D:/iot/esp32/sdk/esp-adf/components/audio_hal/driver/es8156/es8156.c: In func
tion 'es8156_codec_init':
D:/iot/esp32/sdk/esp-adf/components/audio_hal/driver/es8156/es8156.c:43:22: error: 'BOARD_PA_GAIN' undeclared (first use in this function)
.board_pa_gain = BOARD_PA_GAIN,
D:/iot/esp32/sdk/esp-adf/components/audio_hal/driver/es8156/es8156.c:175:41: note: in expansion of macro 'ES8156_DAC_VOL_CFG_DEFAULT'
codec_dac_volume_config_t vol_cfg = ES8156_DAC_VOL_CFG_DEFAULT();
D:/iot/esp32/sdk/esp-adf/components/audio_hal/driver/es8156/es8156.c:43:22: note: each undeclared identifier is reported only once for each function it appears in
[24/150] Building C object esp-idf/esp-adf-libs/CMakeFiles/__idf_esp-adf-libs.dir/esp_codec/audio_forge.c.obj
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
D:iotesp32sdkesp-adfprojecta2dp_stream_with_tp123_copy>
