乐鑫技术交流
直播中
席毖庸
7年用户 1037经验值
擅长:596874
私信 关注
[问答]
ESP32-LyraT V4.3烧进去dueros固件,机器一直重启,为什么?
ESP32-LyraT  V4.3烧进去dueros固件,机器一直重启,日志如下:
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6036
load:0x40078000,len:8812
load:0x40080400,len:6488
entry 0x40080734
[0;32mI (29) boot: ESP-IDF v3.2-103-g4aa1058e8-dirty 2nd stage bootloader[0m
[0;32mI (29) boot: compile time 19:58:17[0m
[0;32mI (29) boot: Enabling RNG early entropy source...[0m
[0;32mI (35) boot: SPI Speed      : 40MHz[0m
[0;32mI (39) boot: SPI Mode       : DIO[0m
[0;32mI (43) boot: SPI Flash Size : 4MB[0m
[0;32mI (47) boot: Partition Table:[0m
[0;32mI (51) boot: ## Label            Usage          Type ST Offset   Length[0m
[0;32mI (58) boot:  0 nvs              WiFi data        01 02 00009000 00006000[0m
[0;32mI (66) boot:  1 phy_init         RF data          01 01 0000f000 00001000[0m
[0;32mI (73) boot:  2 factory          factory app      00 00 00010000 00300000[0m
[0;32mI (81) boot: End of partition table[0m
[0;32mI (85) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x6decc (450252) map[0m
[0;32mI (250) esp_image: segment 1: paddr=0x0007def4 vaddr=0x3ffb0000 size=0x0211c (  8476) load[0m
[0;32mI (253) esp_image: segment 2: paddr=0x00080018 vaddr=0x400d0018 size=0x128950 (1214800) map[0m
[0;32mI (678) esp_image: segment 3: paddr=0x001a8970 vaddr=0x3ffb211c size=0x01a6c (  6764) load[0m
[0;32mI (681) esp_image: segment 4: paddr=0x001aa3e4 vaddr=0x40080000 size=0x00400 (  1024) load[0m
[0;32mI (685) esp_image: segment 5: paddr=0x001aa7ec vaddr=0x40080400 size=0x1771c ( 96028) load[0m
[0;32mI (745) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (745) boot: Disabling RNG early entropy source...[0m
[0;31mE (746) spiram: Expected 4096KiB chip but found 8192KiB chip. Bailing out..[0m
[0;31mE (753) cpu_start: Failed to init external RAM![0m
abort() was called at PC 0x4008162
这个是不支持dueros,内存太小了吗?
回帖(1)
1653339509.516700
2024-7-1 15:22:51
根据您提供的信息,您的ESP32-LyraT V4.3设备在烧录了dueros固件后一直重启。我们可以从以下几个方面来分析可能的原因:
1. **固件问题**:首先,需要确认您烧录的dueros固件是否适用于ESP32-LyraT V4.3设备。如果固件与硬件不兼容,可能会导致设备无法正常启动或频繁重启。
2. **烧录过程问题**:在烧录过程中,如果数据传输不完整或出现错误,可能会导致设备无法正常启动。请检查烧录过程中是否有任何异常,并尝试重新烧录固件。
3. **硬件问题**:设备硬件可能存在问题,如电源不稳定、焊接不良等。这可能导致设备在启动过程中出现问题,从而导致重启。检查硬件连接和焊接,确保一切正常。
4. **电源问题**:如果设备的电源不稳定或电压不符合要求,可能会导致设备无法正常启动。请检查电源供应是否稳定,并确保电压符合设备要求。
5. **软件配置问题**:在烧录固件时,可能需要进行一些软件配置,如设置正确的波特率、选择正确的烧录模式等。请检查您的配置是否正确。
6. **日志分析**:从您提供的日志来看,设备在启动过程中出现了重置(rst:0xc (SW_CPU_RESET))。这可能是由于软件或硬件问题导致的。您可以根据日志中的信息进一步分析问题所在。
综上所述,要解决设备一直重启的问题,您需要从固件、烧录过程、硬件、电源和软件配置等方面进行排查。希望这些信息对您有所帮助。
举报
更多回帖
