/* main.c -- MQTT client example
* Copyright (c) 2014-2015, Tuan PM
* All rights reserved.
* Redistribu
tion and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* * Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Redis nor the names of its contributors may be used
* to endorse or promote products derived from this software without
* specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#include "ets_sys.h"
#include "driver/uart.h"
#include "osapi.h"
#include "mqtt.h"
#include "wifi.h"
#include "config.h"
#include "debug.h"
#include "gpio.h"
#include "user_interface.h"
#include "mem.h"
#include "driver/ir_tx_rx.h"
#include"driver/ringbuf.h"
#include "ip_addr.h"
#include "espconn.h"
#include "smartconfig.h"
#include "airkiss.h"
#define DEVICE_TYPE "gh_e2728760afcf"//wechat public number
#define DEVICE_ID "gh_e2728760afcf_bf51293fd4cd31a8"//,"qrticket" //model ID
#define DEFAULT_LAN_PORT 12476
os_timer_t ir_timer;
os_timer_t Send_temp_timer_t;
MQTT_Client mqttClient;
LOCAL esp_udp ssdp_udp;
LOCAL struct espconn pssdpudpconn;
LOCAL os_timer_t ssdp_time_serv;
uint8_t lan_buf[200];
uint16_t lan_buf_len;
uint8 udp_sent_cnt = 0;
int mark=0;
const airkiss_config_t akconf =
(airkiss_memset_fn)&memset,
(airkiss_memcpy_fn)&memcpy,
(airkiss_memcmp_fn)&memcmp,
0,
void wifiConnectCb(uint8_t status)
if(status == STATION_GOT_IP){
MQTT_Connect(&mqttClient);
} else {
MQTT_Disconnect(&mqttClient);
void mqttConnectedCb(uint32_t *args)
MQTT_Client* client = (MQTT_Client*)args;
INFO("MQTT: Connectedrn");
MQTT_Subscribe(client, "remote", 0);
void mqttDisconnectedCb(uint32_t *args)
INFO("MQTT: Disconnectedrn");
void mqttPublishedCb(uint32_t *args)
INFO("MQTT: Publishedrn");
void mqttDataCb(uint32_t *args, const char* topic, uint32_t topic_len, const char *data, uint32_t data_len)
char *topicBuf = (char*)os_zalloc(topic_len+1),
*dataBuf = (char*)os_zalloc(data_len+1);
os_memcpy(topicBuf, topic, topic_len);
topicBuf[topic_len] = 0;
os_memcpy(dataBuf, data, data_len);
dataBuf[data_len] = 0;
INFO("Receive topic: %s, data: %s rn", topicBuf, dataBuf);
os_free(topicBuf);
os_free(dataBuf);
LOCAL void ICACHE_FLASH_ATTR
airkiss_wifilan_time_callback(void)
uint16 i;
airkiss_lan_ret_t ret;
if ((udp_sent_cnt++) >30) {
udp_sent_cnt = 0;
os_timer_disarm(&ssdp_time_serv);//s
//return;
ssdp_udp.remote_port = DEFAULT_LAN_PORT;
ssdp_udp.remote_ip[0] = 255;
ssdp_udp.remote_ip[1] = 255;
ssdp_udp.remote_ip[2] = 255;
ssdp_udp.remote_ip[3] = 255;
lan_buf_len = sizeof(lan_buf);
ret = airkiss_lan_pack(AIRKISS_LAN_SSDP_NOTIFY_CMD,
DEVICE_TYPE, DEVICE_ID, 0, 0, lan_buf, &lan_buf_len, &akconf);
if (ret != AIRKISS_LAN_PAKE_READY) {
os_printf("Pack lan packet error!");
return;
ret = espconn_sendto(&pssdpudpconn, lan_buf, lan_buf_len);
if (ret != 0) {
os_printf("UDP send error!");
os_printf("Finish send notify!n");
airkiss_wifilan_recv_callbk(void *arg, char *pdata, unsigned short len)
uint16 i;
remot_info* pcon_info = NULL;
airkiss_lan_ret_t ret = airkiss_lan_recv(pdata, len, &akconf);
airkiss_lan_ret_t packret;
switch (ret){
case AIRKISS_LAN_SSDP_REQ:
espconn_get_connection_info(&pssdpudpconn, &pcon_info, 0);
os_printf("remote ip: %d.%d.%d.%d rn",pcon_info->remote_ip[0],pcon_info->remote_ip[1],
pcon_info->remote_ip[2],pcon_info->remote_ip[3]);
os_printf("remote port: %d rn",pcon_info->remote_port);
pssdpudpconn.proto.udp->remote_port = pcon_info->remote_port;
os_memcpy(pssdpudpconn.proto.udp->remote_ip,pcon_info->remote_ip,4);
packret = airkiss_lan_pack(AIRKISS_LAN_SSDP_RESP_CMD,
if (packret != AIRKISS_LAN_PAKE_READY) {
return;
os_printf("rnrn");
for (i=0; i
* Redistribution and use in source and binary forms, with or without
#include "osapi.h"
#include "mqtt.h"
#include "wifi.h"
#include "config.h"
#include "debug.h"
#include "gpio.h"
#include "mem.h"
int mark=0;
0,
} else {
os_free(topicBuf);
os_free(dataBuf);
uint16 i;
udp_sent_cnt = 0;
//return;
return;
if (ret != 0) {
uint16 i;
switch (ret){
return;
os_printf("rnrn");
for (i=0; i
#include "osapi.h"
#include "mqtt.h"
#include "wifi.h"
#include "config.h"
#include "debug.h"
#include "gpio.h"
#include "mem.h"
int mark=0;
0,
} else {
os_free(topicBuf);
os_free(dataBuf);
uint16 i;
udp_sent_cnt = 0;
//return;
return;
if (ret != 0) {
uint16 i;
switch (ret){
return;
os_printf("rnrn");
for (i=0; i
