STM32
直播中
张英
8年用户 1443经验值
私信 关注
[问答]
STM32F030K6T6+CubeMX+DMA+AD无法读出电压值怎么解决?
利用CubeMX 6.3.0 生成AD读取程序无法取出寄存器值,一直为零 应为IO不够用用的串口下载程序
ADC_HandleTypeDef hadc;
DMA_HandleTypeDef hdma_adc;
/* ADC init function */
void MX_ADC_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_BACKWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = ENABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = ENABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init( hadc) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_71CYCLES_5;
  if (HAL_ADC_ConfigChannel( hadc,  sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
    Error_Handler();
  /* USER CODE BEGIN ADC_Init 2 */
//  ADC1->CFGR1  = (uint32_t)~ADC_CFGR1_DMACFG;
//  ADC1->CFGR1 |= (uint32_t)ADC_CFGR1_DMACFG;
  /* USER CODE END ADC_Init 2 */
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(adcHandle->Instance==ADC1)
  /* USER CODE BEGIN ADC1_MspInit 0 */
  /* USER CODE END ADC1_MspInit 0 */
    /* ADC1 clock enable */
    __HAL_RCC_ADC1_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /**ADC GPIO Configuration
    PA0     ------> ADC_IN0
    PA1     ------> ADC_IN1
    PA2     ------> ADC_IN2
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOA,  GPIO_InitStruct);
    /* ADC1 DMA Init */
    /* ADC Init */
    hdma_adc.Instance = DMA1_Channel1;
    hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc.Init.Mode = DMA_CIRCULAR;
    hdma_adc.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init( hdma_adc) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc);
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
  /* USER CODE BEGIN ADC1_MspDeInit 0 */
  /* USER CODE END ADC1_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_ADC1_CLK_DISABLE();
    PA0     ------> ADC_IN0
    PA1     ------> ADC_IN1
    PA2     ------> ADC_IN2
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2);
    /* ADC1 DMA DeInit */
    HAL_DMA_DeInit(adcHandle->DMA_Handle);
  /* USER CODE BEGIN ADC1_MspDeInit 1 */
  /* USER CODE END ADC1_MspDeInit 1 */
还有初始化
HAL_ADCEx_Calibration_Start( hadc);
HAL_Delay(100);
HAL_ADC_Start_DMA( hadc, ADC_Value, 150);
处理函数
void read_V(void)
  for(i=0,ad1=0,ad2=0,ad3=0; i<150;)
    ad1 += ADC_Value[i++];
    ad2 += ADC_Value[i++];
    ad3 += ADC_Value[i++];
  ad1 /= 50;
  ad2 /= 50;
  ad3 /= 50;
  ChongDDY= ad1+ad2+ad3;
回帖(1)
云甫太
2024-3-29 16:50:22
如果基于CubeMx进行配置结合Cube库的话,应该可以很快实现该功能。我刚才也用F030开发板测试了OK.
代码比较简单,你可以参考下:
uint32_t AdcData3]={0};
HAL_ADCEx_Calibration_Start( hadc);;
  HAL_ADC_Start_DMA( hadc, AdcData,  3);
static void MX_ADC_Init(void)
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.LowPowerAutoWait = DISABLE;
    Error_Handler();
  sConfig.SamplingTime = ADC_SAMPLETIME_55CYCLES_5;
    Error_Handler();
    Error_Handler();
    Error_Handler();
另外,建议你检查下硬件,尤其电源以及VDDA脚的连接情况。
举报
更多回帖
