#include "
STM32f7xx.h"
#include "stm32f7xx_hal.h"
#include
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (op
tion LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
static void Error_Handler(void);
static void CPU_CACHE_Enable(void);
void systemclockinit(int plln,int pllm,int pllp,int pllq);
void uartinit(void);
static UART_HandleTypeDef UARThandle;
int main(void)
/* Enable the CPU Cache */
CPU_CACHE_Enable();
HAL_Init();
systemclockinit(432,25,2,9);
uartinit();
printf("hello");
// HAL_icInit();
// printf("my printf test,compile time:%s %srn",__DATE__,__TIME__);
printf("hello");
while(1)
/* if(TIM5CH1_Capture_STA 0X40)
temp=TIM5CH1_Capture_STA;
temp*=0xFFFFFFFF;
temp+=TIM5CH1_Capture_VAL;
sprintf(text, "AD value = 0x%04X", temp);
/* User may add here some code to deal with this error */
while(1)
/* Enable I-Cache */
SCB_EnableICache();
/* Enable D-Cache */
SCB_EnableDCache();
//串口初始化
void uartinit(void)
UARThandle.Instance=USART1;
UARThandle.Init.BaudRate=115200;
UARThandle.Init.WordLength=UART_WORDLENGTH_8B;
UARThandle.Init.StopBits=UART_STOPBITS_1;
UARThandle.Init.HwFlowCtl=UART_HWCONTROL_NONE;
UARThandle.Init.Parity=UART_PARITY_NONE;
UARThandle.Init.Mode=UART_MODE_TX_RX;
if (HAL_UART_Init( UARThandle)!=HAL_OK)
Error_Handler();
//串口回调函数
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
GPIO_InitTypeDef GPIO_InitStruct;
RCC_PeriphCLKInitTypeDef RCC_PeriphClkInit;
/*##-1- Enable peripherals and GPIO Clocks #################################*/
/* Enable GPIO TX/RX clock */
__HAL_RCC_GPIOA_CLK_ENABLE();
/* Select SysClk as source of USART1 clocks */
RCC_PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
RCC_PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_SYSCLK;
HAL_RCCEx_PeriphCLKConfig( RCC_PeriphClkInit);
/* Enable USARTx clock */
__HAL_RCC_USART1_CLK_ENABLE();
/*##-2- Configure peripheral GPIO ##########################################*/
/* UART TX GPIO pin configuration */
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
HAL_GPIO_Init(GPIOA, GPIO_InitStruct);
/* UART RX GPIO pin configuration */
GPIO_InitStruct.Pin = GPIO_PIN_10;
//printf重定向
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */
HAL_UART_Transmit( UARThandle, (uint8_t *) ch, 1, 0xFFFF);
return ch;
