【米尔-全志T113-i开发板试用】JPG硬件解码的实现和对比测试
MYC-YT113i核心板及开发板
真正的国产核心板,100%国产物料认证
datasheet中清楚的写着
基础开发环境搭建参考上一篇
https://bbs.elecfans.com/jishu_2408808_1_1.html
我们需要调用全志的视频引擎库进行硬件编解码,具体的sdk下载自
https://github.com/MYIR-ALLWINNER/framework/tree/develop-yt113-framework/libcedarc
so库文件可以直接从开发板上提取出来
adb pull /usr/lib/libaftertreatment.so
adb pull /usr/lib/libcdc_base.so
adb pull /usr/lib/libfbm.so
adb pull /usr/lib/libMemAdapter.so
adb pull /usr/lib/libsbm.so
adb pull /usr/lib/libscaledown.so
adb pull /usr/lib/libvdecoder.so
adb pull /usr/lib/libVE.so
adb pull /usr/lib/libvideoengine.so
https://github.com/nothings/stb
stb_image 是应用十分广泛的图片解码实现,纯C语言,无任何依赖,接口简单易用,支持读取jpg/png/bmp等图片格式,适合用于嵌入式环境中
先从文件读取jpg数据到内存中
// read file
std::vector<unsigned char> buf;
FILE* fp = fopen("in.jpg", "rb");
fseek(fp, 0, SEEK_END);
int size = ftell(fp);
rewind(fp);
buf.resize(size);
fread(buf.data(), 1, size, fp);
fclose(fp);
fprintf(stderr, "size = %d\n", size);
使用 stb_image 解码图片为 RGB pixeldata 完成jpg软件解码
int desired_channels = 3;
int w;
int h;
int c;
unsigned char* pixeldata = stbi_load_from_memory(buf.data(), buf.size(), &w, &h, &c, desired_channels);
其中步骤 3~6 是基于cedarc库完成,剩余步骤是软件实现
步骤3可以初始化一次后,不需要再重复初始化
cedarc库的使用方法参考
https://github.com/MYIR-ALLWINNER/framework/tree/develop-yt113-framework/libcedarc/demo/vdecoderDemo
硬件解码核心关键代码
#include <memoryAdapter.h>
#include <vdecoder.h>
// 步骤3
AddVDPlugin();
// 步骤4
struct ScMemOpsS* memops = MemAdapterGetOpsS();
CdcMemOpen(memops);
VideoDecoder* vdec = CreateVideoDecoder();
VideoStreamInfo videoInfo;
memset(&videoInfo, 0, sizeof(videoInfo));
videoInfo.eCodecFormat = VIDEO_CODEC_FORMAT_MJPEG;
videoInfo.nWidth = width;
videoInfo.nHeight = height;
VConfig vconfig;
memset(&vconfig, 0, sizeof(vconfig));
vconfig.eOutputPixelFormat = PIXEL_FORMAT_NV21;
vconfig.eSecOutputPixelFormat = PIXEL_FORMAT_NV21;
vconfig.nDeInterlaceHoldingFrameBufferNum = 1;
vconfig.nDisplayHoldingFrameBufferNum = 1;
vconfig.nRotateHoldingFrameBufferNum = 0;
vconfig.nDecodeSmoothFrameBufferNum = 1;
vconfig.memops = memops;
vconfig.eCtlAfbcMode = DISABLE_AFBC_ALL_SIZE;
vconfig.eCtlIptvMode = DISABLE_IPTV_ALL_SIZE;
vconfig.nSupportMaxWidth = width;
vconfig.nSupportMaxHeight = height;
InitializeVideoDecoder(vdec, &videoInfo, &vconfig);
// 步骤5
char* pBuf = 0;
int bufSize = 0;
char* pRingBuf = 0;
int ringBufSize = 0;
RequestVideoStreamBuffer(vdec, jpgsize, &pBuf, &bufSize, &pRingBuf, &ringBufSize, 0);
// copy to vdec sbm
if (bufSize >= jpgsize)
memcpy(pBuf, jpgdata, jpgsize);
else
memcpy(pBuf, jpgdata, bufSize);
memcpy(pRingBuf, jpgdata + bufSize, jpgsize - bufSize);
VideoStreamDataInfo dataInfo;
memset(&dataInfo, 0, sizeof(dataInfo));
dataInfo.pData = pBuf;
dataInfo.nLength = jpgsize;
dataInfo.bIsFirstPart = 1;
dataInfo.bIsLastPart = 1;
SubmitVideoStreamData(vdec, &dataInfo, 0);
// 步骤6
DecodeVideoStream(vdec, 1/*endofstream*/, 0, 0, 0);
VideoPicture* vpic = RequestPicture(vdec, 0);
// 步骤7
yuv420sp2rgb_neon((const unsigned char*)vpic->pData0, (const unsigned char*)vpic->pData1, vpic->nLineStride, width, height, outrgb);
输出的rgb数据,可以再利用 stb_image_write 写入新的jpg图片,下载到本地查看解码是否正常
stbi_write_jpg("testout.jpg", width, height, 3, outrgb, 90);
./jpgd 1920x1080.jpg
sh-4.4# ./jpgd 1920x1080.jpg 2>&1 | grep jpgd
jpgd stbi 143.520
jpgd stbi 144.460
jpgd stbi 143.488
jpgd stbi 144.909
jpgd stbi 178.350
jpgd stbi 144.221
jpgd stbi 143.416
jpgd stbi 144.427
jpgd vdec 66.448
jpgd vdec 62.489
jpgd vdec 63.168
jpgd vdec 63.128
jpgd vdec 62.299
jpgd vdec 63.151
jpgd vdec 65.188
jpgd vdec 78.007
对1080p图片,分别使用 stb_image 和 cedarc 硬件解码库做解码测试,循环调用记录最低耗时
可以看到米尔-全志T113-i开发板的jpg硬件解码能有效加速 50% 以上
#include <stdio.h>
#include <string>
#include <vector>
#include <sys/stat.h>
#include <sys/time.h>
#include <sys/types.h>
#include <unistd.h>
#define STB_IMAGE_IMPLEMENTATION
#define STBI_NEON
#include "stb_image.h"
#define STB_IMAGE_WRITE_IMPLEMENTATION
#include "stb_image_write.h"
// aw header
void yuv420sp2rgb_neon(const unsigned char* _yptr, const unsigned char* _vuptr, int stride, int w, int h, unsigned char* rgb)
// 此处省略 yuv420sp 转rgb neon加速代码
// 具体可参考 ncnn项目中的相关实现
double get_current_time()
struct timeval tv;
gettimeofday(&tv, NULL);
return tv.tv_sec * 1000.0 + tv.tv_usec / 1000.0;
class jpeg_decoder_aw
public:
jpeg_decoder_aw(const unsigned char* jpgdata, size_t jpgsize);
int ping();
int decode(unsigned char* outrgb);
protected:
const unsigned char* jpgdata;
size_t jpgsize;
public:
int corrupted; // 0=fine
int width;
int height;
int components; // 1=gray 3=yuv
int sampling_factor; // 0=444 1=422h 2=422v 3=420 4=400
int progressive;
jpeg_decoder_aw::jpeg_decoder_aw(const unsigned char* _jpgdata, size_t _jpgsize)
jpgdata = _jpgdata;
jpgsize = _jpgsize;
corrupted = 1;
width = 0;
height = 0;
components = 0;
sampling_factor = -1;
progressive = 0;
int jpeg_decoder_aw::ping()
if (!jpgdata || jpgsize < 4)
return -1;
// jpg magic
if (jpgdata[0] != 0xFF || jpgdata[1] != 0xD8)
return -1;
// parse jpg for width height components sampling-factor progressive
// 此处省略解析 exif 部分代码
if (corrupted)
return -1;
return 0;
int jpeg_decoder_aw::decode(unsigned char* outrgb)
if (!outrgb)
return -1;
// corrupted file
if (corrupted)
return -1;
// progressive not supported
if (progressive)
return -1;
CdcMemOpen(memops);
VConfig vconfig;
// PIXEL_FORMAT_NV21 = 5
char* pBuf = 0;
int bufSize = 0;
char* pRingBuf = 0;
// copy to vdec sbm
else
ReturnPicture(vdec, vpic);
DestroyVideoDecoder(vdec);
CdcMemClose(memops);
return 0;
int main(int argc, char** argv)
const char* path = argc >= 2 ? argv[1] : "in.jpg";
AddVDPlugin();
// read file
FILE* fp = fopen(path, "rb");
rewind(fp);
buf.resize(size);
fclose(fp);
for (int j = 0; j < 8; j++)
double t0 = get_current_time();
int w;
int h;
int c;
double t1 = get_current_time();
stbi_image_free(pixeldata);
fprintf(stderr, "jpgd stbi %.3f\n", t1-t0);
std::vector<unsigned char> outrgb;
jpeg_decoder_aw jpg_decoder(buf.data(), buf.size());
jpg_decoder.ping();
const int width = jpg_decoder.width;
const int height = jpg_decoder.height;
outrgb.resize(width * height * 3);
jpg_decoder.decode(outrgb.data());
fprintf(stderr, "jpgd vdec %.3f\n", t1-t0);
if (j == 7)
// save to out image
stbi_write_jpg("testout.jpg", width, height, 3, outrgb.data(), 90);
return 0;
更多回帖
