社区活动专版
直播中
大菠萝Alpha
4年用户 766经验值
擅长:嵌入式技术
私信 关注
《深入理解FFmpeg阅读体验》FFmpeg摄像头测试
零、前期工作
上文FFmpeg移植完成后,需要将x264/lib文件夹下的库文件拷贝到开发板的/lib/目录下,将ffmpeg_install/lib文件夹下的库文件全部拷贝到开发板的/lib/目录下,将ffmpeg_install/bin/目录下的ffmpeg文件拷贝到开发板的/bin/目录下。
root@myd-yd9x:~# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                 1.9G      1.9G         0 100% /
devtmpfs                619.1M         0    619.1M   0% /dev
tmpfs                   763.8M         0    763.8M   0% /dev/shm
tmpfs                   763.8M    184.0K    763.7M   0% /tmp
tmpfs                   763.8M    468.0K    763.4M   0% /run
然后测试下ffmpeg:
root@myd-yd9x:/bin# ./ffmpeg
ffmpeg version N-114829-gf48987f609 Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 7.3.1 (Linaro GCC 7.3-2018.05) 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701]
  configuration: --prefix=/home/ffmpeg_install --enable-cross-compile --arch=arm64 --target-os=linux --cc=aarch64-linux-gnu-gcc --disable-x86asm --cross-prefix=aarch64-linux-gnu- --pkg-config=/usr/bin/pkg-config
  libavutil      59. 15.100 / 59. 15.100
  libavcodec     61.  5.103 / 61.  5.103
  libavformat    61.  3.100 / 61.  3.100
  libavdevice    61.  2.100 / 61.  2.100
  libavfilter    10.  2.101 / 10.  2.101
  libswscale      8.  2.100 /  8.  2.100
  libswresample   5.  2.100 /  5.  2.100
Universal media converter
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
OK的。
二、连接摄像头
我用的是手头的海康720P USB摄像头。
插进去后系统自动识别。
[ 1812.860609] uvcvideo: Found UVC 1.00 device HIK 720P Camera (2bdf:0280)
[ 1812.863363] uvcvideo 1-1.5:1.0: Entity type for entity Extension 3 was not initialized!
[ 1812.863439] uvcvideo 1-1.5:1.0: Entity type for entity Processing 2 was not initialized!
[ 1812.863505] uvcvideo 1-1.5:1.0: Entity type for entity Camera 1 was not initialized!
[ 1812.865476] input: HIK 720P Camera: HIK 720P Camer as /devices/platform/soc/soc:usb3@31260000/31260000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.5/1-1.5:1.0/input/input4
[ 1812.869972] snd-usb-audio 1-1.5:1.2: no of_node; not parsing pinctrl DT
然后在/dev中发现了video8设备,记住名字备用。
三、视频录制
通过FFmpeg录制视频使用如下cmd:
ffmpeg -f video4linux2 -s 320x240 -i /dev/video8 /tmp/cam_video.avi
看看CPU占用率。
将视频拷贝出来,因为录制的时候分辨率没设置很高,所以将就看看,能看出是啥电影吗?
更多回帖
