STM32
直播中
符筹荣
8年用户 1059经验值
私信 关注
[问答]
STM32MP157F-DK2 tsv下载错误的原因?
问题
  • 按照官网教程 Getting_started 操作测试开发板
  • 进行到使用 CubeProgrammer 下载 STM32MP1 OpenSTLinux Starter Package 至SD卡时下载错误
操作过程
  • 设置开发板启动模式
  • 重启开发板
  • 连接CubeProg
  • 选择.tsv文件 FlashLayout_sdcard_stm32mp157f-dk2-trusted.tsv
  • 选择Binaries path
  • 下载
  • 听到USB设备弹出提示音
  • CubeProg报错
CubeProg 输出的错误信息(部分)
  • ...前面省略
  • 11:50:11:906 : sending a set alternate setting request with index: 2
  • 11:50:11:906 : Memory Programming ...
  • 11:50:11:906 : Opening and parsing file: fip-stm32mp157f-dk2-trusted.bin
  • 11:50:11:908 :   File          : fip-stm32mp157f-dk2-trusted.bin
  • 11:50:11:908 :   Size          : 1090807 Bytes
  • 11:50:11:908 :   Partition ID  : 0x06
  • 11:50:11:908 : Download in Progress:
  • 11:50:11:908 : sending packet nbr: 0
  • 11:50:11:909 : DFU status = 0
  • 11:50:11:909 : DFU State = 5
  • ...中间省略若干灰色输出信息
  • 11:50:11:970 : sending packet nbr: 121
  • 11:50:11:971 : DFU status = 0
  • 11:50:11:971 : DFU State = 5
  • 11:50:11:971 : sending packet nbr: 122
  • 11:50:15:891 : libusb control transfer error [-7] : LIBUSB_ERROR_TIMEOUT
  • 11:50:15:891 : Error: failed to download Segment[0]
  • 11:50:15:891 : Error: failed to download the File
  • 11:50:15:926 : Error: Download partition 0x06 failed
  • 11:50:15:967 : Error: TSV flashing service failed
  • 11:50:16:594 : Warning: Connection to device 0x500 is lost
  • 11:50:17:396 : Disconnected from device.
  • 11:50:17:397 : STLinkUSBDriver.dll loaded
STlink 输出的信息
  • U-Boot 2020.10-stm32mp-r2 (Oct 05 2020 - 15:15:32 +0000)
  • CPU: STM32MP157FAC Rev.Z
  • Model: STMicroelectronics STM32MP157F-DK2 Discovery Board
  • Board: stm32mp1 in trusted mode (st,stm32mp157f-dk2)
  • Board: MB1272 Var4.0 Rev.C-02
  • DRAM:  512 MiB
  • Clocks:
  • -MPU : 800 MHz
  • -MCU : 208.878 MHz
  • -AXI : 266.500 MHz
  • -PER : 24 MHz
  • -DDR : 533 MHz
  • WDT:   Started with servicing (32s timeout)
  • NAND:  0 MiB
  • MMC:   STM32 SD/MMC: 0, STM32 SD/MMC: 1
  • In:    serial
  • Out:   serial
  • Err:   serial
  • Net:   eth0: ethernet@5800a000
  • Hit any key to stop autoboot:  1  0
  • Boot over usb0!
  • partitions : Writing GPT: success!
  • done
  • Erasing fip on mmc 0: done
  • DFU alt info setting: done
  • crq->brequest:0x0
  • crq->brequest:0x0
  • UPLOAD ... done
  • Ctrl+C to exit ...
  • DOWNLOAD ... OK
  • UPLOAD ... done
  • UPLOAD ... done
  • DOWNLOAD ... OK
  • UPLOAD ... done
  • UPLOAD ... done
其他
  • 供电使用树莓派5V3A电源适配器,未提示电流不足
  • SD卡原装16G与另一张32G均试过
  • 换第二台计算机错误同样
想问一下各位是什么问题
回帖(1)
小芳
2024-3-29 16:25:26
根据提供的步骤和错误信息,有几个可能导致STM32MP157F-DK2 tsv下载错误的原因:
1. 文件路径错误:请确保选择的.tsv文件路径正确,确保文件存在且路径正确。确保你已经正确选择了正确的文件路径。
2. 文件格式错误:请确保.tsv文件格式正确。如果文件格式不正确,可能会导致下载错误。可以尝试重新下载正确的文件并重试。
3. 开发板连接问题:请确保开发板与计算机已正确连接,并关注连接体验是否如预期。确保使用合适的USB线缆连接,检查是否设备驱动程序已正确安装。尝试重新连接设备并重试。
4. CubeProg 设置错误:请确保在使用CubeProg之前已经正确设置了开发板的启动模式。确保正确选择设备并设置正常的启动模式来支持下载操作。您可以参考开发板的用户手册或官方文档以确保正确的设置。
如果问题仍然存在,请尝试联系STM32官方技术支持以获取进一步的帮助和指导。
举报
更多回帖
