使用库文件的Demo程序,配合ST官方Demo板,
下载库文件的Demo程序,发送使用DMA时,DAC没有输出,
反复修改,
最后将两个DAC都配置成Stream5 Chanel7 两个通道都正常输出,
但是数据手册了上DAC2应该是Sream6 Channel7, 根据手册配置的话 DAC1和DAC2 都没有输出
这是怎么回事,
下边是我的源程序
* @file DAC_SignalsGenera
tion/main.c
* @author MCD Application Team
* @version V1.0.0
* @date 19-September-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
copy; COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "
STM32f4_discovery.h"
/** @addtogroup STM32F4_Discovery_Peripheral_Examples
/** @addtogroup DAC_SignalsGeneration
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define DAC_DHR12R2_ADDRESS 0x40007414
#define DAC_DHR8R1_ADDRESS 0x40007410
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
DAC_InitTypeDef DAC_InitStructure;
const uint16_t Sine12bit[32] = {
2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
const uint8_t Escalator8bit[6] = {0x0,0X11,0X22,0X33,0X44,0xFF};
__IO uint8_t SelectedWavesForm = 1;
__IO uint8_t KeyPressed = SET;
/* Private function prototypes -----------------------------------------------*/
void TIM6_Config(void);
void DAC_Ch1_EscalatorConfig(void);
void DAC_Ch2_SineWaveConfig(void);
void DAC_Ch1_NoiseConfig(void);
void DAC_Ch2_TriangleConfig(void);
/* Private functions ---------------------------------------------------------*/
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f4xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f4xx.c file
/* Preconfiguration before using DAC----------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
/* DMA1 clock and GPIOA clock enable (to be used with DAC) */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1 | RCC_AHB1Periph_GPIOA, ENABLE);
/* DAC Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
/* DAC channel 1 2 (DAC_OUT1 = PA.4)(DAC_OUT2 = PA.5) configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, GPIO_InitStructure);
/* TIM6 Configuration ------------------------------------------------------*/
TIM6_Config();
/* Configures User Button */
STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI);
DAC_Ch1_EscalatorConfig();
/* Sine Wave generator -----------------------------------------------*/
DAC_Ch2_SineWaveConfig();
while (1)
/* If the User Button is pressed */
if (KeyPressed == RESET)
DAC_DeInit();
/* select waves forms according to the Key Button status */
if (SelectedWavesForm == 1)
//SelectedWavesForm 已经设置成1
/* The sine wave and the escalator wave has been selected */
// DAC_Ch1_EscalatorConfig(); ==========注释掉这部分,移动到while (1)前
/* Escalator Wave generator ------------------------------------------*/
// DAC_Ch2_SineWaveConfig();==========注释掉这部分,移动到while (1)前
else
/* The triangle wave and the noise wave has been selected */
/* Noise Wave generator ----------------------------------------------*/
//DAC_Ch1_NoiseConfig();
/* Triangle Wave generator -------------------------------------------*/
DAC_Ch2_TriangleConfig();
KeyPressed = SET;
* @brief TIM6 Configuration
* @note TIM6 configuration is based on CPU @168MHz and APB1 @42MHz
* @note TIM6 Update event occurs each 37.5MHz/256 = 16.406 KHz
* @param None
* @retval None
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/* TIM6 Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
/* Time base configuration */
TIM_TimeBaseStructInit( TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 0xFF;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM6, TIM_TimeBaseStructure);
/* TIM6 TRGO selection */
TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
/* TIM6 enable counter */
TIM_Cmd(TIM6, ENABLE);
* @brief DAC Channel2 SineWave Configuration
* @param None
* @retval None
DMA_InitTypeDef DMA_InitStructure;
/* DAC channel2 Configuration */
DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init(DAC_Channel_2, DAC_InitStructure);
//这部分注释应该有问题,手册上DAC2对应Stream6 Channel7
/* DMA1_Stream5 channel7 configuration **************************************/
DMA_DeInit(DMA1_Stream5);
DMA_InitStructure.DMA_Channel = DMA_Channel_7;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)DAC_DHR12R2_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) Sine12bit;
DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
DMA_InitStructure.DMA_BufferSize = 32;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA1_Stream5, DMA_InitStructure);
/* Enable DMA1_Stream5 */
DMA_Cmd(DMA1_Stream5, ENABLE);
/* Enable DAC Channel2 */
DAC_Cmd(DAC_Channel_2, ENABLE);
/* Enable DMA for DAC Channel2 */
DAC_DMACmd(DAC_Channel_2, ENABLE);
* @brief DAC Channel1 Escalator Configuration
* @param None
* @retval None
/* DAC channel1 Configuration */
DAC_Init(DAC_Channel_1, DAC_InitStructure);
//这部分注释应该有问题,手册上DAC2对应Stream5 Channel7
/* DMA1_Stream6 channel7 configuration **************************************/
DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR8R1_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) Escalator8bit;
DMA_InitStructure.DMA_BufferSize = 6;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_Init(DMA1_Stream6, DMA_InitStructure);
/* Enable DMA1_Stream6 */
DMA_Cmd(DMA1_Stream6, ENABLE);
/* Enable DAC Channel1 */
DAC_Cmd(DAC_Channel_1, ENABLE);
/* Enable DMA for DAC Channel1 */
DAC_DMACmd(DAC_Channel_1, ENABLE);
* @brief DAC Channel2 Triangle Configuration
* @param None
* @retval None
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Triangle;
DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_1023;
/* Set DAC channel2 DHR12RD register */
DAC_SetChannel2Data(DAC_Align_12b_R, 0x100);
* @brief DAC Channel1 Noise Configuration
* @param None
* @retval None
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Noise;
DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bits10_0;
/* Set DAC Channel1 DHR12L register */
DAC_SetChannel1Data(DAC_Align_12b_L, 0x7FF0);
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
