乐鑫技术交流
直播中
HCPcry
9年用户 1258经验值
擅长:处理器/DSP
私信 关注
[问答]
OTA时,由USER2.BIN更新USER1.BIN出错,无法启动怎么解决?
BOOT.BIN用的1.5版的.
SDK用的1.5.2,由USER1.BIN更新USER2.BIN时正常,重启后能运行到USER2.BIN,但随即从USER2.BIN更新USER1.BIN时,FLASH超时,触发WDT RESET ,系统一直报错,无法启动.重新通过串口刷一次USER1.BIN,重启后是从USER2.BIN启动.相关日志如下:
第一次启动信息:
ets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1856, room 16
tail 0
chksum 0x63
load 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
SDK version:1.5.2(80914727)
OAT升级USER2.BIN部分日志:
HEAD /agent/update/user2.bin HTTP/1.1
Host: 192.168.1.140
Connection: close
Content-Length: 0
Cache-Control: max-age=0
Accept: */*
User-Agent: Mozilla/5.0 (Windows NT 5.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36
Accept-Encoding: gzip, deflate
Accept-Language: zh-CN,zh;q=0.8,en;q=0.6,zh-TW;q=0.4
pusrdata = HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
Accept-Ranges: bytes
ETag: W/"236356-1456840445390"
Last-Modified: Tue, 01 Mar 2016 13:54:05 GMT
Content-Type: application/octet-stream
Content-Length: 236356
Date: Tue, 01 Mar 2016 13:55:07 GMT
Connection: close
sumlength = 236356
sec_block 58
..........................................................upgrade_get_sum_disconcb 41696
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
执行OAT升级USER2.BIN时,启动信息:
totallen = 236356
upgrade file download finished.
flash_crc = 896672383
img_crc = 896672383
upgrade_check
upgrade successful
reboot to use2
state: 5 -> 0 (0)
rm 0
pm close 7
del if0
usl
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
jump to run user2 @ 81000
再次执行OAT,升级USER1.BIN日志信息:
HEAD /agent/update/user1.bin HTTP/1.1
Host: 192.168.1.140
Connection: close
Content-Length: 0
Accept: */*
ETag: W/"236356-1456840451625"
Last-Modified: Tue, 01 Mar 2016 13:54:11 GMT
Date: Tue, 01 Mar 2016 13:55:28 GMT
Connection: close
sumlength = 236356
sec_block 58
erase sector=1 ok
ets Jan  8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
Fatal exception (0):
epc1=0x40201a18, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
后面一直是这个错误信息,重新上电直接报这个错误,无法启动.
通过串口单独烧录USER1.BIN到0X01000后,启动成功,启动信息:
ets Jan  8 2013,rst cause:2, boot mode:(3,6)
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
don't use rtc mem data
回帖(1)
尚文清
2024-7-18 18:03:46
以下是一些建议,希望能帮助您解决问题:
1. **检查文件完整性**:确保USER2.BIN文件没有损坏。您可以通过重新生成或下载该文件来验证。
2. **检查文件大小**:确保USER2.BIN文件的大小没有超过设备的闪存容量。如果文件过大,可能会导致更新失败。
3. **检查BOOT.BIN版本**:您提到使用的是1.5版的BOOT.BIN,但SDK是1.5.2。请确保BOOT.BIN与SDK版本兼容。如果需要,尝试升级BOOT.BIN到与SDK相匹配的版本。
4. **检查WDT(看门狗定时器)设置**:从日志来看,系统在更新过程中触发了WDT RESET。这可能是因为更新过程中的操作超时。您可以尝试调整WDT的超时时间,以确保在更新过程中有足够的时间完成操作。
5. **检查日志中的错误信息**:从您提供的日志来看,似乎在加载USER2.BIN时出现了一些问题。请仔细检查日志中的chksum(校验和)值,确保它们与预期值匹配。如果校验和不匹配,可能意味着文件在传输过程中被损坏。
6. **尝试手动更新**:如果可能的话,尝试通过串口或其他方式手动更新USER1.BIN,而不是通过OTA。这可以帮助您确定问题是否与OTA过程有关。
7. **检查网络连接**:在进行OTA更新时,网络连接的稳定性非常重要。请确保设备在更新过程中有稳定的网络连接。
举报
更多回帖
