电路设计论坛
直播中
bigbangboom
9年用户 1400经验值
擅长:电源/新能源
私信 关注
[问答]
ad9695的channel1 FTW一直配置不成功的原因?
我需要使用NCO的快速切换通道功能,用了DDC0和DDC1,需要使用这两个DDC的channel0和channel1,但是只配置成功了channel0的FTW。另一个channel1的FTW一直配置不成功。我的配置程序如下所示,请问我的配置程序有什么问题?
//-----------------nco fast config-----------//
                //----------ddc0 ch0--------------------//
                20'h0_6a00: DataReg <= {16'h0314, 8'H00};
                20'h0_6c00: DataReg <= {16'h0316, AD_FREQ_156_25M[7:0]};
                20'h0_6d00: DataReg <= {16'h0317, AD_FREQ_156_25M[15:8]};
                20'h0_6e00: DataReg <= {16'h0318, AD_FREQ_156_25M[23:16]};
                20'h0_6f00: DataReg <= {16'h0319, AD_FREQ_156_25M[31:24]};
                20'h0_7000: DataReg <= {16'h031a, AD_FREQ_156_25M[39:32]};
                20'h0_7100: DataReg <= {16'h031b, AD_FREQ_156_25M[47:40]};
                //----------ddc1 ch0--------------------//
                20'h0_7200: DataReg <= {16'h0334, 8'H00};
                20'h0_7300: DataReg <= {16'h0336, AD_FREQ_156_25M[7:0]};
                20'h0_7400: DataReg <= {16'h0337, AD_FREQ_156_25M[15:8]};
                20'h0_7500: DataReg <= {16'h0338, AD_FREQ_156_25M[23:16]};
                20'h0_7600: DataReg <= {16'h0339, AD_FREQ_156_25M[31:24]};
                20'h0_7700: DataReg <= {16'h033a, AD_FREQ_156_25M[39:32]};
                20'h0_7800: DataReg <= {16'h033b, AD_FREQ_156_25M[47:40]};
                // 20'h0_7900: DataReg <= {16'h000f, 8'h01};  //
                //----------ddc0 ch1--------------------//
                20'h0_7a00: DataReg <= {16'h0314, 8'H01};
                20'h0_7b00: DataReg <= {16'h0316, AD_FREQ_257_50M[7:0]};
                20'h0_7c00: DataReg <= {16'h0317, AD_FREQ_257_50M[15:8]};
                20'h0_7d00: DataReg <= {16'h0318, AD_FREQ_257_50M[23:16]};
                20'h0_7e00: DataReg <= {16'h0319, AD_FREQ_257_50M[31:24]};
                20'h0_7f00: DataReg <= {16'h031a, AD_FREQ_257_50M[39:32]};
                20'h0_8000: DataReg <= {16'h031b, AD_FREQ_257_50M[47:40]};
                //----------ddc1 ch1--------------------//
                20'h0_8100: DataReg <= {16'h0334, 8'H01};
                20'h0_8200: DataReg <= {16'h0336, AD_FREQ_257_50M[7:0]};
                20'h0_8300: DataReg <= {16'h0337, AD_FREQ_257_50M[15:8]};
                20'h0_8400: DataReg <= {16'h0338, AD_FREQ_257_50M[23:16]};
                20'h0_8500: DataReg <= {16'h0339, AD_FREQ_257_50M[31:24]};
                20'h0_8600: DataReg <= {16'h033a, AD_FREQ_257_50M[39:32]};
                20'h0_8700: DataReg <= {16'h033b, AD_FREQ_257_50M[47:40]};
                //------------------config nco  channel ----------------//
                20'h0_9100: DataReg <= {16'h0314, 4'b0000, 3'b000, ch_slect};
                20'h0_9200: DataReg <= {16'h0334, 4'b0000, 3'b000, ch_slect};
                20'h0_9300: DataReg <= 24'h030013;
                20'h0_9400: DataReg <= 24'h030003;
回帖(1)
郝埃连
2024-5-30 14:33:34
根据您提供的配置程序,我将逐步分析可能的问题并提供解决方案。
1. 首先,检查FTW寄存器的配置。确保FTW寄存器的配置正确,以便在通道1上启用快速切换功能。请检查FTW寄存器的配置是否与通道0相同。
2. 确保DDC0和DDC1的配置正确。根据您的描述,您需要使用DDC0和DDC1的通道0和通道1。请检查DDC0和DDC1的配置是否正确,以及它们是否正确地映射到通道0和通道1。
3. 检查NCO配置。确保NCO的配置正确,以便在通道1上实现快速切换功能。请检查NCO寄存器的配置是否与通道0相同。
4. 检查程序中的注释。在您的代码中,有一些注释使用了HTML实体(如 ),这可能会影响代码的可读性和正确性。建议将这些实体替换为普通的空格或制表符。
5. 检查代码的语法和格式。确保代码的语法正确,格式整齐,以便编译器能够正确解析和执行代码。
6. 调试和测试。在修改配置程序后,进行调试和测试,以确保通道1的FTW配置成功。
综上所述,您需要检查FTW寄存器、DDC配置、NCO配置以及代码的语法和格式。在进行这些检查和修改后,您的配置程序应该能够成功配置通道1的FTW。
举报
更多回帖
