STM32
直播中
周棠亨
7年用户 1047经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
746 Nucleo板子上添加UART初始化代码,不发生接收中断怎么解决?
我在用746 Nucleo板子作串口实验,用下面这个工程:
D:workSTM32CubeF7STM32Cube_FW_F7_V1.7.0ProjectsSTM32F746ZG-NucleoExamplesUARTUART_PrintfEWARM
uart初始化代码改成 ,我用UART3:
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
  GPIO_InitTypeDef  GPIO_InitStruct;
  RCC_PeriphCLKInitTypeDef RCC_PeriphClkInit;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable GPIO TX/RX clock */
  USARTx_TX_GPIO_CLK_ENABLE();
  //USARTx_RX_GPIO_CLK_ENABLE();
  /* Select SysClk as source of USART1 clocks */
  RCC_PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  RCC_PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_SYSCLK;
  HAL_RCCEx_PeriphCLKConfig( RCC_PeriphClkInit);
  /* Enable USARTx clock */
  USARTx_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
  /* UART TX GPIO pin configuration  */
  GPIO_InitStruct.Pin       = USARTx_TX_PIN;
  GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull      = GPIO_PULLUP;
  GPIO_InitStruct.Speed     = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = USARTx_TX_AF;
  HAL_GPIO_Init(USARTx_TX_GPIO_PORT,  GPIO_InitStruct);
  /* UART RX GPIO pin configuration  */
  GPIO_InitStruct.Pin = USARTx_RX_PIN;
  GPIO_InitStruct.Alternate = USARTx_RX_AF;
  HAL_GPIO_Init(USARTx_RX_GPIO_PORT,  GPIO_InitStruct);
  HAL_NVIC_SetPriority(USARTx_IRQn,0,1);
  HAL_NVIC_EnableIRQ(USARTx_IRQn);
在main文件中加了回调函数:
  * @brief Rx Transfer completed callbacks
  * @param huart: uart handle
  * @retval None
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
                UartReady = SET;
main() 函数里增加了 接收判断函数;
UartHandle.Instance        = USARTx;
  UartHandle.Init.BaudRate   = 9600;
  UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
  UartHandle.Init.StopBits   = UART_STOPBITS_1;
  UartHandle.Init.Parity     = UART_PARITY_ODD;
  UartHandle.Init.HwFlowCtl  = UART_HWCONTROL_NONE;
  UartHandle.Init.Mode       = UART_MODE_TX_RX;
  UartHandle.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init( UartHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
        printf("nr UART Printf Example: retarget the C library printf function to the UARTnr");
  printf("** Test finished successfully. ** nr");
        UartReady = RESET;
        if( HAL_UART_Receive_IT( UartHandle , aRxBuffer, 30) != HAL_OK)
                 Error_Handler();
        UartReady = RESET;
        while (UartReady != SET)
                BSP_LED_On(LED2);
                HAL_Delay(100);
                BSP_LED_Off(LED2);
                HAL_Delay(100);
                BSP_LED_On(LED2);
                HAL_Delay(100);
                BSP_LED_Off(LED2);
                HAL_Delay(500);
        UartReady = RESET;
        BSP_LED_Off(LED2);
启动程序后, 断点放在最后两行, 无论用超级终端怎么发数据, 都无法跳出上面的while 循环。
如果谁有 746Nucleo板子的中断方式发送和接收的工程, 共享出来学习一下。 谢谢!
回帖(1)
徐振方
2024-5-6 10:22:57
main()函数中需要加入:
__HAL_UART_ENABLE_IT( UartHandle,UART_IT_RXNE);
举报
更多回帖
