1 20:04:19redial[1305]send to modem (9): AT+CGSN^M
信息Aug 1 20:04:19redial[1305]modem response :<25>, ^M 869752020352981^M ^M OK^M
信息Aug 1 20:04:19redial[1305]send to modem (14): AT+MODODREX?^M
信息Aug 1 20:04:19redial[1305]modem response :<22>, ^M +MODODREX: 2^M ^M OK^M
信息Aug 1 20:04:19redial[1305]send to modem (29): AT$QCPDPP=1,3,"gprs","gprs"^M
信息Aug 1 20:04:19redial[1305]send to modem (13): AT+CGDCONT?^M
信息Aug 1 20:04:19redial[1305]modem response :<49>, ^M +CGDCONT: 1,"IP","uninet","0.0.0.0",0,0^M ^M OK^M
信息Aug 1 20:04:19redial[1305]The current apn configration: uninet
信息Aug 1 20:04:19redial[1305]send to modem (28): AT+CGDCONT=1,"IP","uninet"^M
信息Aug 1 20:04:19redial[1305]send to modem (10): AT+CPIN?^M
信息Aug 1 20:04:19redial[1305]modem response :<22>, ^M +CPIN: READY^M ^M OK^M
信息Aug 1 20:04:19redial[1305]modem is detected!
更多回帖
