乐鑫技术交流
直播中
张敏
8年用户 1664经验值
私信 关注
[问答]
chip-tool pairing ble-wifi给matter设备配网异常的原因?
在使用chip-tool pairing ble-wifi 0x7283 SSID PASSCODE 20202021 3840给matter 设备配网的时候,
出现如下错误,wifi名字和密码已经设置到matter设备的,看着是后面还有些配置没有成功
[1688103497.794157][22124:22126] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1688103498.919658][22124:22126] CHIP:DIS: Checking node lookup status after 45001 ms
[1688103498.919684][22124:22126] CHIP:DIS: OperationalSessionSetup[1:0000000000007283]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1688103498.919689][22124:22126] CHIP:CTL: Device connection failed. Error src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1688103498.919700][22124:22126] CHIP:CTL: Error on commissioning step 'FindOperational': 'src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout'
[1688103498.919704][22124:22126] CHIP:CTL: Failed to perform commissioning step 20
[1688103498.919708][22124:22126] CHIP:CTL: Going from commissioning step 'FindOperational' with lastErr = 'src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout' -> 'Cleanup'
[1688103498.919715][22124:22126] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout'
[1688103498.919719][22124:22126] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1688103498.919726][22124:22126] CHIP:TOO: Device commissioning Failure: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1688103498.920293][22124:22124] CHIP:CTL: Shutting down the commissioner
[1688103498.920318][22124:22124] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1688103498.920340][22124:22124] CHIP:DIS: Closing all BLE connections
[1688103498.920346][22124:22124] CHIP:IN: Clearing BLE pending packets.
[1688103498.921023][22124:22124] CHIP:BLE: Auto-closing end point's BLE connection.
[1688103498.921031][22124:22124] CHIP:DL: Closing BLE GATT connection (con 0x7effac0ec930)
[1688103498.921135][22124:22125] CHIP:DL: BluezDisconnect peer=D2:87:93:87:CD:A7
[1688103501.596697][22124:22124] CHIP:IN: SecureSession[0x7effa40dd600]: MarkForEviction Type:1 LSID:38471
[1688103501.596760][22124:22124] CHIP:SC: SecureSession[0x7effa40dd600]: Moving from state 'kActive' --> 'kPendingEviction'
[1688103501.596805][22124:22124] CHIP:IN: SecureSession[0x7effa40dd600]: Released - Type:1 LSID:38471
[1688103501.596822][22124:22124] CHIP:CTL: Shutting down the controller
[1688103501.596833][22124:22124] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1688103501.596841][22124:22124] CHIP:FP: Forgetting fabric 0x1
[1688103501.596909][22124:22124] CHIP:TS: Pending Last Known Good Time: 2023-06-21T21:51:50
[1688103501.596990][22124:22124] CHIP:TS: Previous Last Known Good Time: 2023-06-21T21:51:50
[1688103501.597044][22124:22124] CHIP:TS: Reverted Last Known Good Time to previous value
[1688103501.597074][22124:22124] CHIP:CTL: Shutting down the commissioner
[1688103501.597082][22124:22124] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1688103501.597091][22124:22124] CHIP:CTL: Shutting down the controller
[1688103501.597097][22124:22124] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1688103501.597174][22124:22124] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1688103501.597393][22124:22124] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1688103501.597422][22124:22124] CHIP:FP: Shutting down FabricTable
[1688103501.597427][22124:22124] CHIP:TS: Pending Last Known Good Time: 2023-06-21T21:51:50
[1688103501.597446][22124:22124] CHIP:TS: Previous Last Known Good Time: 2023-06-21T21:51:50
[1688103501.597449][22124:22124] CHIP:TS: Reverted Last Known Good Time to previous value
[1688103501.597578][22124:22124] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-m3hrN6)
[1688103501.597881][22124:22124] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1688103501.597910][22124:22124] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1688103501.597945][22124:22124] CHIP:DL: Inet Layer shutdown
[1688103501.597950][22124:22124] CHIP:DL: BLE shutdown
[1688103501.609307][22124:22124] CHIP:DL: System Layer shutdown
[1688103501.610224][22124:22124] CHIP:TOO: Run command failure: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
回帖(1)
h1654155272.9717
2024-6-27 17:04:13
在这种情况下,我们需要逐步分析可能导致配网异常的原因。以下是一些可能的原因和相应的解决方案:
1. **设备兼容性问题**:确保你的matter设备和chip-tool都支持BLE-WiFi配网。如果设备或工具不支持,可能导致配网失败。
2. **SSID和密码格式问题**:检查SSID和密码是否符合要求。例如,SSID不能包含特殊字符,密码长度和复杂性也需要满足要求。
3. **配网命令格式问题**:确保你使用的配网命令格式正确。根据你提供的信息,命令格式应该是:`chip-tool pairing ble-wifi < discriminator>`。请检查命令中的参数是否正确。
4. **设备距离问题**:确保你的matter设备和chip-tool之间的距离足够近,以便BLE信号可以正常传输。
5. **设备电源问题**:检查matter设备是否有足够的电量进行配网操作。
6. **网络环境问题**:确保你的WiFi网络环境稳定,没有其他干扰因素。
7. **Matter设备固件问题**:检查matter设备的固件是否为最新版本,如果不是,请更新固件。
8. **chip-tool版本问题**:确保你使用的chip-tool是最新版本,如果不是,请更新到最新版本。
9. **日志信息分析**:根据你提供的日志信息,可以看到"operational discovery failed",这可能意味着在配网过程中,设备之间的通信出现了问题。需要进一步检查设备之间的通信是否正常。
10. **尝试重新配网**:如果以上步骤都无法解决问题,可以尝试重新执行配网操作,有时候问题可能是暂时性的。
通过以上步骤,你可以逐步排查并解决配网异常的问题。如果问题仍然存在,建议联系设备制造商或chip-tool的开发者寻求技术支持。
举报
更多回帖
