Execu
ting task in folder ESP32Test02: C:UsersAdministrator.platformiopenvScriptsplatformio.exe run <
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
-------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION:
https://docs.platformio.org/page/boards ... 32dev.html
PLATFORM: Espressif 32 (3.3.2) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-espidf 3.40300.0 (4.3.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
Reading CMake configuration...
Generating assembly for certificate bundle...
CMake Error at C:/Users/Administrator/.platformio/packages/framework-espidf/tools/cmake/scripts/data_file_embed_asm.cmake:26 (file):
file failed to open for reading (No such file or directory):
E:ESP32ESP32Test02.piobuildesp32devx509_crt_bundle
*** Error 1
LDF: Library Dependency Finder ->
http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 0 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Archiving .piobuildesp32devesp-idflwipliblwip.a
*** [.piobuildesp32dev.piobuildesp32devx509_crt_bundle.o] Source `.piobuildesp32devx509_crt_bundle.S' not found, needed by target `.piobuildesp32dev.piobuildesp32devx509_crt_bundle.o'.
Indexing .piobuildesp32devesp-idflwipliblwip.a
================================================= [FAILED] Took 9.15 seconds =================================================
终端进程“C:UsersAdministrator.platformiopenvScriptsplatformio.exe 'run'”已终止,退出代码: 1。
终端将被任务重用,按任意键关闭。
