STM32
直播中
蒋美燕
8年用户 967经验值
私信 关注
[问答]
STM32H743 UART DMA数据发送报错的原因?
采用STM32H743芯片, 实现UART DMA收发数据.
用图形化的界面配置了设置, UART配置成DMA模式, 之后通过HAL_UART_Transmit_DMA发送数据, 中断报发送错误(DMA_FLAG_TEIF0_4), 总线上也没有数据输出.
以下是初始化部分代码:
static void MX_UART4_Init(void)
  huart4.Instance = UART4;
  huart4.Init.BaudRate = 115200;
  huart4.Init.WordLength = UART_WORDLENGTH_8B;
  huart4.Init.StopBits = UART_STOPBITS_1;
  huart4.Init.Parity = UART_PARITY_NONE;
  huart4.Init.Mode = UART_MODE_TX_RX;
  huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart4.Init.OverSampling = UART_OVERSAMPLING_16;
  huart4.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart4.Init.Prescaler = UART_PRESCALER_DIV1;
  huart4.Init.FIFOMode = UART_FIFOMODE_DISABLE;
  huart4.Init.TXFIFOThreshold = UART_TXFIFO_THRESHOLD_1_8;
  huart4.Init.RXFIFOThreshold = UART_RXFIFO_THRESHOLD_1_8;
  huart4.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init( huart4) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==UART4)
  /* USER CODE BEGIN UART4_MspInit 0 */
  /* USER CODE END UART4_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_UART4_CLK_ENABLE();
    /**UART4 GPIO Configuration
    PA0-WKUP     ------> UART4_TX
    PA11     ------> UART4_RX
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Alternate = GPIO_AF8_UART4;
    HAL_GPIO_Init(GPIOA,  GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_11;
    GPIO_InitStruct.Alternate = GPIO_AF6_UART4;
    /* UART4 DMA Init */
    /* UART4_TX Init */
    hdma_uart4_tx.Instance = DMA1_Stream0;
    hdma_uart4_tx.Init.Request = DMA_REQUEST_UART4_TX;
    hdma_uart4_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_uart4_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_uart4_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_uart4_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_uart4_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_uart4_tx.Init.Mode = DMA_NORMAL;
    hdma_uart4_tx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_uart4_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init( hdma_uart4_tx) != HAL_OK)
    __HAL_LINKDMA(huart,hdmatx,hdma_uart4_tx);
    /* UART4_RX Init */
    hdma_uart4_rx.Instance = DMA1_Stream1;
    hdma_uart4_rx.Init.Request = DMA_REQUEST_UART4_RX;
    hdma_uart4_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_uart4_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_uart4_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_uart4_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_uart4_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_uart4_rx.Init.Mode = DMA_CIRCULAR;
    hdma_uart4_rx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_uart4_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init( hdma_uart4_rx) != HAL_OK)
    __HAL_LINKDMA(huart,hdmarx,hdma_uart4_rx);
    /* UART4 interrupt Init */
    HAL_NVIC_SetPriority(UART4_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(UART4_IRQn);
  /* USER CODE BEGIN UART4_MspInit 1 */
  /* USER CODE END UART4_MspInit 1 */
调用 if(HAL_UART_Transmit_DMA( huart4, (uint8_t *)cmd_37, 1/*sizeof(cmd_37)*/)!= HAL_OK)
//if(HAL_UART_Transmit( huart4, (uint8_t *)cmd_37, sizeof(cmd_37), 1000)!= HAL_OK)
  Error_Handler();
DMA产生了中断, 中断源是发送错误.
补充: 通过HAL_UART_Transmit( huart4, (uint8_t *)cmd_37, sizeof(cmd_37), 1000)发送, 串口是可以正常看到数据发送的, 可以排除串口本身的问题.
回帖(1)
dplion5
2024-4-26 17:19:07
    HAL_UART_Init(&huart4);
    // DMA配置
    hdma_uart4_tx.Instance = DMA2_Stream6;
    hdma_uart4_tx.Init.Channel = DMA_CHANNEL_7;
    hdma_uart4_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
    hdma_uart4_tx.Init.MemBurst = DMA_MBURST_SINGLE;
    hdma_uart4_tx.Init.PeriphBurst = DMA_PBURST_SINGLE;
    HAL_DMA_Init(&hdma_uart4_tx);
    // 将DMA与UART关联
    __HAL_LINKDMA(&huart4, hdmatx, hdma_uart4_tx);
    // 配置UART DMA传输
    HAL_UARTEx_Receive_DMA(&huart4, (uint8_t *)rxBuffer, sizeof(rxBuffer));
    HAL_UART_Transmit_DMA(&huart4, (uint8_t *)txBuffer, sizeof(txBuffer));
    // 使能DMA中断
    HAL_NVIC_SetPriority(DMA2_Stream6_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(DMA2_Stream6_IRQn);
根据您提供的代码,我将分析可能导致UART DMA数据发送报错的原因:
1. DMA通道配置错误:请确保您选择的DMA通道(DMA2_Stream6)与您的硬件设计相匹配。如果通道选择错误,可能导致数据传输失败。
2. DMA中断优先级配置错误:请确保您为DMA中断设置了正确的优先级。如果优先级设置不当,可能导致中断处理不当,从而影响数据传输。
3. DMA中断服务例程(ISR)未正确实现:请确保您已经实现了DMA中断服务例程,并且在其中正确处理了DMA中断标志。如果ISR未正确实现,可能导致DMA传输错误。
4. UART配置错误:请确保您的UART配置(如波特率、数据位、停止位等)与接收设备相匹配。如果配置错误,可能导致数据传输失败。
5. 数据缓冲区未正确初始化:请确保您的发送和接收缓冲区(txBuffer和rxBuffer)已正确初始化。如果缓冲区未正确初始化,可能导致数据传输错误。
6. 硬件连接问题:请检查您的UART和DMA硬件连接是否正确。如果硬件连接存在问题,可能导致数据传输失败。
7. 中断使能问题:请确保您已经使能了UART的DMA传输中断。如果中断未使能,可能导致DMA传输错误。
8. 代码中可能存在其他逻辑错误:请仔细检查您的代码,确保所有相关配置和操作都已正确执行。
举报
更多回帖
