你好,我刚接触 ESP8266 TROS SDK,想用ESP8266的HSPI驱动NRF24L01模块,自己模拟SPI时序可以正常驱动NRF24L01,但
通信速率只有350K左右。请问如何使用RTOS SDK才能正确驱动NRF24L模块呢?关键在于要如何用RTOS SDK里面的函数来替换我的SPI2_ReadWriteByte函数(全双工)。
RTOS SDK HSPI 代码
void MySPI_Init(void)
SpiAttr hSpiAttr;
hSpiAttr.bitOrder = SpiBitOrder_MSBFirst;
hSpiAttr.speed = SpiSpeed_2MHz;
hSpiAttr.mode = SpiMode_Master;Code:
Select all
hSpiAttr.subMode = SpiSubMode_0;
// Init HSPI GPIO
WRITE_PERI_REG(PERIPHS_IO_MUX, 0x105);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 2);//configure io to spi mode
SPIInit(SpiNum_HSPI, &hSpiAttr);
我发现RTOS SPI 里面主要由spi_transac
tion函数处理接收和发送。
还有以下宏和定义
uint32 spi_transaction(uint8 spi_no, uint8 cmd_bits, uint16 cmd_data, uint32 addr_bits, uint32 addr_data, uint32 dout_bits, uint32 dout_data, uint32 din_bits, uint32 dummy_bits);
#define spi_busy(spi_no) READ_PERI_REG(SPI_CMD(spi_no))&SPI_USR
#define spi_txd(spi_no, bits, data) spi_transaction(spi_no, 0, 0, 0, 0, bits, (uint32) data, 0, 0)
#define spi_tx8(spi_no, data) spi_transaction(spi_no, 0, 0, 0, 0, 8, (uint32) data, 0, 0)
#define spi_tx16(spi_no, data) spi_transaction(spi_no, 0, 0, 0, 0, 16, (uint32) data, 0, 0)
#define spi_tx32(spi_no, data) spi_transaction(spi_no, 0, 0, 0, 0, 32, (uint32) data, 0, 0)
#define spi_rxd(spi_no, bits) spi_transaction(spi_no, 0, 0, 0, 0, 0, 0, bits, 0)
#define spi_rx8(spi_no) spi_transaction(spi_no, 0, 0, 0, 0, 0, 0, 8, 0)
#define spi_rx16(spi_no) spi_transaction(spi_no, 0, 0, 0, 0, 0, 0, 16, 0)
#define spi_rx32(spi_no) spi_transaction(spi_no, 0, 0, 0, 0, 0, 0, 32, 0)
我的模拟SPI代码
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
//MISO->GPIO12
//MOSI->GPIO13
//SCK->GPIO14
//CSN->GPIO15
//IRQ->GPIO2
//CE->GPIO5
u8 NRF24L01_MISO()//输入
u8 result;
result = GPIO_INPUT_GET(GPIO_ID_PIN(12));
return result;
void NRF24L01_MOSI(u8 level)
GPIO_OUTPUT_SET(GPIO_ID_PIN(13), level);
void NRF24L01_SCK(u8 level)
GPIO_OUTPUT_SET(GPIO_ID_PIN(14), level);
void NRF24L01_CSN(u8 level)
GPIO_OUTPUT_SET(GPIO_ID_PIN(15), level);
void NRF24L01_CE(u8 level)
GPIO_OUTPUT_SET(GPIO_ID_PIN(5), level);
u8 NRF24L01_IRQ() //输入
u8 result;
result = GPIO_INPUT_GET(GPIO_ID_PIN(2));
return result;
void NRF24L01_Init(void)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, FUNC_GPIO12); //输入
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_GPIO13);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, FUNC_GPIO14);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_GPIO15);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO5_U, FUNC_GPIO5);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2); //输入
NRF24L01_CE(0);
NRF24L01_CSN(1);
uint8 SPI2_ReadWriteByte(uint8 u8_writedata)
uint8 i;
uint8 u8_readdata = 0x00;
for(i=0;i<8;i++)
u8_readdata <<= 1; //读取MISO 8次输入的值,存入u8_readdata。
if(u8_writedata & 0x80) //判断最高位,总是写最高位(输出最高位)
NRF24L01_MOSI(1); //MOSI输出1,数据总线准备数据1
else
NRF24L01_MOSI(0); //MOSI输出0,数据总线准备数据0
u8_writedata <<= 1; //左移抛弃已经输出的最高位
NRF24L01_SCK(1); //上升沿来了(SCK从0-->1),数据总线上的数据写入器件
if(NRF24L01_MISO()) //读取最高位,保存至最末尾,通过左移位完成读整个字节
u8_readdata |= 0x01;
else
u8_readdata &= ~0x01;
NRF24L01_SCK(0); //下降沿来了(SCK从1-->0),MISO上将产生新的数据,读取存入u8——readdata
return u8_readdata;
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
u8 status;
NRF24L01_CSN(0);
status =SPI2_ReadWriteByte(reg);
SPI2_ReadWriteByte(value);
NRF24L01_CSN(1);
return(status);
u8 NRF24L01_Read_Reg(u8 reg)
u8 reg_val;
NRF24L01_CSN(0);
reg_val=SPI2_ReadWriteByte(0XFF);
NRF24L01_CSN(1);
return(reg_val);
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
u8 status,u8_ctr;
NRF24L01_CSN(0);
status=SPI2_ReadWriteByte(reg);
for(u8_ctr=0;u8_ctrGPIO12
//MOSI->GPIO13
//SCK->GPIO14
//CSN->GPIO15
//IRQ->GPIO2
//CE->GPIO5
u8 result;
return result;
u8 result;
return result;
NRF24L01_CE(0);
NRF24L01_CSN(1);
uint8 i;
for(i=0;i<8;i++)
else
else
return u8_readdata;
u8 status;
NRF24L01_CSN(0);
NRF24L01_CSN(1);
return(status);
u8 reg_val;
NRF24L01_CSN(0);
NRF24L01_CSN(1);
return(reg_val);
u8 status,u8_ctr;
NRF24L01_CSN(0);
for(u8_ctr=0;u8_ctr
