STM32
直播中
廖阿朋
9年用户 1369经验值
私信 关注
[问答]
STM32F103RCT6呼吸灯实验PWM调不出来的原因?
STM32F103RCT6呼吸灯实验PWM调不出来,用的原子MINI 开发板,利用PA8 复用功能tiM1_CH1   输出PWM
#include"stm32f10x.h"
#include"sys.h"
#define LED0 PAout(8)
#define LED1 PDout(2)
void SysTick_Init(u8 SYSCLK);  //SysTick初始化函数声明
void delay_ms(u16 nms);        //自定义的延时毫秒函数声明
void GPIO_Configuration(void); //GPIO端口初始化设置函数声明
void TIM1_PWM_Init(u16 arr,u16 psc);//定时器1初始化设置配置成PWM输出函数声明
u8 fac_us=0;
u16 fac_ms=0;
int main(void)
{ u16 led0pwmval=0;
        u8 dir=1;
        SysTick_Init(72);  // 调用SysTick初始化函数
  //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        GPIO_Configuration();
        TIM1_PWM_Init(899,0);//不分频。PWM频率=72000/(899+1)=80Khz
        while(1)
                 delay_ms(10);
                if(dir)led0pwmval++;
                else led0pwmval--;
                 if(led0pwmval>300)dir=0;
                if(led0pwmval==0)dir=1;
                TIM_SetCompare1(TIM1,led0pwmval);
void SysTick_Init(u8 SYSCLK) //SysTick初始化函数
{SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
fac_us=SYSCLK/8; //SYSCLK的8分频 保存1us所需的计数次数
fac_ms=(u16)fac_us*1000; //1ms 需要计数的次数
{        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE);//使能PA,PD外设端口时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;                                  //LED0-->PA8 端口配置
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度为50MHz
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //复用推挽输出,TIM1_CH1输出PWM脉冲波形
        GPIO_Init(GPIOA,  GPIO_InitStructure);                                          //根据设定参数初始化GPIOA.8
  // GPIO_SetBits(GPIOA,GPIO_Pin_8);                                                        //PA8 输出高
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;                            //LED1-->PD2 端口配置
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOD,  GPIO_InitStructure);                                          //根据设定参数初始化GPIOD.2,推挽输出,IO口速度为50MHz
  GPIO_SetBits(GPIOD,GPIO_Pin_2);                                                       //PD.2 输出高
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值         80K
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值  不分频
        TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM1,  TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
        TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高
        TIM_OC1Init(TIM1,  TIM_OCInitStructure);  //根据TIM_OCInitStruct中指定的参数初始化外设TIMx
  TIM_CtrlPWMOutputs(TIM1,ENABLE);                         //MOE 主输出使能
  TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1预装载使能
        TIM_ARRPreloadConfig(TIM1, ENABLE);                //使能TIMx在ARR上的预装载寄存器
        TIM_Cmd(TIM1, ENABLE);                             //使能TIM1
void delay_ms(u16 nms) //利用SysTick自定义的延时毫秒函数 最长延时1864ms
{u32 temp;
SysTick->LOAD=(u32)nms*fac_ms; // nms毫秒需要装载的寄存器值
SysTick->VAL =0x00; //清空计数器
SysTick->CTRL=0x01; //开始倒数
do{temp=SysTick->CTRL;}
while ((temp 0x01)  !(temp (1<<16))); //等待时间到达
SysTick->CTRL =~0x01; //关闭计数器
SysTick->VAL =0X00; //清空计数器
回帖(1)
陈俊
2024-4-16 16:48:06
根据提供的代码,呼吸灯实验无法调出PWM的原因可能有以下几点:
1. 未正确配置GPIO端口:确保已正确配置PA8引脚的模式和复用功能,以使用TIM1_CH1输出功能。
2. 未初始化系统滴答定时器(SysTick):检查是否正确调用了SysTick_Init函数进行初始化,该函数用于提供延时功能。
3. 定时器1未正确配置:确认是否正确调用了TIM1_PWM_Init函数进行初始化配置,该函数用于将定时器1配置为PWM输出模式。
4. 未正确设置定时器1的自动重装载寄存器(ARR)和预分频器(PSC)的值:确认传入TIM1_PWM_Init函数的参数arr和psc是否正确,这两个参数决定了PWM信号的频率和占空比。
5. 延时时间设置不当:在主函数中,根据呼吸灯的需求,使用合适的延时时间。
需要仔细检查以上几个方面的配置,以确保呼吸灯实验能够正确输出PWM信号。
举报
更多回帖
