使用arduino,用的安信可的
开发板包,选择esp32c3 dev moudle,下载后一直reboot(同样的程序在esp32上测试没有问题)。串口信息如下:
0ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40382b44
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1484
load:0x403ce000,len:0xb80
load:0x403d0000,len:0x2ba4
SHA-256 comparison failed:
Calculated: ab48a4942e2c1f450cd572b1fb4b64f9e62e8b100edab04184d7d951c303f782
Expected: 02adf0d2e33022877265b2418512145185fb8a373ec0addfeef9f2dcb34cad28
Attemp
ting to boot anyway...
entry 0x403ce000
I (53) boot: ESP-IDF v4.4-dev-960-gcf457d412 2nd stage bootloader
I (54) boot: compile time 12:10:59
I (54) boot: chip revision: 3
I (54) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (60) qio_mode: Enabling default flash chip QIO
I (64) boot.esp32c3: SPI Speed : 80MHz
I (68) boot.esp32c3: SPI Mode : QIO
I (72) boot.esp32c3: SPI Flash Size : 4MB
I (76) boot: Enabling RNG early entropy source...
I (80) boot: Partition Table:
I (83) boot: ## Label Usage Type ST Offset Length
I (89) boot: 0 nvs WiFi data 01 02 00009000 00005000
I (96) boot: 1 otadata OTA data 01 00 0000e000 00002000
I (102) boot: 2 app0 OTA app 00 10 00010000 00140000
I (109) boot: 3 app1 OTA app 00 11 00150000 00140000
I (115) boot: 4 spiffs Unknown data 01 82 00290000 00170000
I (122) boot: End of partition table
I (125) boot_comm: chip revision: 3, min. application chip revision: 0
I (131) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=09920h ( 39200) map
I (144) esp_image: segment 1: paddr=00019948 vaddr=3fc8a800 size=01638h ( 5688) load
I (147) esp_image: segment 2: paddr=0001af88 vaddr=40380000 size=05090h ( 20624) load
I (157) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=24ffch (151548) map
I (182) esp_image: segment 4: paddr=00045024 vaddr=40385090 size=05700h ( 22272) load
I (186) esp_image: segment 5: paddr=0004a72c vaddr=50000000 size=00010h ( 16) load
I (189) boot: Loaded app from partition at offset 0x10000
I (191) boot: Disabling RNG early entropy source...
[138481][D][esp32-hal-cpu.c:211] setCpuFrequencyMhz(): PLL: 480 / 6 = 80 Mhz, APB: 80000000 Hz
