STM32
直播中
马占云
8年用户 1645经验值
私信 关注
[问答]
STM32F105 ADC采集数据时,IO电压一样,采集数据不一样是为什么?
如题,STM32F105,DMA方式采集ADC数据,其中两路,IO口电压一样,但采集数据不一样。数据相差较大,且差值不固定。
请大神指导。
void SysInit_ADC(void)
         ADC_InitTypeDef ADC_InitStructure;
         RCC_ADCCLKConfig(RCC_PCLK2_Div2);
/* Enable ADC1*/
           RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
         ADC_DeInit(ADC1);
/* Initialize the ADCx according to the ADC_InitStructure members */
         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
         ADC_InitStructure.ADC_ScanConvMode = ENABLE;
         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
         ADC_InitStructure.ADC_NbrOfChannel = 7;
         ADC_Init(ADC1, ADC_InitStructure);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 6, ADC_SampleTime_41Cycles5);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 7, ADC_SampleTime_41Cycles5);
/* Enable ADC1 DMA */
           ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
         ADC_Cmd(ADC1,ENABLE);
/* Enable ADC1 reset calibration register */
           ADC_ResetCalibration(ADC1);
/* Check the end of ADC1 reset calibration register */
           while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibration */
           ADC_StartCalibration(ADC1);
/* Check the end of ADC1 calibration */
           while(ADC_GetCalibrationStatus(ADC1));
         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void SysInit_DMA(void)
         DMA_InitTypeDef DMA_InitStructure;
         /* Enable DMA1 clock */
           RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
           /* DMA1 channel1 configuration ----------------------------------------------*/
           DMA_DeInit(DMA1_Channel1);
           DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
           DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADCConvertedValue;
           DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
           DMA_InitStructure.DMA_BufferSize = 7;
           DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
           DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
           DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
           DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
           DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
           DMA_InitStructure.DMA_Priority = DMA_Priority_High;
           DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
           DMA_Init(DMA1_Channel1,  DMA_InitStructure);
           /* Enable DMA1 channel1 */
           DMA_Cmd(DMA1_Channel1, ENABLE);
//AD采集
//每10MS调用
void ADC_Scan(void)
         Filter_Buf00[Filter_Pointer] = (u16)(ADCConvertedValue[0]>>2);
         Filter_Buf01[Filter_Pointer] = (u16)(ADCConvertedValue[1]>>2);
         Filter_Buf02[Filter_Pointer] = (u16)(ADCConvertedValue[2]>>2);
         Filter_Buf03[Filter_Pointer] = (u16)(ADCConvertedValue[3]>>2);
         Filter_Buf05[Filter_Pointer] = (u16)(ADCConvertedValue[4]>>2);
         Filter_Buf04[Filter_Pointer] = (u16)(ADCConvertedValue[5]>>2);
         Filter_Buf06[Filter_Pointer] = (u16)(ADCConvertedValue[6]>>2);
         Filter_Pointer++;
         if(Filter_Pointer >= 10) //去极值求平均        Filter_Remove_Extremum
                 Filter_Pointer = 0;
                 Aircondition.S_InTemp = Avr_Filter(Filter_Buf0,Filter_Remove_Extremum(Filter_Buf00));
         //        Aircondition.S_OutTemp = Avr_Filter(Filter_Buf1,Filter_Remove_Extremum(Filter_Buf01));
                 Aircondition.S_Def0Temp = Avr_Filter(Filter_Buf2,Filter_Remove_Extremum(Filter_Buf02));
         //        Aircondition.S_LNTemp = Avr_Filter(Filter_Buf3,Filter_Remove_Extremum(Filter_Buf03));
                 Aircondition.S_VOL = Avr_Filter(Filter_Buf4,Filter_Remove_Extremum(Filter_Buf04));
         //        Aircondition.S_PTC1Temp = Avr_Filter(Filter_Buf5,Filter_Remove_Extremum(Filter_Buf05));
         //        Aircondition.S_PTC2Temp = Avr_Filter(Filter_Buf6,Filter_Remove_Extremum(Filter_Buf06));
//                ADC_AnalogToDigtal();
回帖(1)
郑成枝
2024-5-9 16:27:42
STM32F105 ADC采集数据时,如果两路IO口电压相同,但采集到的数据不一样,可能有以下几个原因:
1. **ADC校准问题**:STM32F105的ADC需要进行校准,以确保其精度。如果未进行校准或校准不正确,可能会导致采集到的数据不准确。
2. **ADC配置问题**:检查ADC_InitTypeDef结构体中的参数设置,确保采样时间、分辨率等参数设置正确。
3. **模拟输入通道问题**:确保两路IO口连接到ADC的输入通道是正确的,并且没有受到干扰。
4. **DMA配置问题**:检查DMA的配置,确保它正确地将ADC数据传输到内存中。
5. **电源和地线问题**:检查电源和地线是否稳定,不稳定的电源或地线可能导致ADC采集到的数据不稳定。
6. **外部干扰**:检查是否有外部电磁干扰,这可能导致ADC采集到的数据不稳定。
7. **软件问题**:检查代码逻辑,确保没有错误地处理或解释ADC数据。
8. **硬件问题**:检查硬件连接,确保ADC输入通道与IO口之间的连接正确且无损坏。
为了解决这个问题,你可以尝试以下步骤:
1. 重新校准ADC。
2. 检查ADC_InitTypeDef结构体中的参数设置,确保它们正确。
3. 检查DMA配置,确保它正确地将ADC数据传输到内存中。
4. 检查电源和地线,确保它们稳定。
5. 检查是否有外部电磁干扰,并采取措施减少干扰。
6. 仔细检查代码逻辑,确保正确处理和解释ADC数据。
7. 检查硬件连接,确保ADC输入通道与IO口之间的连接正确且无损坏。
希望这些建议能帮助你解决问题。如果问题仍然存在,请提供更多详细信息,以便进一步分析。
举报
更多回帖
