乐鑫技术交流
直播中
那些年儿ing
13年用户 1383经验值
擅长:84784
私信 关注
[问答]
VSCode IDF插件升级到0.6.0后Monitor无法串口打印的原因?
VSCode IDF插件升级到0.6.0后Monitor无法串口打印,退回到0.5.1后可正常打印,第一次点击出现如下的提示:
  • Windows PowerShell
  • 版权所有 (C) Microsoft Corporation。保留所有权利。
  • 尝试新的跨平台 PowerShell https://aka.ms/pscore6
  • PS D:SelfSoftwareESP32UserProjectwear_levelling> $Env:Path = "
  • >> $Env:IDF_PATH = "
  • PS D:SelfSoftwareESP32UserProjectwear_levelling> $Env:IDF_TARGET = "
  • >> $Env:PYTHON = "
  • PS D:SelfSoftwareESP32UserProjectwear_levelling> $Env:IDF_PYTHON_ENV_PATH = "
  • >> cls
  • >> d:SelfSoftwareESP32ESP_IDFToolspython_envidf4.3_py3.9_envScriptspython.exe d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py -p COM3 monitor
第二次点击出现如下的提示:
  • PS D:SelfSoftwareESP32UserProjectwear_levelling> d:SelfSoftwareESP32ESP_IDFToolspython_envidf4.3_py3.9_envScriptspython.exe d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py -p COM3 monitor
  • Traceback (most recent call last):
  •   File "d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py", line 805, in
  •     main()
  •   File "d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py", line 720, in main
  •     checks_output = check_environment()
  •   File "d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py", line 77, in check_environment
  •     debug_print_idf_version()
  •   File "d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf.py", line 126, in debug_print_idf_version
  •     version = idf_version()
  •   File "d:SelfSoftwareESP32IDF_Masteresp-idftoolsidf_py_actionstools.py", line 54, in idf_version
  •     version = subprocess.check_output([
  •   File "C:UsersZLFAppDataLocalProgramsPythonPython39libsubprocess.py", line 420, in check_output
  •     return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  •   File "C:UsersZLFAppDataLocalProgramsPythonPython39libsubprocess.py", line 501, in run
  •     with Popen(*popenargs, **kwargs) as process:
  •   File "C:UsersZLFAppDataLocalProgramsPythonPython39libsubprocess.py", line 947, in __init__
  •     self._execute_child(args, executable, preexec_fn, close_fds,
  •   File "C:UsersZLFAppDataLocalProgramsPythonPython39libsubprocess.py", line 1416, in _execute_child
  •     hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
  • FileNotFoundError: [WinError 2] 系统找不到指定的文件。
回帖(1)
杨海清
2024-6-24 17:02:20
这可能是由于以下几个原因:
1. **兼容性问题**:新版本的IDF插件可能存在一些兼容性问题,导致在您的系统上无法正常工作。这可能是由于新版本中的某些更改与您的系统环境不兼容。
2. **配置问题**:升级到0.6.0版本后,可能需要重新配置一些环境变量或设置。从您提供的Windows PowerShell输出来看,`$Env:Path`、`$Env:IDF_PATH`、`$Env:IDF_TARGET`和`$Env:PYTHON`等环境变量都被设置为空。这可能是导致Monitor无法串口打印的原因。
3. **依赖问题**:新版本的IDF插件可能依赖于某些新的软件或库,而这些依赖在您的系统上尚未安装或配置。这可能导致插件无法正常运行。
为了解决这个问题,您可以尝试以下步骤:
1. **检查环境变量**:确保`$Env:Path`、`$Env:IDF_PATH`、`$Env:IDF_TARGET`和`$Env:PYTHON`等环境变量已正确设置。您可以在VSCode的设置中查找并修改这些环境变量。
2. **检查依赖**:确保您的系统上已安装并配置了所有必要的依赖项。您可以查阅IDF插件的文档,了解新版本所需的依赖,并确保它们已正确安装。
3. **查看日志和错误信息**:在VSCode的输出窗口或控制台中查看与IDF插件相关的日志和错误信息。这可能有助于您找到导致问题的具体原因。
举报
更多回帖
