esp-idf 版本 : v4.4.2
示例:bluetooth/esp_ble_mesh/aligenie_demo
idf.py menuconfig 关于Coredump配置如下
配置好后执行烧录 idf.py -p /dev/ttyUSB0 erase_flash flash monitor
烧录成功执行 espcoredump.py -p /dev/ttyUSB0 dbg_corefile build/aligenie_demo.elf
报错如下:Code:
Select all
espcoredump.py v0.4-devINFO: Invoke parttool to read image.INFO: esptool.py v3.3.2-devSerial port /dev/ttyUSB0Connec
ting...Detecting chip type... Unsupported detection protocol, switching and trying again...Connecting...Detecting chip type... ESP32Chip is ESP32-D0WD-V3 (revision 3)Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme NoneCrystal is 40MHzMAC: 08:3a:8d:0b:b4:24Stub is already running. No upload is necessary.3072 (100 %)3072 (100 %)Read 3072 bytes at 0x8000 in 0.3 seconds (86.2 kbit/s)...Hard resetting via RTS pin...esptool.py v3.3.2-devSerial port /dev/ttyUSB0Connecting...Detecting chip type... Unsupported detection protocol, switching and trying again...Connecting.....Detecting chip type... ESP32Chip is ESP32-D0WD-V3 (revision 3)Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme NoneCrystal is 40MHzMAC: 08:3a:8d:0b:b4:24Uploading stub...Running stub...Stub running...65536 (100 %)65536 (100 %)Read 65536 bytes at 0x3d0000 in 5.9 seconds (88.5 kbit/s)...Hard resetting via RTS pin...Running /home/jyb/.espressif/python_env/idf4.4_py3.8_env/bin/python /home/jyb/esp/ayla_esp/components/esptool_py/esptool/esptool.py --port /dev/ttyUSB0 read_flash 32768 3072 /tmp/tmp207ozkg3...Running /home/jyb/.espressif/python_env/idf4.4_py3.8_env/bin/python /home/jyb/esp/ayla_esp/components/esptool_py/esptool/esptool.py --port /dev/ttyUSB0 read_flash 3997696 65536 /tmp/tmpsw1n2sfc...Read partition 'coredump' contents from device at offset 0x3d0000 to file '/tmp/tmpsw1n2sfc'Traceback (most recent call last): File "/home/jyb/esp/ayla_esp/components/espcoredump/espcoredump.py", line 352, in temp_core_files = dbg_corefile() File "/home/jyb/esp/ayla_esp/components/espcoredump/espcoredump.py", line 125, in dbg_corefile core_elf_path, target, temp_files = get_core_dump_elf(e_machine=exe_elf.e_machine) File "/home/jyb/esp/ayla_esp/components/espcoredump/espcoredump.py", line 65, in get_core_dump_elf loader = ESPCoreDumpFlashLoader(args.off, args.chip, port=args.port, baud=args.baud) File "/home/jyb/esp/ayla_esp/components/espcoredump/corefile/loader.py", line 439, in __init__ self.target = self._load_core_src() File "/home/jyb/esp/ayla_esp/components/espcoredump/corefile/loader.py", line 179, in _load_core_src raise ESPCoreDumpLoaderError('Core dump version "0x%x" is not supported!' % self.dump_ver)corefile.ESPCoreDumpLoaderError: Core dump version "0xffff" is not supported!
