乐鑫技术交流
直播中
李华
8年用户 1439经验值
私信 关注
[问答]
在vscode+pio环境开发esp-wrrom-32遇到这种下载问题怎么解决?
请问在vscode+pio环境开发esp-wrrom-32遇到这种下载问题怎么解决?
Traceback (most recent call last):
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 5387, in
    _main()
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 5380, in _main
    main()
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 4687, in main
    esp = esp or get_default_connected_device(ser_list, port=args.port, connect_attempts=args.connect_attempts,
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 115, in get_default_connected_device
    _esp.connect(before, connect_attempts)
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 664, in connect
    last_error = self._connect_attempt(mode=mode, usb_jtag_serial=usb_jtag_serial, extra_delay=extra_delay)
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 629, in _connect_attempt
    self.sync()
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 519, in sync
    val, _ = self.command(self.ESP_SYNC, b'x07x07x12x20' + 32 * b'x55',
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 458, in command
    self.write(pkt)
  File "C:Userslenovo.platformiopackagestool-esptoolpyesptool.py", line 421, in write
    self._port.write(buf)
  File "C:Userslenovo.platformiopenvlibsite-packagesserialserialwin32.py", line 325, in write
    raise SerialtimeoutException('Write timeout')
serial.serialutil.SerialTimeoutException: Write timeout
*** [upload] Error 1
回帖(1)
李辉
2024-7-1 15:29:12
在VSCode + PlatformIO环境中开发ESP32时,遇到下载问题可能是由多种原因导致的。以下是一些建议和解决方案,帮助您解决这个问题:
1. 检查硬件连接:
确保您的ESP32模块与计算机之间的连接是稳定的。检查USB线是否完好,以及ESP32模块的引脚是否有损坏。
2. 检查电源:
确保ESP32模块的电源稳定,避免在下载过程中出现断电的情况。
3. 检查波特率设置:
在PlatformIO配置文件(platformio.ini)中,检查波特率设置是否正确。通常,波特率应设置为460800或115200。例如:
[env:esp32dev]
platform = espressif32
board = esp32dev
framework = arduino
upload_speed = 460800
4. 检查烧录模式:
确保您的ESP32模块处于正确的烧录模式。通常,烧录模式为DOUT(下载模式)或D2WD(下载和焊接模式)。
5. 检查ESPTool版本:
确保您使用的ESPTool版本与您的ESP32模块兼容。您可以在PlatformIO配置文件中指定ESPTool版本,例如:
[platformio]
default_envs = esp32dev
src_dir = src
[env]
board = esp32dev
framework = arduino
lib_deps =
  ArduinoJson
  PubSubClient
  WiFi
monitor_filters = esp32_exception_decoder
extra_scripts = pre:extra_script.py
[env:esp32dev]
board = esp32dev
framework = arduino
upload_protocol = esptool
6. 尝试使用其他烧录工具:
如果问题仍然存在,您可以尝试使用其他烧录工具,如NodeMCU Flasher或esptool.py,看看是否能够解决问题。
7. 检查代码问题:
确保您的代码没有错误,编译后生成的固件文件是正确的。如果代码中有错误,可能导致烧录过程中出现问题。
8. 重启设备:
有时候,重启ESP32模块和计算机可以解决一些奇怪的问题。
9. 更新PlatformIO和相关库:
确保您的PlatformIO和相关库是最新版本,以避免兼容性问题。
10. 查看错误日志:
仔细查看错误日志,了解问题的具体原因。这有助于您找到解决方案。
总之,解决ESP32下载问题需要耐心和细致的排查。希望以上建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们为您提供更具体的帮助。
举报
更多回帖
