STM32
直播中
文甘翀
7年用户 944经验值
私信 关注
[问答]
STM32f0C8T6睡眠模式到底能不能用?
最近在做一个很简单的程序,然后客户必须要低功耗,开始用STC的单片机由于要使用5个1外部中断实现低功耗唤醒,功能实现不了,换STM32来是,产考了很多资料但不管怎么样就是进不了睡眠模式,要不就是进入了睡眠模式但却不能唤醒,而且用电流表测量电流竟然达到了40mA,折腾了好多天也一直没有个结果。有没有大神指导下的!下面是我参考官方例程写的程序!!
  • int main(void)
  •         SYS_HSI_CLK_Config();
  •   if (Systick_Config(SystemCoreClock / 1000))
  •     while (1);//²¶»ñ´íÎó
  •         RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  •   PWR_BackupAccessCmd(ENABLE);
  •   RCC_BackupResetCmd(ENABLE);
  •   RCC_BackupResetCmd(DISABLE);
  •   SleepMode_Measure();
  •         LED_IO_Init();
  •   while (1)
  •                 switch(mode)
  •                   case 1:SW_1() ;break;
  •                         case 2:SW_2() ;break;
  •                         case 3:SW_3() ;break;
  •                         case 4:SW_4() ;break;
  •                         case 5:SW_5() ;break;
  •                         default:         __WFI(); break; // Sys_Standby();rest_all(GPIOA,OUT_DATA,~OUT_DATA);
  •                 //test();
  •                 GPIOC->ODR |=0x2000;
  •                 Delay(50);
  •                 GPIOC->ODR  =~0x2000;
  •                 Delay(50);
  • void SleepMode_Measure()
  •          __IO uint32_t index = 0;
  •   GPIO_InitTypeDef GPIO_InitStructure;
  •   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC, ENABLE);
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  •   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  •   GPIO_Init(GPIOA,  GPIO_InitStructure);
  •   GPIO_Init(GPIOB,  GPIO_InitStructure);
  •   GPIO_Init(GPIOC,  GPIO_InitStructure);
  •   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC, DISABLE);
  •         EXTI0_1InitConfig();
  •         EXTI2_3InitConfig();
  •         EXTI4_15InitConfig();
  •         __WFI();
  •         while (1)
  •     for(index = 0; index < 0x7FFFF; index++);
  • void EXTI0_1InitConfig(void)
  •   //Enable GPIOA clock
  •   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  •   // Configure PA0 pin as input floating
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  •   // Enable SYSCFG clock
  •   RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  •   // Connect EXTI0 Line to PA0 pin
  •   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource1);
  •   // Configure EXTI1 line
  •   EXTI_InitStructure.EXTI_Line = EXTI_Line1;
  •   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  •   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  •   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  •   EXTI_Init( EXTI_InitStructure);
  •   // Enable and set EXTI0 Interrupt
  •   NVIC_InitStructure.NVIC_IRQChannel = EXTI0_1_IRQn;
  •   NVIC_InitStructure.NVIC_IRQChannelPriority = 0x00;
  •   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  •   NVIC_Init( NVIC_InitStructure);
  • void EXTI2_3InitConfig(void)
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
  •   // Connect EXTI0 Line to PA2 pin
  •   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource2);
  •         // Connect EXTI0 Line to PA3 pin
  •   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource3);
  •   // Configure EXTI2 line
  •   EXTI_InitStructure.EXTI_Line = EXTI_Line2;
  •   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  •         // Configure EXTI3 line
  •          EXTI_InitStructure.EXTI_Line = EXTI_Line3;
  •   // Enable and set EXTI2-3 Interrupt
  •   NVIC_InitStructure.NVIC_IRQChannel = EXTI2_3_IRQn;
  •   NVIC_InitStructure.NVIC_IRQChannelPriority = 0x01;
  • void EXTI4_15InitConfig(void)
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5;
  •   // Connect EXTI0 Line to PA4 pin
  •   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource4);
  •         // Connect EXTI0 Line to PA5 pin
  •   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource5);
  •   // Configure EXTI4 line
  •   EXTI_InitStructure.EXTI_Line = EXTI_Line4;
  •         // Configure EXTI5 line
  •         EXTI_InitStructure.EXTI_Line = EXTI_Line5;
  •   // Enable and set EXTI4-15 Interrupt
  •   NVIC_InitStructure.NVIC_IRQChannel = EXTI4_15_IRQn;
  •   NVIC_InitStructure.NVIC_IRQChannelPriority = 0x10;
  •         //Sys_Enter_Standby();
回帖(1)
刘锦
2024-5-8 16:42:08
降电流除了进入低功耗模式外,还要注意晶振频率,很多功耗来源于时钟频率导致的静态功耗
举报
更多回帖
