STM32
直播中
abdkjshd
9年用户 1258经验值
擅长:可编程逻辑
私信 关注
[问答]
使用STM32Cube Programmer可以连接到芯片,不能擦除是为什么?
使用STM32CubeProgrammer可以连接到芯片,但是不能擦除
  15:17:06 : STM32CubeProgrammer API v2.12.0 | Windows-64Bits   15:17:10 : ST-LINK SN  : 390A070A2416303030303032  15:17:10 : ST-LINK FW  : V2J41S7  15:17:10 : Board       : --  15:17:10 : Voltage     : 4.70V  15:17:10 : SWD freq    : 4000 KHz  15:17:10 : Connect mode: Under Reset  15:17:10 : Reset mode  : Hardware reset  15:17:10 : Device ID   : 0x413  15:17:10 : Revision ID : Rev Y  15:17:10 : Debug in Low Power mode is not supported for this device.  15:17:11 : UPLOADING OPtiON BYTES DATA ...  15:17:11 :   Bank          : 0x00  15:17:11 :   Address       : 0x40023c14  15:17:11 :   Size          : 4 Bytes  15:17:11 : UPLOADING ...  15:17:11 :   Size          : 1024 Bytes  15:17:11 :   Address       : 0x8000000  15:17:11 : Read progress:  15:17:11 : Data read successfully  15:17:11 : Time elapsed during the read operation is: 00:00:00.007  15:18:01 : MASS ERASE ...   15:18:01 : Error: Mass erase operation failed.Please verify flash protection使用最新版本的STM32CUBEIDE 调试STM32F407ZGT6单片机报错信息
STMicroelectronics ST-LINK GDB server. Version 7.3.0Copyright (c) 2023, STMicroelectronics. All rights reserved.Starting server with the following options:        Persistent Mode            : Disabled        Logging Level              : 1        Listen Port Number         : 61234        Status Refresh Delay       : 15s        Verbose Mode               : Disabled        SWD Debug                  : EnabledSTM32_SystemReset(), failure reset target.Waiting for debugger connection...Debugger connectedWaiting for debugger connection...Debugger connectedWaiting for debugger connection...      -------------------------------------------------------------------                       STM32CubeProgrammer v2.13.0        -------------------------------------------------------------------Log output file:   C:UsersJohn9AppDataLocalTempSTM32CubeProgrammer_a12424.logST-LINK SN  : 390A070A2416303030303032ST-LINK FW  : V2J41S7Board       : --Voltage     : 3.14VSWD freq    : 4000 KHzConnect mode: Under ResetReset mode  : Hardware resetDevice ID   : 0x413Revision ID : Rev YDevice name : STM32F405xx/F407xx/F415xx/F417xxFlash size  : 1 MBytes (default)Device type : MCUDevice CPU  : Cortex-M4BL Version  : 0x91Memory Programming ...Opening and parsing file: ST-LINK_GDB_server_a12424.srec  File          : ST-LINK_GDB_server_a12424.srec  Size          : 39.39 KB   Address       : 0x08000000 Erasing memory corresponding to segment 0:Erasing internal memory sectors [0 2]Error: failed to erase memoryError: failed to erase memoryEncountered Error when opening P:ProgramSTMicroelectronicsSTM32CubeIDESTM32CubeIDEpluginscom.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.600.202301161003toolsbinSTM32_Programmer_CLI.exeError in STM32CubeProgrammerShutting down...Exit.
回帖(1)
李亚东
2024-3-14 15:14:46
用cubeprogrammer 工具连上后,能读取FLASH 和 option byte 的内容么?如果能读取的话,重点检查一下option byte的内容是否正常。
举报
更多回帖
