代码是从Fwlib的例子里改的
基本配置代码如下
/* ADCs configura
tion: double interleaved with 6cycles delay to reach 5Msps */
/* ADC Common configuration *************************************************/
ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_Interl;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_8Cycles;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_3;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInit( amp;ADC_CommonInitStructure);
/* DMA mode 3 is used in interleaved mode in 6-bit or 8-bit resolutions */
ADC_InitStructure.ADC_Resolution = ADC_Resolution_8b;//ADC_Resolution_8b;
/* ADC1 regular channel 12 configuration ************************************/
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 1;
ADC_Init(ADC1, amp;ADC_InitStructure);
/* ADC1 regular channel12 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* ADC2 regular channel 12 configuration ************************************/
ADC_Init(ADC2, amp;ADC_InitStructure);
/* ADC2 regular channel12 configuration */
ADC_RegularChannelConfig(ADC2, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (multi-ADC mode) ******************/
ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
/* Enable ADC1 **************************************************************/
ADC_Cmd(ADC1, ENABLE);
/* Enable ADC2 **************************************************************/
ADC_Cmd(ADC2, ENABLE);
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConv(ADC1);
代码如上,这里 ADC_CommonInitStructure.ADC_TwoSamplingDelay
输入信号为300k的正弦波,采样结果如图所示
黑色波形为ADC1,2的组合数据,蓝色和红色分别对应 ADC1,ADC2
如果将输入信号改为800k,那么ADC1,ADC2的差距将更加明显。另外,从图中可以看到,ADC1,ADC2的采样分辨率视乎根本没达到8位的效果
我试过ADC_TwoSamplingDelay_6Cycles,效果差不多,我使用单ADC采样,则没有问题,就是达不到我要的4M左右的AD速度
双AD inter模式本来就是为高速设计的,现在这样的结果肯定不是预期的效果,不知道问题错在哪里,请各位指教
