乐鑫技术交流
直播中
李晨灵
7年用户 1455经验值
私信 关注
[问答]
ESP32外挂W5500以太网,如何设置静态IP地址呢?
  • #define INIT_SPI_ETH_MODULE_CONFIG(eth_module_config, num)
  •     do
  •         eth_module_config.spi_cs_gpio = CONFIG_ETH_SPI_CS##num##_GPIO;
  •         eth_module_config.int_gpio = CONFIG_ETH_SPI_INT##num##_GPIO;
  •         eth_module_config.phy_reset_gpio = CONFIG_ETH_SPI_PHY_RST##num##_GPIO;
  •         eth_module_config.phy_addr = CONFIG_ETH_SPI_PHY_ADDR##num;
  •     } while (0)
  • typedef struct
  •     uint8_t spi_cs_gpio;
  •     uint8_t int_gpio;
  •     int8_t phy_reset_gpio;
  •     uint8_t phy_addr;
  • } spi_eth_module_config_t;
  • esp_ip4_addr_t ip_tmp;
  • /** Event handler for Ethernet events */
  • static void eth_event_handler(void *arg, esp_event_base_t event_base,
  •                               int32_t event_id, void *event_data)
  •     uint8_t mac_addr[6 = {0};
  •     /* we can get the ethernet driver handle from event data */
  •     esp_eth_handle_t eth_handle = *(esp_eth_handle_t *)event_data;
  •     switch (event_id)
  •     case ETHERNET_EVENT_CONNECTED:
  •         esp_eth_ioctl(eth_handle, ETH_CMD_G_MAC_ADDR, mac_addr);
  •         ESP_LOGI(TAG, "Ethernet Link Up");
  •         ESP_LOGI(TAG, "Ethernet HW Addr %02x:%02x:%02x:%02x:%02x:%02x",
  •                  mac_addr[0, mac_addr[1, mac_addr[2, mac_addr[3, mac_addr[4, mac_addr[5);
  •         break;
  •     case ETHERNET_EVENT_DISCONNECTED:
  •         ESP_LOGI(TAG, "Ethernet Link Down");
  •         break;
  •     case ETHERNET_EVENT_START:
  •         ESP_LOGI(TAG, "Ethernet Started");
  •         break;
  •     case ETHERNET_EVENT_STOP:
  •         ESP_LOGI(TAG, "Ethernet Stopped");
  •         break;
  •     default:
  •         break;
  • /** Event handler for IP_EVENT_ETH_GOT_IP */
  • static void got_ip_event_handler(void *arg, esp_event_base_t event_base,
  •     ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
  •     const esp_netif_ip_info_t *ip_info = &event->ip_info;
  •     ESP_LOGI(TAG, "Ethernet Got IP Address");
  •     ESP_LOGI(TAG, "ETHIP:" IPSTR, IP2STR(&ip_info->ip));
  •     ip_tmp = ip_info->ip;
  •     ESP_LOGI(TAG, "ETHMASK:" IPSTR, IP2STR(&ip_info->netmask));
  •     ESP_LOGI(TAG, "ETHGW:" IPSTR, IP2STR(&ip_info->gw));
  •     //  http_init();
  • void bsp_ethernet_init(void)
  •     ESP_LOGI(TAG, "%s", __func__);
  •     // Initialize TCP/IP network interface (should be called only once in application)
  •     ESP_ERROR_CHECK(esp_netif_init());
  •     // Create instance(s) of esp-netif for SPI Ethernet(s)
  •     esp_netif_inherent_config_t esp_netif_config = ESP_NETIF_INHERENT_DEFAULT_ETH();
  •     esp_netif_config_t cfg_spi = {
  •         .base = &esp_netif_config,
  •         .stack = ESP_NETIF_NETSTACK_DEFAULT_ETH};
  •     esp_netif_t *eth_netif_spi = NULL;
  •     esp_netif_config.if_key = IF_KEY_STR;
  •     esp_netif_config.if_desc = IF_DESC_STR;
  •     esp_netif_config.route_prio = 30;
  •     eth_netif_spi = esp_netif_new(&cfg_spi);
  •     //设置静态IP地址
  •     esp_netif_dhcps_stop(eth_netif_spi);
  •     char *ip = "192.168.1.168";
  •     char *gateway = "192.168.1.1";
  •     char *netmask = "255.255.0.0";
  •     esp_netif_ip_info_t ip_info;
  •     memset(&ip_info, 0, sizeof(esp_netif_ip_info_t));
  •     ip_info.ip.addr = esp_ip4addr_aton((const char *)ip);
  •     ip_info.ip.addr = esp_ip4addr_aton((const char *)gateway);
  •     ip_info.ip.addr = esp_ip4addr_aton((const char *)netmask);
  •     if (esp_netif_set_ip_info(eth_netif_spi, &ip_info))
  •         ESP_LOGI(TAG, "Set static IP OK");
  •     else
  •         ESP_LOGI(TAG, "Set static IP error");
  •     // Init MAC and PHY configs to default
  •     eth_mac_config_t mac_config_spi = ETH_MAC_DEFAULT_CONFIG();
  •     eth_phy_config_t phy_config_spi = ETH_PHY_DEFAULT_CONFIG();
  •     // Install GPIO ISR handler to be able to service SPI Eth modlues interrupts
  •     gpio_install_isr_service(0);
  •     // Init SPI bus
  •     spi_device_handle_t spi_handle = NULL;
  •     spi_bus_config_t buscfg = {
  •         .miso_io_num = CONFIG_ETH_SPI_MISO_GPIO,
  •         .mosi_io_num = CONFIG_ETH_SPI_MOSI_GPIO,
  •         .sclk_io_num = CONFIG_ETH_SPI_SCLK_GPIO,
  •         .quadwp_io_num = -1,
  •         .quadhd_io_num = -1,
  •     ESP_ERROR_CHECK(spi_bus_initialize(CONFIG_ETH_SPI_HOST, &buscfg, SPI_DMA_CH_AUTO));
  •     // Init specific SPI Ethernet module configuration from Kconfig (CS GPIO, Interrupt GPIO, etc.)
  •     spi_eth_module_config_t spi_eth_module_config;
  •     INIT_SPI_ETH_MODULE_CONFIG(spi_eth_module_config, 0);
  •     // Configure SPI interface and Ethernet driver for specific SPI module
  •     esp_eth_mac_t *mac_spi;
  •     esp_eth_phy_t *phy_spi;
  •     esp_eth_handle_t eth_handle_spi = NULL;
  •     spi_device_interface_config_t devcfg = {
  •         .command_bits = 16, // Actually it's the address phase in W5500 SPI frame
  •         .address_bits = 8,  // Actually it's the control phase in W5500 SPI frame
  •         .mode = 0,
  •         .clock_speed_hz = CONFIG_ETH_SPI_CLOCK_MHZ * 1000 * 1000,
  •         .queue_size = 20};
  •     // Set SPI module Chip Select GPIO
  •     devcfg.spics_io_num = spi_eth_module_config.spi_cs_gpio;
  •     ESP_ERROR_CHECK(spi_bus_add_device(CONFIG_ETH_SPI_HOST, &devcfg, &spi_handle));
  •     // w5500 ethernet driver is based on spi driver
  •     eth_w5500_config_t w5500_config = ETH_W5500_DEFAULT_CONFIG(spi_handle);
  •     // Set remaining GPIO numbers and configuration used by the SPI module
  •     w5500_config.int_gpio_num = spi_eth_module_config.int_gpio;
  •     phy_config_spi.phy_addr = spi_eth_module_config.phy_addr;
  •     phy_config_spi.reset_gpio_num = spi_eth_module_config.phy_reset_gpio;
  •     mac_spi = esp_eth_mac_new_w5500(&w5500_config, &mac_config_spi);
  •     phy_spi = esp_eth_phy_new_w5500(&phy_config_spi);
  •     esp_eth_config_t eth_config_spi = ETH_DEFAULT_CONFIG(mac_spi, phy_spi);
  •     ESP_ERROR_CHECK(esp_eth_driver_install(&eth_config_spi, &eth_handle_spi));
  •     /* The SPI Ethernet module might not have a burned factory MAC address, we cat to set it manually.
  •    02:00:00 is a Locally Administered OUI range so should not be used except when testing on a LAN under your control.*/
  •     ESP_ERROR_CHECK(esp_eth_ioctl(eth_handle_spi, ETH_CMD_S_MAC_ADDR, (uint8_t[){0xB0, 0x8E, 0x1A, 0x37, 0x00, 0x01}));
  •     //  attach Ethernet driver to TCP/IP stack
  •     ESP_ERROR_CHECK(esp_netif_attach(eth_netif_spi, esp_eth_new_netif_glue(eth_handle_spi)));
  •     // Register user defined event handers
  •     ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ESP_EVENT_ANY_ID, &eth_event_handler, NULL));
  •     ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &got_ip_event_handler, NULL));
  •     /* start Ethernet driver state machine */
  •     ESP_ERROR_CHECK(esp_eth_start(eth_handle_spi));
我是在这里设置的静态IP地址,运行后发现还是动态IP,是不是方法不对,ESP32如何设置W5500采用静态IP地址工作呢
有关ESP32挂载W5500的使用具体看看哪方面的资料。
回帖(1)
听我讲
2024-6-13 16:22:46
要在ESP32上使用W5500以太网模块并设置静态IP地址,您需要遵循以下步骤:
1. 首先,确保您已经安装了ESP32开发板和所需的库。在Arduino IDE中,您可以通过“文件”>“首选项”>“设置”来添加ESP32板管理器的URL。
2. 安装W5500以太网库。在Arduino IDE中,转到“工具”>“管理库”,然后在搜索框中输入“W5500”。找到库后,点击“安装”。
3. 接下来,您需要配置W5500模块的SPI接口。在您的代码中,添加以下宏定义:
```cpp
  do {
    eth_module_config->host = (uint8_t)num;
    eth_module_config->int_pin_num = (gpio_num_t)W5500_INT_PIN;
    eth_module_config->cs_pin_num = (gpio_num_t)W5500_CS_PIN;
    eth_module_config->spi_config = &spi_eth_config;
  } while(0)
4. 配置SPI接口参数。在您的代码中,添加以下代码:
```cpp
spi_device_handle_t spi_eth_handle;
spi_board_slot_t spi_eth_slot = SPI_ETH_SLOT;
spi_device_interface_config_t spi_eth_config = {
  .command_bits = 0,
  .address_bits = 8,
  .dummy_bits = 0,
  .clock_speed_hz = 10 * 1000 * 1000, // 10 MHz
  .duty_cycle_pos = 128,               // 50% duty cycle
  .cs_ena_posttrans = 3,               // 3 clock cycles after CS enabled
  .cs_dis_delay = 1,                   // 1 clock cycle after CS disabled
  .input_delay_ns = 0,                 // 0 ns
  .mode = 0,                           // SPI mode 0
  .intermediate_mailbox = 0
5. 初始化W5500模块。在您的`setup()`函数中,添加以下代码:
```cpp
void setup() {
  Serial.begin(115200);
  while (!Serial) {}
  // 初始化W5500模块
  INIT_SPI_ETH_MODULE_CONFIG(&w5500_config, 0);
  esp_err_t ret = spi_bus_add_device(HSPI_HOST, &spi_eth_config, &spi_eth_handle);
  assert(ret == ESP_OK);
  ret = w5500_init(&w5500_config, spi_eth_handle);
6. 设置静态IP地址。在您的代码中,添加以下函数:
```cpp
void setStaticIP() {
  w5500_ip_addr_t ip = { .addr = {192, 168, 1, 100} }; // 将此处的IP地址更改为您的静态IP地址
  w5500_ip_addr_t gateway = { .addr = {192, 168, 1, 1} }; // 将此处的网关地址更改为您的网关地址
  w5500_ip_addr_t subnet = { .addr = {255, 255, 255, 0} }; // 将此处的子网掩码更改为您的子网掩码
  w5500_set_ip(ip);
  w5500_set_gateway(gateway);
  w5500_set_subnet_mask(subnet);
7. 在`setup()`函数中调用`setStaticIP()`函数:
```cpp
void setup() {
  // ... 其他初始化代码 ...
  setStaticIP();
8. 编译并上传代码到您的ESP32开发板。
现在,您的ESP32应该已经配置了W5500以太网模块,并设置了静态IP地址。您可以使用串口监视器查看网络连接状态和IP地址。
举报
更多回帖
