乐鑫技术交流
直播中
那些年儿ing
13年用户 1383经验值
擅长:84784
私信 关注
[问答]
ESP32-C3运行pipeline_play_mp3_with_dac_or_pdm例程看门狗超时的原因?怎么处理?
esp32-c3-wroom-02模组
运行官方pipeline_play_mp3_with_dac_or_pdm例程,配置对应芯片开发板,配置pwm左右通道引脚分别为GPIO0、GPIO3,此外无任何更改,结果烧录后运行异常:看门狗超时。
运行log如下:
[Codebox]ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xd (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x16bc
load:0x403cc710,len:0x930
load:0x403ce710,len:0x2d28
SHA-256 comparison failed:
Calculated: 62f3b81659a66cce95713413127eab3f0f599feb9c44555c28705762b8655f57
Expected: adef8716c33cabbc299cb10cfe7234c94c96ecd6e85f10e05a6f5d6f60bdc295
Attempting to boot anyway...
entry 0x403cc710
I (48) boot: ESP-IDF v4.4.3-dirty 2nd stage bootloader
I (49) boot: compile time 11:06:11
I (49) boot: chip revision: 3
I (51) boot.esp32c3: SPI Speed      : 80MHz
I (56) boot.esp32c3: SPI Mode       : DIO
I (60) boot.esp32c3: SPI Flash Size : 4MB
I (65) boot: Enabling RNG early entropy source...
I (70) boot: Partition Table:
I (74) boot: ## Label            Usage          Type ST Offset   Length
I (81) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (89) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (96) boot:  2 factory          factory app      00 00 00010000 00100000
I (104) boot: End of partition table
I (108) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=1f6c0h (128704) map
I (137) esp_image: segment 1: paddr=0002f6e8 vaddr=3fc8b800 size=00930h (  2352) load
I (137) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=2360ch (144908) map
I (165) esp_image: segment 3: paddr=00053634 vaddr=3fc8c130 size=00ad4h (  2772) load
I (166) esp_image: segment 4: paddr=00054110 vaddr=40380000 size=0b7e4h ( 47076) load
I (179) esp_image: segment 5: paddr=0005f8fc vaddr=50000010 size=00010h (    16) load
I (183) boot: Loaded app from partition at offset 0x10000
I (185) boot: Disabling RNG early entropy source...
I (202) cpu_start: Pro cpu up.
I (211) cpu_start: Pro cpu start user code
I (211) cpu_start: cpu freq: 160000000
I (211) cpu_start: Application information:
I (214) cpu_start: Project name:     play_mp3_pwm_or_dac
I (220) cpu_start: App version:      1
I (224) cpu_start: Compile time:     Jun 20 2023 11:16:33
I (230) cpu_start: ELF file SHA256:  09b49e4cdeb57ac4...
I (236) cpu_start: ESP-IDF:          v4.4.3-dirty
I (242) heap_init: Initializing. RAM available for dynamic allocation:
I (249) heap_init: At 3FC8DC00 len 0004EB10 (314 KiB): DRAM
I (255) heap_init: At 3FCDC710 len 00002950 (10 KiB): STACK/DRAM
I (262) heap_init: At 50000020 len 00001FE0 (7 KiB): RTCRAM
I (268) spi_flash: detected chip: generic
I (273) spi_flash: flash io: dio
I (277) sleep: Configure to isolate all GPIO pins in sleep state
I (283) sleep: Enable automatic switching of GPIO sleep configuration
I (290) cpu_start: Starting scheduler.
I (295) MP3_PWM_DAC_EXAMPLE: [ 1 ] Periph init
I (295) MP3_PWM_DAC_EXAMPLE: [ 2 ] Create audio pipeline for playback
I (305) MP3_PWM_DAC_EXAMPLE: [2.1] Create output stream to write data to codec chip
I (315) MP3_PWM_DAC_EXAMPLE: [2.2] Create wav decoder to decode wav file
I (315) MP3_PWM_DAC_EXAMPLE: [2.3] Register all elements to audio pipeline
I (325) MP3_PWM_DAC_EXAMPLE: [2.4] Link it together [mp3_music_read_cb]-->mp3_decoder-->output_stream-->[pa_chip]
I (335) MP3_PWM_DAC_EXAMPLE: [ 3 ] Set up  event listener
I (345) MP3_PWM_DAC_EXAMPLE: [3.1] Listening event from all elements of pipeline
I (355) MP3_PWM_DAC_EXAMPLE: [3.2] Listening event from peripherals
I (355) MP3_PWM_DAC_EXAMPLE: [ 4 ] Start audio_pipeline
I (365) MP3_PWM_DAC_EXAMPLE: [ 5 ] Listen for all pipeline events
I (375) MP3_PWM_DAC_EXAMPLE: [ * ] Receive music info from mp3 decoder, sample_rates=44100, bits=16, ch=2
E (5295) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (5295) task_wdt:  - IDLE (CPU 0)
E (5295) task_wdt: Tasks currently running:
E (5295) task_wdt: CPU 0: output
E (10295) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (10295) task_wdt:  - IDLE (CPU 0)
E (10295) task_wdt: Tasks currently running:
E (10295) task_wdt: CPU 0: output[/Codebox]
请大佬帮忙看下为什么esp32-c3不能运行这个例程?
回帖(1)
孙成红
2024-6-28 16:53:01
以下是一些建议来解决这个问题:
1. **检查固件烧录**:首先,请确保您烧录的固件是正确的版本,适用于ESP32-C3。您可以尝试重新烧录固件,以排除烧录过程中可能出现的错误。
2. **检查SPI Flash**:看门狗超时可能与SPI Flash有关。请检查SPI Flash是否正常工作,以及其与ESP32-C3的连接是否稳定。
3. **检查GPIO配置**:确保GPIO0和GPIO3的配置正确,没有其他干扰。您可以尝试使用其他GPIO引脚,看看问题是否仍然存在。
4. **检查电源**:确保ESP32-C3的电源稳定,电压在正常范围内。不稳定的电源可能会影响看门狗定时器的正常工作。
5. **检查看门狗配置**:检查看门狗定时器的配置,确保其设置正确。您可以在代码中调整看门狗定时器的超时时间,以查看是否能够解决问题。
6. **检查代码逻辑**:仔细检查pipeline_play_mp3_with_dac_or_pdm例程的代码,确保没有死循环或其他可能导致看门狗超时的逻辑错误。
7. **查看错误日志**:您提供的日志显示SHA-256比较失败,这可能意味着烧录的固件文件损坏或不完整。请尝试重新下载固件文件并重新烧录。
举报
更多回帖
