乐鑫技术交流
直播中
贾小龙
8年用户 1708经验值
私信 关注
[问答]
audio_player在MicroPython下无法运行怎么解决?
我们参考 IDF/ADF/MicroPython_ADF 的说明将它们进行了整合,Python 的 REPL 工作基本正常,ADF下的play_mp3_control 在脱离MicroPython的环境下单独编译、运行也正常。
但在MicroPython中,通过MicroPython_ADF下的 audio_player 模块播放mp3失败。
IDF/ADF/MicroPython均为主线最新代码。
测试的命令为:
#sdcard
import machine, os
sd = machine.SDCard(slot=1)
os.mount(sd, "/sdcard")
# Add libs in sdcard to sys.path
import sys
sys.path.append('/sdcard')
#Audio
from audio import player, recorder
def cb(state):
    print(state)
p = player(cb)
p.get_state()
p.play("file://sdcard/music-16b-2c-8000hz.mp3")
在执行到最后一步的时候出错,Log为:
I (29784) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
E (29784) gpio: gpio_install_isr_service(460): GPIO isr service already installed
I (29804) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (29804) ES8388_DRIVER: init,out:02, in:00
I (29814) AUDIO_HAL: Codec mode is 3, Ctrl:1
I (29814) ESP_AUDIO_TASK: media_ctrl_task running...,0x3fb03548
----------------------------- ESP Audio Platform -----------------------------
|                 ESP_AUDIO-v1.7.0-9-g84df87e-037bef3-09be8fe                |
|                     Compile date: Jul 20 2021-13:51:36                     |
I (29854) ESP_AUDIO_CTRL: Func:media_ctrl_create, Line:350, MEM Total:1235103 Bytes, Inter:270899 Bytes, Dram:231251 Bytes
I (29864) MP3_DECODER: MP3 init
I (29874) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3
I (29924) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0
I (29924) LYRAT_V4_3: I2S0, MCLK output by GPIO0
>>> p.get_state()
{'media_src': 0, 'err_msg': 0, 'status': 0}
I (31104) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (31104) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (31104) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffbd824
I (31114) ESP_AUDIO_TASK: It's a decoder
I (31114) ESP_AUDIO_TASK: 1.CUR IN:[IN_file],CODEC:[DEC_mp3],RESAMPLE:[48000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (31124) ESP_AUDIO_TASK: 2.Handles,IN:0x3fb03768,CODEC:0x3fb03eb8,FILTER:0x3fb044b0,OUT:0x3fb04324
I (31134) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (31144) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (31144) AUDIO_PIPELINE: link el->rb, el:0x3fb03768, tag:IN_file, rb:0x3fb04828
I (31154) AUDIO_PIPELINE: link el->rb, el:0x3fb03eb8, tag:DEC_mp3, rb:0x3fb07068
I (31164) AUDIO_PIPELINE: link el->rb, el:0x3fb044b0, tag:Audio_forge, rb:0x3fb090a8
I (31174) ESP_AUDIO_TASK: 3. Previous starting...
I (31174) AUDIO_ELEMENT: [IN_file-0x3fb03768] Element task created
I (31184) AUDIO_ELEMENT: [IN_file] AEL_MSG_CMD_RESUME,state:1
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x400dfaf0  PS      : 0x00060230  A0      : 0x800e00e4  A1      : 0x3ffcf810
0x400dfaf0: gc_alloc at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/gc.c:460
A2      : 0x0000001f  A3      : 0x00000000  A4      : 0x00000001  A5      : 0x00000001
A6      : 0x000000fe  A7      : 0x00000001  A8      : 0x800dfaf0  A9      : 0x3ffcf7f0
A10     : 0x00000000  A11     : 0x00060c23  A12     : 0x00060c20  A13     : 0x00060c23
A14     : 0x000000fe  A15     : 0x00000001  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000008  LBEG    : 0x4008cea5  LEND    : 0x4008ceb5  LCOUNT  : 0xfffffff8
0x4008cea5: strlen at /builds/idf/crosstool-NG/.build/HOST-x86_64-apple-darwin12/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:84
0x4008ceb5: strlen at /builds/idf/crosstool-NG/.build/HOST-x86_64-apple-darwin12/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:96
Backtrace:0x400dfaed:0x3ffcf810 0x400e00e1:0x3ffcf830 0x400e545d:0x3ffcf850 0x400e58cf:0x3ffcf870 0x4012fa8e:0x3ffcf890 0x40171146:0x3ffcf950 0x40171693:0x3ffcf980 0x401717a6:0x3ffcf9a0 0x4017265d:0x3ffcf9d0 0x401718ac:0x3ffcfa10
0x400dfaed: gc_alloc at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/gc.c:460
0x400e00e1: m_malloc at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/malloc.c:86
0x400e545d: mp_obj_new_str_copy at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/objstr.c:2029
0x400e58cf: mp_obj_new_str at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/objstr.c:2095
(inlined by) mp_obj_new_str at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/lv_micropython/py/objstr.c:2088
0x4012fa8e: _vfs_open at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/micropython_adf/mod/vfs_stream.c:120
0x40171146: audio_element_process_init at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/components/audio_pipeline/audio_element.c:175
0x40171693: audio_element_on_cmd_resume at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/components/audio_pipeline/audio_element.c:279
0x401717a6: audio_element_on_cmd at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/components/audio_pipeline/audio_element.c:320 (discriminator 13)
0x4017265d: audio_event_iface_waiting_cmd_msg at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/components/audio_pipeline/audio_event_iface.c:247
0x401718ac: audio_element_task at /Volumes/Linux/Projects/Esp32Proj/adf_integration/yangtze/components/esp-adf/components/audio_pipeline/audio_element.c:473
根据Log查看 gc.c:460 行为:
459    // check if GC is locked
460    if (MP_STATE_THREAD(gc_lock_depth) > 0) {
461        return NULL;
462    }
因为中间的 esp-adf-libs 部分贵司只提供了库文件,并未公开源码,因此不是很明确此处为什么会出错及该如何解决,还望给出建议
回帖(1)
李鸿洋
2024-6-28 17:00:57
根据您提供的信息,您在MicroPython环境下使用audio_player模块播放MP3文件时遇到了问题。以下是一些建议来解决这个问题:
1. 确保您的MicroPython固件和ESP-ADF库是最新版本。这可以通过检查官方GitHub仓库来完成。
2. 检查您的MP3文件是否正确存储在SD卡上,并且文件路径正确。您可以使用以下代码列出SD卡上的文件:
```python
import os
def list_files(path):
    files = os.listdir(path)
    for file in files:
        print(file)
list_files("/sdcard")
3. 确保您的audio_player模块已经正确导入。您可以尝试重新导入模块,如下所示:
```python
4. 检查您的回调函数(cb)是否正确定义。确保它接受一个参数,如下所示:
```python
def cb(event):
    if event == player.EVENT_PLAYBACK_FINISHED:
        print("Playback finished")
5. 确保您已经正确初始化了音频播放器,并设置了回调函数。例如:
```python
player = player.Player()
player.set_callback(cb)
6. 确保您已经正确挂载了SD卡,并设置了正确的路径。例如:
```python
import machine
import os
7. 最后,尝试使用player模块播放MP3文件。例如:
```python
player.play("/sdcard/your_audio_file.mp3")
如果问题仍然存在,请提供更多详细信息,例如错误消息或日志,以便我们能够更好地帮助您解决问题。
举报
更多回帖
