看了官方的说明文档,v4.2采用Python3,所以将Python改为了python3.6,从github上下载了zip包,解压到~/esp目录下,分别完成了install.sh和export.sh结果都成功,分别如下:
Code:
Select all
eric@eric-virtual-machine:~/esp/esp-idf$ sudo ./install.sh[sudo] password for eric: Detec
ting the Python interpreterChecking "python" ...Python 3.6.9"python" has been detectedInstalling ESP-IDF toolsInstalling tools: xtensa-esp32-elf, xtensa-esp32s2-elf, esp32ulp-elf, esp32s2ulp-elf, openocd-esp32Skipping
xtensa-esp32-elf@esp-2020r3-8.4.0 (already installed)Skipping
xtensa-esp32s2-elf@esp-2020r3-8.4.0 (already installed)Skipping
esp32ulp-elf@2.28.51-esp-20191205 (already installed)Skipping
esp32s2ulp-elf@2.28.51-esp-20191205 (already installed)Skipping
openocd-esp32@v0.10.0-esp32-20200709 (already installed)Installing Python environment and packagesfatal: not a git repository (or any of the parent directories): .gitWARNING: Git describe was unsuccessul: Command '['git', 'describe']' returned non-zero exit status 128.Installing Python packages from /home/eric/esp/esp-idf/requirements.txtWARNING: The directory '/home/eric/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.Ignoring python-socketio: markers 'python_version <= "2.7"' don't match your environmentIgnoring None: markers 'sys_platform == "win32"' don't match your environmentRequirement already satisfied: setuptools>=21 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 4)) (54.1.2)Requirement already satisfied: click>=5.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 8)) (7.1.2)Requirement already satisfied: pyserial>=3.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 9)) (3.5)Requirement already satisfied: future>=0.15.2 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 10)) (0.18.2)Requirement already satisfied: cryptography>=2.1.4 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 11)) (3.4.7)Requirement already satisfied: pyparsing<2.4.0,>=2.0.3 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 12)) (2.3.1)Requirement already satisfied: pyelftools>=0.22 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 13)) (0.27)Requirement already satisfied: gdbgui==0.13.2.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 15)) (0.13.2.0)Requirement already satisfied: pygdbmi<=0.9.0.2 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 18)) (0.9.0.2)Requirement already satisfied: reedsolo<=1.5.4,>=1.5.3 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 23)) (1.5.4)Requirement already satisfied: bitstring>=3.1.6 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 24)) (3.1.7)Requirement already satisfied: ecdsa>=0.16.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from -r /home/eric/esp/esp-idf/requirements.txt (line 25)) (0.16.1)Requirement already satisfied: gevent<2.0,>=1.2.2 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.5.0)Requirement already satisfied: Flask-SocketIO<3.0,>=2.9 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (2.9.6)Requirement already satisfied: Flask<1.0,>=0.12.2 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (0.12.5)Requirement already satisfied: Flask-Compress<2.0,>=1.4.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.9.0)Requirement already satisfied: Pygments<3.0,>=2.2.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (2.8.1)Requirement already satisfied: cffi>=1.12 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from cryptography>=2.1.4->-r /home/eric/esp/esp-idf/requirements.txt (line 11)) (1.14.5)Requirement already satisfied: six>=1.9.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from ecdsa>=0.16.0->-r /home/eric/esp/esp-idf/requirements.txt (line 25)) (1.15.0)Requirement already satisfied: pycparser in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from cffi>=1.12->cryptography>=2.1.4->-r /home/eric/esp/esp-idf/requirements.txt (line 11)) (2.20)Requirement already satisfied: itsdangerous>=0.21 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.1.0)Requirement already satisfied: Jinja2>=2.4 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (2.11.3)Requirement already satisfied: Werkzeug<1.0,>=0.7 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (0.16.1)Requirement already satisfied: brotli in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Flask-Compress<2.0,>=1.4.0->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.0.9)Requirement already satisfied: python-socketio>=1.6.1 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Flask-SocketIO<3.0,>=2.9->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (5.1.0)Requirement already satisfied: greenlet>=0.4.14 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from gevent<2.0,>=1.2.2->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.0.0)Requirement already satisfied: MarkupSafe>=0.23 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from Jinja2>=2.4->Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (1.1.1)Requirement already satisfied: bidict>=0.21.0 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from python-socketio>=1.6.1->Flask-SocketIO<3.0,>=2.9->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (0.21.2)Requirement already satisfied: python-engineio>=4 in /home/eric/.espressif/python_env/idf4.2_py3.6_env/lib/python3.6/site-packages (from python-socketio>=1.6.1->Flask-SocketIO<3.0,>=2.9->gdbgui==0.13.2.0->-r /home/eric/esp/esp-idf/requirements.txt (line 15)) (4.0.1)All done! You can now run: . ./export.sh
Code:
Select all
eric@eric-virtual-machine:~/esp/esp-idf$ . ./export.shDetecting the Python interpreterChecking "python" ...Python 3.6.9"python" has been detectedAdding ESP-IDF tools to PATH...fatal: not a git repository (or any of the parent directories): .gitWARNING: Git describe was unsuccessul: Command '['git', 'describe']' returned non-zero exit status 128.Using Python interpreter in /home/eric/.espressif/python_env/idf4.2_py3.6_env/bin/pythonChecking if Python packages are up to date...Python requirements from /home/eric/esp/esp-idf/requirements.txt are satisfied.Added the following directories to PATH: /home/eric/esp/esp-idf/components/esptool_py/esptool /home/eric/esp/esp-idf/components/espcoredump /home/eric/esp/esp-idf/components/partition_table /home/eric/esp/esp-idf/components/app_update /home/eric/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin /home/eric/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin /home/eric/.espressif/tools/esp32ulp-elf/2.28.51-esp-20191205/esp32ulp-elf-binutils/bin /home/eric/.espressif/tools/esp32s2ulp-elf/2.28.51-esp-20191205/esp32s2ulp-elf-binutils/bin /home/eric/.espressif/tools/openocd-esp32/v0.10.0-esp32-20200709/openocd-esp32/bin /home/eric/.espressif/python_env/idf4.2_py3.6_env/binDone! You can now compile ESP-IDF projects.Go to the project directory and run: idf.py build
然而,在实例项目的目录下,使用idf.py报错,报错信息如下:Code:
Select all
eric@eric-virtual-machine:~/esp/esp-idf$ idf.pyTraceback (most recent call last): File "/home/eric/esp/esp-idf/tools/idf.py", line 45, in from idf_py_actions.tools import (executable_exists, idf_version, merge_action_lists, realpath) # noqa: E402 File "/home/eric/esp/esp-idf/tools/idf_py_actions/tools.py", line 1, in import clickModuleNotFoundError: No module named 'click'
请问如何解决呢?不胜感激!
