乐鑫技术交流
直播中
刘芳
7年用户 1311经验值
私信 关注
[问答]
esp32s3 dma adc怎么读取都是0或者4095?为什么?
examples code:
#include
#include
#include "sdkconfig.h"
#include "esp_log.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "esp_adc/adc_continuous.h"
#define EXAMPLE_ADC_UNIT                    ADC_UNIT_1
#define _EXAMPLE_ADC_UNIT_STR(unit)         #unit
#define EXAMPLE_ADC_UNIT_STR(unit)          _EXAMPLE_ADC_UNIT_STR(unit)
#define EXAMPLE_ADC_CONV_MODE               ADC_CONV_SINGLE_UNIT_1
#define EXAMPLE_ADC_ATTEN                   ADC_ATTEN_DB_0
#define EXAMPLE_ADC_BIT_WIDTH               SOC_ADC_DIGI_MAX_BITWIDTH
#if CONFIG_IDF_TARGET_ESP32 || CONFIG_IDF_TARGET_ESP32S2
#define EXAMPLE_ADC_OUTPUT_TYPE             ADC_DIGI_OUTPUT_FORMAT_TYPE1
#define EXAMPLE_ADC_GET_CHANNEL(p_data)     ((p_data)->type1.channel)
#define EXAMPLE_ADC_GET_DATA(p_data)        ((p_data)->type1.data)
#else
#define EXAMPLE_ADC_OUTPUT_TYPE             ADC_DIGI_OUTPUT_FORMAT_TYPE2
#define EXAMPLE_ADC_GET_CHANNEL(p_data)     ((p_data)->type2.channel)
#define EXAMPLE_ADC_GET_DATA(p_data)        ((p_data)->type2.data)
#endif
#define EXAMPLE_READ_LEN                    256
static adc_channel_t channel[2] = {ADC_CHANNEL_6, ADC_CHANNEL_7};
#else
static adc_channel_t channel[2] = {ADC_CHANNEL_2, ADC_CHANNEL_3};
#endif
static TaskHandle_t s_task_handle;
static const char *TAG = "EXAMPLE";
static bool IRAM_ATTR s_conv_done_cb(adc_continuous_handle_t handle, const adc_continuous_evt_data_t *edata, void *user_data)
    BaseType_t mustYield = pdFALSE;
    //Notify that ADC continuous driver has done enough number of conversions
    vTaskNotifyGiveFromISR(s_task_handle, &mustYield);
    return (mustYield == pdTRUE);
static void continuous_adc_init(adc_channel_t *channel, uint8_t channel_num, adc_continuous_handle_t *out_handle)
    adc_continuous_handle_t handle = NULL;
    adc_continuous_handle_cfg_t adc_config = {
        .max_store_buf_size = 1024,
        .conv_frame_size = EXAMPLE_READ_LEN,
    ESP_ERROR_CHECK(adc_continuous_new_handle(&adc_config, &handle));
    adc_continuous_config_t dig_cfg = {
        .sample_freq_hz = 20 * 1000,
        .conv_mode = EXAMPLE_ADC_CONV_MODE,
        .format = EXAMPLE_ADC_OUTPUT_TYPE,
    adc_digi_pattern_config_t adc_pattern[SOC_ADC_PATT_LEN_MAX] = {0};
    dig_cfg.pattern_num = channel_num;
    for (int i = 0; i < channel_num; i++) {
        adc_pattern[i].atten = EXAMPLE_ADC_ATTEN;
        adc_pattern[i].channel = channel[i] & 0x7;
        adc_pattern[i].unit = EXAMPLE_ADC_UNIT;
        adc_pattern[i].bit_width = EXAMPLE_ADC_BIT_WIDTH;
        ESP_LOGI(TAG, "adc_pattern[%d].atten is :%"PRIx8, i, adc_pattern[i].atten);
        ESP_LOGI(TAG, "adc_pattern[%d].channel is :%"PRIx8, i, adc_pattern[i].channel);
        ESP_LOGI(TAG, "adc_pattern[%d].unit is :%"PRIx8, i, adc_pattern[i].unit);
    dig_cfg.adc_pattern = adc_pattern;
    ESP_ERROR_CHECK(adc_continuous_config(handle, &dig_cfg));
    *out_handle = handle;
void app_main(void)
    esp_err_t ret;
    uint32_t ret_num = 0;
    uint8_t result[EXAMPLE_READ_LEN] = {0};
    memset(result, 0xcc, EXAMPLE_READ_LEN);
    s_task_handle = xTaskGetCurrentTaskHandle();
    continuous_adc_init(channel, sizeof(channel) / sizeof(adc_channel_t), &handle);
    adc_continuous_evt_cbs_t cbs = {
        .on_conv_done = s_conv_done_cb,
    ESP_ERROR_CHECK(adc_continuous_register_event_callbacks(handle, &cbs, NULL));
    ESP_ERROR_CHECK(adc_continuous_start(handle));
    while(1) {
         * This is to show you the way to use the ADC continuous mode driver event callback.
         * This `ulTaskNotifyTake` will block when the data processing in the task is fast.
         * However in this example, the data processing (print) is slow, so you barely block here.
         * Without using this event callback (to notify this task), you can still just call
         * `adc_continuous_read()` here in a loop, with/without a certain block timeout.
        ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
        char unit[] = EXAMPLE_ADC_UNIT_STR(EXAMPLE_ADC_UNIT);
        while (1) {
            ret = adc_continuous_read(handle, result, EXAMPLE_READ_LEN, &ret_num, 0);
            if (ret == ESP_OK) {
                ESP_LOGI("TASK", "ret is %x, ret_num is %"PRIu32" bytes", ret, ret_num);
                for (int i = 0; i < ret_num; i += SOC_ADC_DIGI_RESULT_BYTES) {
                    adc_digi_output_data_t *p = (adc_digi_output_data_t*)&result[i];
                    uint32_t chan_num = EXAMPLE_ADC_GET_CHANNEL(p);
                    uint32_t data = EXAMPLE_ADC_GET_DATA(p);
                    /* Check the channel number validation, the data is invalid if the channel num exceed the maximum channel */
                    if (chan_num < SOC_ADC_CHANNEL_NUM(EXAMPLE_ADC_UNIT)) {
                        ESP_LOGI(TAG, "Unit: %s, Channel: %"PRIu32", Value: %"PRIx32, unit, chan_num, data);
                    } else {
                        ESP_LOGW(TAG, "Invalid data [%s_%"PRIu32"_%"PRIx32"]", unit, chan_num, data);
                 * Because printing is slow, so every time you call `ulTaskNotifyTake`, it will immediately return.
                 * To avoid a task watchdog timeout, add a delay here. When you replace the way you process the data,
                 * usually you don't need this delay (as this task will block for a while).
                vTaskDelay(1);
            } else if (ret == ESP_ERR_TIMEOUT) {
                //We try to read `EXAMPLE_READ_LEN` until API returns timeout, which means there's no available data
                break;
    ESP_ERROR_CHECK(adc_continuous_stop(handle));
    ESP_ERROR_CHECK(adc_continuous_deinit(handle));
adc1 怎么读取都是 4095 如果通道接地就为0,实在无解求指导
回帖(1)
梅利号
2024-6-11 17:07:34
以下是一些建议和可能的原因:
1. 确保您已经正确初始化了ADC和DMA。在您的代码中,您需要调用`esp_adc_new_ll()`函数来初始化ADC,并使用`esp_dma_new_descriptor()`函数来初始化DMA。
2. 检查您的ADC配置。确保您已经设置了正确的ADC通道、分辨率和采样速率。例如:
```c
adc_config_t adc_config = {
    .adc_num = EXAMPLE_ADC_UNIT,
    .adc_bits = 12, // 12位分辨率
    .adc_atten = 0, // 无衰减
    .adc_channel = 0, // ADC通道0
3. 确保您已经正确配置了DMA传输。在您的代码中,您需要设置DMA传输的源地址、目标地址、传输大小和传输模式。例如:
```c
dma_descriptor_t *dma_descriptor = malloc(sizeof(dma_descriptor_t));
dma_descriptor_init(dma_descriptor);
dma_descriptor_set_src(dma_descriptor, &adc1_io_num);
dma_descriptor_set_dst(dma_descriptor, &adc_value, sizeof(adc_value));
dma_descriptor_set_length(dma_descriptor, 1);
dma_descriptor_set_size(dma_descriptor, DMA_SIZE_WORD);
dma_descriptor_set_burst(dma_descriptor, false);
4. 检查您的ADC读取逻辑。确保您在DMA传输完成后读取ADC值。例如:
```c
while (1) {
    xSemaphoreTake(dma_sem, portMAX_DELAY);
    uint32_t adc_value = *(uint32_t *)dma_descriptor_get_dst(dma_descriptor);
    ESP_LOGI("ADC", "ADC value: %d", adc_value);
举报
更多回帖
