STM32
直播中
李斌
8年用户 1471经验值
私信 关注
[问答]
stm32f103c8t6用外部HSE来产生72Mhz时钟,但是HSE的RDY比特一直都是0,为什么?
目前自己做的板子是,STM32f103c8t6。
现在的问题是想用外部HSE来产生72Mhz时钟,但是HSE的RDY比特一直都是0。 下面是程序代码,请问大家?问题出在哪里?
板子上用的是8Mhz的无源晶振。两个电容都是接的22P, 电容之间没有接电阻
void SystemInit (void)
  /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
#ifndef STM32F10X_CL
  RCC->CFGR  = (uint32_t)0xF8FF0000;
#else
  RCC->CFGR  = (uint32_t)0xF0FF0000;
#endif /* STM32F10X_CL */
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR  = (uint32_t)0xFEF6FFFF;
  /* Reset HSEBYP bit */
  RCC->CR  = (uint32_t)0xFFFBFFFF;
  /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
  RCC->CFGR  = (uint32_t)0xFF80FFFF;
#ifdef STM32F10X_CL
  /* Reset PLL2ON and PLL3ON bits */
  RCC->CR  = (uint32_t)0xEBFFFFFF;
  /* Disable all interrupts and clear pending bits  */
  RCC->CIR = 0x00FF0000;
  /* Reset CFGR2 register */
  RCC->CFGR2 = 0x00000000;
#elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  RCC->CIR = 0x009F0000;
#else
#if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  #ifdef DATA_IN_ExtSRAM
    SystemInit_ExtMemCtl();
  #endif /* DATA_IN_ExtSRAM */
#endif
  /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
  /* Configure the Flash Latency cycles and enable prefetch buffer */
  SetSysClock();
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */
#endif
static void SetSysClock(void)
#ifdef SYSCLK_FREQ_HSE
  SetSysClockToHSE();
#elif defined SYSCLK_FREQ_24MHz
  SetSysClockTo24();
#elif defined SYSCLK_FREQ_36MHz
  SetSysClockTo36();
#elif defined SYSCLK_FREQ_48MHz
  SetSysClockTo48();
#elif defined SYSCLK_FREQ_56MHz
  SetSysClockTo56();
#elif defined SYSCLK_FREQ_72MHz
  SetSysClockTo72();//执行到这里
#endif
static void SetSysClockTo72(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR   RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0)    (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR   RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 2 wait state */
    FLASH->ACR  = (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    RCC->CFGR2  = (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR   RCC_CR_PLL2RDY) == 0)
    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
    RCC->CFGR  = (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
                            RCC_CFGR_PLLMULL9);
#else
    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
    RCC->CFGR  = (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
                                        RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR   RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR  = (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR   (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
回帖(1)
h1654155275.5741
2024-4-12 16:01:49
从您提供的代码来看,使用HSE(外部时钟)来产生72MHz时钟的问题可能出在以下几个地方:
1.        晶振的频率设置:您提到使用的是8MHz的无源晶振。请确保在初始化RCC之前,将HSEBYP位(bit 17)清零,以使外部时钟源正常工作,即 RCC->CR &= ~(1<<17)。
2.        等待外部时钟稳定:在启动外部时钟后,根据芯片的规格,需要一定的时间等待外部时钟稳定。为了避免进一步的问题,可以在启动外部时钟后增加适当的延迟,比如几百个毫秒等。
3.        使用外部时钟作为系统时钟:请确保在RCC中正确配置SYSCFGR寄存器,将外部时钟源(HSE)作为系统时钟。相关的代码可能如下:
   RCC->CR |= RCC_CR_HSEON;                            // 开启外部时钟
   while(!(RCC->CR & RCC_CR_HSERDY));  // 等待外部时钟就绪
   // 配置系统时钟源(HSE)
   RCC->CFGR |= RCC_CFGR_SW_0;                       // 外部时钟作为系统时钟
   while((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_0); // 等待系统时钟切换完成
   // 设置APB1和APB2时钟分频系数等
   请在代码中进行适当更改,并确保按照规格手册的要求正确配置并初始化外部时钟。
4.        检查引脚连接:请确保将晶振连接到正确的引脚(OSC_IN和OSC_OUT)。
如果上述步骤都没能解决问题,那么可能有其他硬件问题,比如连接错误,电源不稳定等。建议再次检查电路连接,引脚状态,以及输入电压等。
另外,建议参考STM32官方提供的例程和用户手册,以获取更多关于使用外部时钟的细节信息。
举报
更多回帖
