STM32
直播中
百合子
9年用户 984经验值
擅长:控制/MCU
私信 关注
[问答]
STM8AF开发板无法实现CAN通信怎么解决?
各位大神
       我是STM8的新手,最近买了两套STM8A-DISCOVERY开发板,基于STM8AF52芯片开发,原本想着将两块开发板的CAN口对接,进行一些通信测试,但发现无法实现CAN通信,一下是我的代码,请各位大神指点指点:
主循环中的实现:
main()
        CLK_Config();
        CAN_Config();
        while(1)
                 /* Transmit Parameters*/
                Tx_Id = 0;
                Tx_IDE = CAN_Id_Standard;
                Tx_RTR = CAN_RTR_Data;
                Tx_DLC = 1;
                Tx_Data[0] = i;
                GPIO_WriteLow(GPIOA, (GPIO_Pin_TypeDef)GPIO_PIN_3);
                 /* Sender send Frame */
                status = CAN_Transmit(Tx_Id,Tx_IDE,Tx_RTR,Tx_DLC,Tx_Data);
void CLK_Config(void)
  /* Initialization of the clock */
  /* Clock divider to HSI/1 */
  CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
void CAN_Config(void)
  CAN_InitStatus_TypeDef status = CAN_InitStatus_Failed;
  /* Filter Parameters */
  CAN_FilterNumber_TypeDef CAN_FilterNumber;
  FunctionalState CAN_FilterActivation;
  CAN_FilterMode_TypeDef CAN_FilterMode;
  CAN_FilterScale_TypeDef CAN_FilterScale;
  UINT8 CAN_FilterID1;
  UINT8 CAN_FilterID2;
  UINT8 CAN_FilterID3;
  UINT8 CAN_FilterID4;
  UINT8 CAN_FilterIDMask1;
  UINT8 CAN_FilterIDMask2;
  UINT8 CAN_FilterIDMask3;
  UINT8 CAN_FilterIDMask4;
  /* Init Parameters*/
  CAN_MasterCtrl_TypeDef CAN_MasterCtrl;
  CAN_Mode_TypeDef CAN_Mode;
  CAN_SynJumpWidth_TypeDef CAN_SynJumpWidth;
  CAN_BitSeg1_TypeDef CAN_BitSeg1;
  CAN_BitSeg2_TypeDef CAN_BitSeg2;
  UINT8 CAN_Prescaler;
  /* CAN register init */
  CAN_DeInit();
  /* CAN  init */
  CAN_MasterCtrl=CAN_MasterCtrl_AllDisabled;
  CAN_Mode = CAN_Mode_Normal;
  CAN_SynJumpWidth = CAN_SynJumpWidth_1TimeQuantum;
  CAN_BitSeg1 = CAN_BitSeg1_8TimeQuantum;
  CAN_BitSeg2 = CAN_BitSeg2_7TimeQuantum;
  CAN_Prescaler = 1;
  status = CAN_Init(CAN_MasterCtrl, CAN_Mode, CAN_SynJumpWidth, CAN_BitSeg1,
                    CAN_BitSeg2, CAN_Prescaler);
  /* CAN filter init */
  CAN_FilterNumber = CAN_FilterNumber_0;
  CAN_FilterActivation = ENABLE;
  CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterScale = CAN_FilterScale_32Bit;
  CAN_FilterID1=0;
  CAN_FilterID2=0;
  CAN_FilterID3=0;
  CAN_FilterID4=0;
  CAN_FilterIDMask1=0;
  CAN_FilterIDMask2=0;
  CAN_FilterIDMask3=0;
  CAN_FilterIDMask4=0;
  CAN_FilterInit(CAN_FilterNumber, CAN_FilterActivation, CAN_FilterMode,
                 CAN_FilterScale,CAN_FilterID1, CAN_FilterID2, CAN_FilterID3,
                 CAN_FilterID4,CAN_FilterIDMask1, CAN_FilterIDMask2,
                 CAN_FilterIDMask3, CAN_FilterIDMask4);
  /* Enable Fifo message pending interrupt*/
  /* Message reception is done by CAN_RX ISR*/
  CAN_ITConfig(CAN_IT_FMP, ENABLE);
中断配置如下:
  * @brief CAN RX Interrupt routine.
  * @param  None
  * @retval None
INTERRUPT_HANDLER(CAN_RX_IRQHandler, 8)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
        /* Receiver Receives Frame */
        CAN_Receive();
同时在stm8_interrupt_vector.c文件中的中断向量表里修改如下:
        {0x82, (interrupt_handler_t)CAN_RX_IRQHandler}, /* irq8  */
将两块开发板CAN口对接,然后我通过调试器将断点设置在中断响应函数的CAN_Receive()一行,无任何中断响应。请问,这个CAN通信的问题有可能出在哪里?
回帖(1)
久醉不醒
2024-5-14 16:59:03
首先,我们需要确保您的STM8AF开发板的CAN通信配置是正确的。以下是一些建议和步骤,以帮助您解决无法实现CAN通信的问题:
1. 检查硬件连接:确保两块开发板的CAN口正确连接,并且没有短路或断路的情况。
2. 检查CAN配置:确保您的CAN配置正确,包括波特率、模式(基本或扩展帧)、过滤器等。以下是一些常见的CAN配置参数:
   a. CAN波特率:确保两个开发板的波特率设置相同。
   b. CAN模式:选择基本帧或扩展帧,并确保两个开发板的设置相同。
   c. CAN过滤器:如果使用过滤器,请确保它们配置正确,以便正确接收和发送消息。
3. 初始化CAN:在主函数中,确保您已经正确初始化了CAN模块。以下是初始化CAN模块的示例代码:
```c
    CAN_InitTypeDef CAN_InitStructure;
    /* CAN clock enable */
    CAN_CLK_ENABLE();
    /* CAN GPIO configuration */
    /* CAN peripheral reset */
    CAN_DeInit(CAN1);
    /* CAN configuration */
    CAN_InitStructure.CAN_TTCM = DISABLE;
    CAN_InitStructure.CAN_ABOM = DISABLE;
    CAN_InitStructure.CAN_AWUM = DISABLE;
    CAN_InitStructure.CAN_NART = DISABLE;
    CAN_InitStructure.CAN_RFLM = DISABLE;
    CAN_InitStructure.CAN_TXFP = DISABLE;
    CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
    CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
    CAN_Init(CAN1, &CAN_InitStructure);
    /* CAN filters configuration */
    /* CAN interrupt enable */
    CAN_ITConfig(CAN1, CAN_IT_TME, ENABLE);
    /* CAN start */
    CAN_Cmd(CAN1, ENABLE);
4. 发送和接收消息:确保您的发送和接收消息的代码是正确的。以下是发送和接收消息的示例代码:
```c
void CAN_Send_Message(CAN_TypeDef* CANx, CAN_TxMsg_TypeDef* TxMessage)
    CAN_TxStatus_TypeDef TxStatus;
    TxStatus = CAN_TransmitStatus(CANx, CAN_TxMailbox_0);
    if (TxStatus == CAN_TxStatus_Failed)
        TxStatus = CAN_TransmitStatus(CANx, CAN_TxMailbox_1);
        TxStatus = CAN_TransmitStatus(CANx, CAN_TxMailbox_2);
    if (TxStatus == CAN_TxStatus_Empty)
        CAN_Transmit(CANx, TxMessage);
void CAN_Receive_Message(CAN_TypeDef* CANx, CAN_RxMsg_TypeDef* RxMessage)
    CAN_FIFO_TypeDef CAN_FIFONumber = CAN_FIFO0;
    if (CAN_MessagePending(CANx, CAN_FIFO0) != 0)
        CAN_Receive(CANx, CAN_FIFO0, RxMessage);
    else if (CAN_MessagePending(CANx, CAN_FIFO1) != 0)
        CAN_Receive(CANx, CAN_FIFO1, RxMessage);
5. 检查中断:确保您的CAN中断配置正确,并且在中断服务例程中正确处理了发送和接收的消息。
6. 使用示波器或逻辑分析仪:如果以上步骤都无法解决问题,您可以尝试使用示波器或逻辑分析仪来检查CAN总线上的信号,以确定问题是否出在硬件层面。
7. 更新固件库:确保您使用的STM8固件库是最新版本,以避免可能的已知问题。
举报
更多回帖
