乐鑫技术交流
直播中
李丽
8年用户 1507经验值
私信 关注
[问答]
ESP32-C3使用WIFI_STA例程卡死在初始化(phy_init:)了,为什么?
ESP32-C3使用的是官方MINI模块,但是板子是自制的,前段时间跑通了LVGL很高兴,昨天开始尝试WIFI。
事情最初是这样子的:
1. 使用IDF里的station模式例程做测试发现烧录完Monitor直接输出报错,没有芯片启动log信息。而且网上说辞不一,定位不了问题。
  • Exception in thread Thread-2 (_run_outer):
  • Traceback (most recent call last):
  •   File "/usr/lib/python3.10/threading.py", line 1009, in _bootstrap_inner
  •     self.run()
  •   File "/usr/lib/python3.10/threading.py", line 946, in run
  •     self._target(*self._args, **self._kwargs)
  •   File "/home/kying/esp/esp-idf/tools/idf_monitor_base/stoppable_thread.py", line 58, in _run_outer
  •     self.run()
  •   File "/home/kying/esp/esp-idf/tools/idf_monitor_base/serial_reader.py", line 51, in run
  •     self.serial.open()
  •   File "/home/kying/.espressif/python_env/idf4.4_py3.10_env/lib/python3.10/site-packages/serial/serialposix.py", line 338, in open
  •     self._update_rts_state()
  •   File "/home/kying/.espressif/python_env/idf4.4_py3.10_env/lib/python3.10/site-packages/serial/serialposix.py", line 708, in _update_rts_state
  •     fcntl.ioctl(self.fd, TIOCMBIC, TIOCM_RTS_str)
  • OSError: [Errno 71] Protocol error
2. 于是开始排查问题,在例程的nvs初始化后、wifi初始化之前加入延迟,烧录后Monitor成功看到BootLoader等log信息。
代码:
  • esp_err_t ret = nvs_flash_init();
  •     if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
  •       ESP_ERROR_CHECK(nvs_flash_erase());
  •      ret =  nvs_flash_init();
  •      ESP_ERROR_CHECK(ret);
  •     ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
  •     printf("---------------- WiFi START! -----------------n");
  •     vTaskDelay(5000/portTICK_RATE_MS);
  •     wifi_init_sta();
LOG输出:
  • ESP-ROM:esp32c3-api1-20210207
  • Build:Feb  7 2021
  • rst:0x15 (USB_UART_CHIP_RESET),boot:0xf (SPI_FAST_FLASH_BOOT)
  • Saved PC:0x420515b8
  • 0x420515b8: cpu_ll_waiti at /home/kying/esp/esp-idf/components/hal/esp32c3/include/hal/cpu_ll.h:168
  • (inlined by) esp_pm_impl_waiti at /home/kying/esp/esp-idf/components/esp_pm/pm_impl.c:837
  • SPIWP:0xee
  • mode:DIO, clock div:1
  • load:0x3fcd6100,len:0x16b8
  • load:0x403ce000,len:0x930
  • load:0x403d0000,len:0x2d40
  • entry 0x403ce000
  • I (24) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
  • I (24) boot: compile time 19:46:22
  • I (25) boot: chip revision: 3
  • I (26) boot.esp32c3: SPI Speed      : 80MHz
  • I (31) boot.esp32c3: SPI Mode       : DIO
  • I (36) boot.esp32c3: SPI Flash Size : 4MB
  • I (41) boot: Enabling RNG early entropy source...
  • I (46) boot: Partition Table:
  • I (50) boot: ## Label            Usage          Type ST Offset   Length
  • I (57) boot:  0 nvs              WiFi data        01 02 00009000 00006000
  • I (64) boot:  1 phy_init         RF data          01 01 0000f000 00001000
  • I (72) boot:  2 factory          factory app      00 00 00010000 00100000
  • I (79) boot: End of partition table
  • I (83) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=134e8h ( 79080) map
  • I (104) esp_image: segment 1: paddr=00023510 vaddr=3fc8e200 size=02b4ch ( 11084) load
  • I (107) esp_image: segment 2: paddr=00026064 vaddr=40380000 size=09fb4h ( 40884) load
  • I (118) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=74e24h (478756) map
  • I (193) esp_image: segment 4: paddr=000a4e4c vaddr=40389fb4 size=04118h ( 16664) load
  • I (197) esp_image: segment 5: paddr=000a8f6c vaddr=50000010 size=00010h (    16) load
  • I (204) boot: Loaded app from partition at offset 0x10000
  • I (205) boot: Disabling RNG early entropy source...
  • I (222) cpu_start: Pro cpu up.
  • I (230) cpu_start: Pro cpu start user code
  • I (230) cpu_start: cpu freq: 160000000
  • I (231) cpu_start: Application information:
  • I (233) cpu_start: Project name:     wifi_station
  • I (239) cpu_start: App version:      1
  • I (243) cpu_start: Compile time:     Mar 29 2022 20:30:59
  • I (249) cpu_start: ELF file SHA256:  f2b0456acb581f1b...
  • I (255) cpu_start: ESP-IDF:          v4.4-dirty
  • I (260) heap_init: Initializing. RAM available for dynamic allocation:
  • I (268) heap_init: At 3FC94CC0 len 0002B340 (172 KiB): DRAM
  • I (274) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
  • I (281) heap_init: At 50000020 len 00001FE0 (7 KiB): RTCRAM
  • I (287) spi_flash: detected chip: generic
  • I (292) spi_flash: flash io: dio
  • I (296) sleep: Configure to isolate all GPIO pins in sleep state
  • I (302) sleep: Enable automatic switching of GPIO sleep configuration
  • I (310) cpu_start: Starting scheduler.
  • I (321) wifi station: ESP_WIFI_MODE_STA
  • ---------------- WiFi START! -----------------
  • I (5321) pp: pp rom version: 9387209
  • I (5321) net80211: net80211 rom version: 9387209
  • I (5331) wifi:wifi driver task: 3fc9d908, prio:23, stack:6656, core=0
  • I (5331) system_api: Base MAC address is not set
  • I (5331) system_api: read default base MAC address from EFUSE
  • I (5341) wifi:wifi firmware version: 7679c42
  • I (5341) wifi:wifi certification version: v7.0
  • I (5341) wifi:config NVS flash: enabled
  • I (5341) wifi:config nano formating: disabled
  • I (5351) wifi:Init data frame dynamic rx buffer num: 32
  • I (5351) wifi:Init management frame dynamic rx buffer num: 32
  • I (5361) wifi:Init management short buffer num: 32
  • I (5361) wifi:Init dynamic tx buffer num: 32
  • I (5371) wifi:Init static tx FG buffer num: 2
  • I (5371) wifi:Init static rx buffer size: 1600
  • I (5381) wifi:Init static rx buffer num: 10
  • I (5381) wifi:Init dynamic rx buffer num: 32
  • I (5381) wifi_init: rx ba win: 6
  • I (5391) wifi_init: tcpip mbox: 32
  • I (5391) wifi_init: udp mbox: 6
  • I (5401) wifi_init: tcp mbox: 6
  • I (5401) wifi_init: tcp tx win: 5744
  • I (5401) wifi_init: tcp rx win: 5744
  • I (5411) wifi_init: tcp mss: 1440
  • I (5411) wifi_init: WiFi IRAM OP enabled
  • I (5421) wifi_init: WiFi RX IRAM OP enabled
  • I (5421) phy_init: phy_version 907,3369105-dirty,Dec  3 2021,14:55:12
然后就卡住了,没有像网络教程那样有后面的输出,比如连接WiFi的ssid密码以及是否成功或尝试重连等。而且感觉芯片会卡死,关闭再启动Monitor又会回到不加延迟的报错OSError: [Errno 71] Protocol error,且不可再正常烧录,需要拉低IO9进入下载模式才行。
3. 参考了本论坛中/英板块可能类似的问题,擦除flash、关闭nvs等操作,大多结果都差不多,只不过擦除第一次可能多一句:
W (5634) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
但后面依旧卡死,没有log输出。起初网络上很多说这句Warnning是供电问题导致的,但我的设计使用的AMS1117-3.3供电理论支持1A MAX且加了10uf+0.1uf电容,我甚至后来拆了稳压芯片使用稳压源供电(USB仅提供Jtag调试)仍然有该行。后来论坛其他帖子和手册看到nvs擦除后就会回到full calibration,所以到头来大概不是供电问题。
目前排查的情况就是这些了,如我有什么疏漏的地方请告知我,有解决的可能思路请尽管提出,十分感谢各位。下一步计划是换一块模块看看情况,以及想请问这个phy init具体的情况,该配置是否可以更换版本,我看网上其他人log输出的版本不一样,会不会是该原因?
回帖(1)
自我清欢
2024-7-1 16:18:56
从您提供的信息来看,问题可能出现在以下几个方面:
1. **固件烧录问题**:确保您使用的是正确的固件版本,以及烧录过程中没有出现错误。如果烧录过程中出现问题,可能导致设备无法正常启动。
2. **硬件问题**:由于您使用的是自制的板子,可能存在硬件连接问题或者元件质量问题。请检查所有连接是否正确,元件是否完好。
3. **电源问题**:ESP32-C3模块需要稳定的电源供应。请确保您的电源供应稳定,且符合模块的电压和电流要求。
4. **WIFI模块配置问题**:在尝试连接WIFI时,确保您的WIFI设置正确,包括SSID和密码。同时,检查您的WIFI模块是否支持您尝试连接的WIFI频段。
5. **软件问题**:您提到的错误信息看起来像是Python线程问题,这可能是由于ESP-IDF环境或者Python环境的问题。请确保您的开发环境设置正确,包括Python版本、ESP-IDF版本等。
6. **代码问题**:检查您的代码是否有逻辑错误或者配置错误,这可能导致程序在执行过程中出现问题。
解决步骤:
- **重新烧录固件**:尝试使用不同的固件版本,或者重新烧录当前固件,确保烧录过程没有问题。
- **检查硬件**:仔细检查您的自制板子,确保所有连接正确,元件完好。
- **检查电源**:确保电源供应稳定,符合模块要求。
- **检查WIFI配置**:确保WIFI设置正确,尝试连接不同的WIFI网络,看是否问题依旧。
- **检查开发环境**:确保Python版本、ESP-IDF版本等设置正确,尝试在其他计算机或环境中运行相同的代码。
- **检查代码**:仔细检查代码,确保没有逻辑错误或配置错误。
如果问题依旧存在,建议您提供更详细的错误信息和代码,以便进一步分析问题。
举报
更多回帖
