内存4G,拉12路流,板子会不定期异常重启,并且重启后会挂死,串口网口均无法连接
[ 44.931588] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:10 count 1 cur_task 0000000086e5c3fa id 2931
[ 44.934518] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:7 count 1 cur_task 00000000bbb691f4 id 2929
[ 44.934617] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:4 count 1 cur_task 000000001c6cd6bb id 2930
[ 132.379315] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:11 count 1 cur_task 0000000006f83d56 id 14877
[ 132.379409] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:9 count 2 cur_task 00000000a3466305 id 14874
[ 132.379853] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:10 count 2 cur_task 00000000e5fc0195 id 14876
[ 132.379910] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:12 count 1 cur_task 000000005c7d7a55 id 14878
[ 132.379935] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2659 session 2659:7 count 2 cur_task 00000000414b939c id 14873
[ 170.053722] rkvdec2_ccu_link_timeout_work:1566: task timeout ---------------------拉流重启
PANIC at PC : 0x00000000000602a8DDR V1.09 a930779e06 typ 22/11/21-17:50:56
LPDDR4, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0xff
CH0 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH1 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH2 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH3 RX Vref:27.7%, TX Vref:12.2%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc060f28d70-220414 #zyf (Apr 18 2022 - 18:13:34)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 2
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 181.265 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-499-ge63a16361:derrick.huang
NOTICE: BL31: Built : 10:58:38, Jan 10 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: f2154d648)(sdk version: .xml) (Dec 11 2023 - 16:58:52 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: eda19000
Relocation fdt: eb9fa5f8 - eb9fecd0
CR: M/C/I
Using default environment
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v2
boot mode: None
=================begin===================
163234 bytes read in 14 ms (11.1 MiB/s)
DTB(Distro): rk-kernel.dtb
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 1000000 uV
vdd_cpu_big1_s0 1000000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 812500 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
Firefly fixed_regulator_set_enable: dev='vcc-hub-reset-regulator', enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev='vbus-typec0-pwr-en-regulator', enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev='vbus-typec1-pwr-en-regulator', enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev='vcc-sdcard-pwr-en-regulator', enable=1, delay=0, has_gpio=0
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
Could not find baseparameter partition
Model: Firefly AIO-3588Q MIPI101(Linux)
No resource partition
No file: logo.bmp
512 bytes read in 7 ms (71.3 KiB/s)
logo(Distro): logo.bmp
6220854 bytes read in 42 ms (141.3 MiB/s)
Rockchip UBOOT DRM driver version: v1.0.1
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary plane: 3
vp2 have layer nr:2[6 8 ], primary plane: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
hdmi@fde80000 disconnected
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 594000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth0: ethernet@fe1b0000, eth1: ethernet@fe1c0000
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Waring: Could not find security partition
Not AVB images, AVB skip
No valid android hdr
Android image load failed
Android boot failed, error -1.
FIT: No FIT image
Unknown command 'bootrkp' - try 'help'
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:3...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
104 bytes read in 7 ms (13.7 KiB/s)
FIREFLY: use /rk-kernel.dtb
1: rk-kernel.dtb linux-5.10.110
Retrieving file: /initrd-5.10.110
9233322 bytes read in 58 ms (151.8 MiB/s)
Retrieving file: /Image-5.10.110
44507648 bytes read in 306 ms (138.7 MiB/s)
Retrieving file: /rk-kernel.dtb
163234 bytes read in 15 ms (10.4 MiB/s)
Fdt Ramdisk skip relocation
Booting using the fdt blob at 0x08300000
'reserved-memory' cma: addr=10000000 size=10000000
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000832ada1
No file: logo_kernel.bmp
logo(Distro): logo_kernel.bmp
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000)
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 4162.643 ms
Starting kernel ...
[ 4.857905] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 4.857928] Linux version 5.10.110 (zhut@indgw) (kernel commit id: f2154d648) (sdk version: .xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #3 SMP Mon Dec 11 17:04:52 CST 2023
[ 4.865589] Machine model: Firefly AIO-3588Q MIPI101(Linux)
[ 4.865672] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options '')
[ 4.915481] printk: bootconsole [uart8250] enabled
[ 4.922106] efi: UEFI not found.
[ 4.929525] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[ 4.941851] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 4.950159] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 5.025532] Zone ranges:
[ 5.028198] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 5.034484] DMA32 empty
[ 5.037447] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 5.043729] Movable zone start for each node
[ 5.048058] Early memory node ranges
[ 5.051739] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 5.058037] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 5.064353] node 0: [mem 0x00000001f0000000-0x00000001ffffffff]
[ 5.070696] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 5.102357] psci: probing for conduit method from DT.
[ 5.107553] psci: PSCIv1.1 detected in firmware.
[ 5.112170] psci: Using standard PSCI v0.2 function IDs
[ 5.117421] psci: Trusted OS migration not required
[ 5.122404] psci: SMC Calling Convention v1.2
[ 5.127299] percpu: Embedded 32 pages/cpu s93352 r8192 d29528 u131072
[ 5.134057] Detected VIPT I-cache on CPU0
[ 5.138189] CPU features: detected: GIC system register CPU interface
[ 5.144686] CPU features: detected: Virtualization Host Extensions
[ 5.150936] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 5.157979] alternatives: patching kernel code
[ 5.164755] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 5.171814] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/mmc@fe2e0000 androidboot.verifiedbootstate=orange ro rootwait ear lycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_poo l=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 5.210816] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 5.219140] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 5.226948] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 5.239681] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 5.281870] Memory: 3688444K/4175872K available (22848K kernel code, 3848K rwdata, 8916K rodata, 7744K init, 678K bss, 225284K reserved, 262144K cma-reserved)
[ 5.296256] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 5.302964] ftrace: allocating 69291 entries in 271 pages
[ 5.410433] ftrace: allocated 271 pages with 5 groups
[ 5.415768] rcu: Hierarchical RCU implementation.
[ 5.420562] rcu: RCU event tracing is enabled.
[ 5.425118] Rude variant of Tasks RCU enabled.
[ 5.429768] Tracing variant of Tasks RCU enabled.
[ 5.434653] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 5.447484] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 5.454991] GICv3: GIC: Using split EOI/Deactivate mode
[ 5.460251] GICv3: 480 SPIs implemented
[ 5.464156] GICv3: 0 Extended SPIs implemented
[ 5.468692] GICv3: Distributor has no Range Selector support
[ 5.474483] GICv3: 16 PPIs implemented
[ 5.478464] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 5.485497] ITS [mem 0xfe640000-0xfe65ffff]
[ 5.489715] ITS@0x00000000fe640000: allocated 8192 Devices @1f0220000 (indirect, esz 8, psz 64K, shr 0)
[ 5.499117] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @1f0230000 (flat, esz 2, psz 64K, shr 0)
[ 5.509743] ITS: using cache flushing for cmd queue
[ 5.514657] ITS [mem 0xfe660000-0xfe67ffff]
[ 5.518912] ITS@0x00000000fe660000: allocated 8192 Devices @1f0250000 (indirect, esz 8, psz 64K, shr 0)
[ 5.528557] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1f0260000 (flat, esz 2, psz 64K, shr 0)
[ 5.539044] ITS: using cache flushing for cmd queue
[ 5.544042] GICv3: using LPI property table @0x00000001f0270000
[ 5.550269] GIC: using cache flushing for LPI property table
[ 5.556017] GICv3: CPU0: using allocated LPI pending table @0x00000001f0280000
[ 5.563546] random: get_random_bytes called from start_kernel+0x3f0/0x65c with crng_init=0
[ 5.675550] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 5.690877] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 5.702423] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 5.711968] Console: colour dummy device 80x25
[ 5.716736] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 5.727693] pid_max: default: 32768 minimum: 301
[ 5.732702] LSM: Security Framework initializing
[ 5.737705] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 5.745640] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 5.755635] rcu: Hierarchical SRCU implementation.
[ 5.761701] Platform MSI: msi-controller@fe640000 domain created
[ 5.768152] Platform MSI: msi-controller@fe660000 domain created
[ 5.774874] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 5.783764] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 5.792698] EFI services will not be available.
[ 5.797851] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 5.811007] Detected VIPT I-cache on CPU1
[ 5.811033] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 5.811048] GICv3: CPU1: using allocated LPI pending table @0x00000001f0290000
[ 5.811089] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 5.819400] Detected VIPT I-cache on CPU2
[ 5.819422] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 5.819436] GICv3: CPU2: using allocated LPI pending table @0x00000001f02a0000
[ 5.819473] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 5.827754] Detected VIPT I-cache on CPU3
[ 5.827773] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 5.827786] GICv3: CPU3: using allocated LPI pending table @0x00000001f02b0000
[ 5.827822] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 5.836088] CPU features: detected: Spectre-v4
[ 5.836091] CPU features: detected: Spectre-BHB
[ 5.836093] Detected PIPT I-cache on CPU4
[ 5.836102] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 5.836110] GICv3: CPU4: using allocated LPI pending table @0x00000001f02c0000
[ 5.836131] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 5.844351] Detected PIPT I-cache on CPU5
[ 5.844361] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 5.844368] GICv3: CPU5: using allocated LPI pending table @0x00000001f02d0000
[ 5.844391] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 5.852615] Detected PIPT I-cache on CPU6
[ 5.852625] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 5.852632] GICv3: CPU6: using allocated LPI pending table @0x00000001f02e0000
[ 5.852653] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 5.860883] Detected PIPT I-cache on CPU7
[ 5.860893] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 5.860900] GICv3: CPU7: using allocated LPI pending table @0x00000001f02f0000
[ 5.860922] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 5.860978] smp: Brought up 1 node, 8 CPUs
[ 6.061007] SMP: Total of 8 processors activated.
[ 6.066045] CPU features: detected: Privileged Access Never
[ 6.071992] CPU features: detected: User Access Override
[ 6.077741] CPU features: detected: 32-bit EL0 Support
[ 6.083246] CPU features: detected: Common not Private translations
[ 6.089982] CPU features: detected: RAS Extension Support
[ 6.095782] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 6.104997] CPU features: detected: CRC32 instructions
[ 6.110527] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 6.118037] CPU features: detected: RCpc load-acquire (LDAPR)
[ 6.124292] CPU: All CPU(s) started at EL2
[ 6.129693] devtmpfs: initialized
[ 6.139606] Registered cp15_barrier emulation handler
[ 6.144932] Registered setend emulation handler
[ 6.149757] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 6.160122] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 6.167625] pinctrl core: initialized pinctrl subsystem
[ 6.173260] DMI not present or invalid.
[ 6.177422] NET: Registered protocol family 16
[ 6.182809] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 6.190440] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 6.198725] audit: initializing netlink subsys (disabled)
[ 6.204488] audit: type=2000 audit(0.316:1): state=initialized audit_enabled=0 res=1
[ 6.204849] thermal_sys: Registered thermal governor 'fair_share'
[ 6.212608] thermal_sys: Registered thermal governor 'step_wise'
[ 6.219034] thermal_sys: Registered thermal governor 'user_space'
[ 6.225400] thermal_sys: Registered thermal governor 'power_allocator'
[ 6.231944] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 6.247329] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 6.255757] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 6.264301] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 6.272790] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 6.281312] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 6.289770] cpuidle: using governor menu
[ 6.293921] Registered FIQ tty driver
[ 6.297865] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 6.305113] ASID allocator initialised with 65536 entries
[ 6.311671] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 6.317192] ramoops: console 0x80000@0x0000000000130000
[ 6.322748] ramoops: pmsg 0x50000@0x00000000001b0000
[ 6.328216] printk: console [ramoops-1] enabled
[ 6.332995] pstore: Registered ramoops as persistent store backend
[ 6.339499] ramoops: using 0xf0000@0x110000, ecc: 0
[ 6.370723] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 6.377768] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 6.384853] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 6.391925] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 6.399018] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 6.405974] rockchip-pinctrl pinctrl: probed pinctrl
[ 6.417082] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 6.424062] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 6.431121] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 6.438215] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 6.502434] raid6: neonx8 gen() 6902 MB/s
[ 6.562496] raid6: neonx8 xor() 5404 MB/s
[ 6.622560] raid6: neonx4 gen() 6733 MB/s
[ 6.682625] raid6: neonx4 xor() 5662 MB/s
[ 6.742687] raid6: neonx2 gen() 6451 MB/s
[ 6.802752] raid6: neonx2 xor() 5370 MB/s
[ 6.862820] raid6: neonx1 gen() 5277 MB/s
[ 6.922883] raid6: neonx1 xor() 4480 MB/s
[ 6.982948] raid6: int64x8 gen() 3213 MB/s
[ 7.043015] raid6: int64x8 xor() 1902 MB/s
[ 7.103078] raid6: int64x4 gen() 3684 MB/s
[ 7.163142] raid6: int64x4 xor() 1905 MB/s
[ 7.223204] raid6: int64x2 gen() 3067 MB/s
[ 7.283266] raid6: int64x2 xor() 1655 MB/s
[ 7.343326] raid6: int64x1 gen() 2517 MB/s
[ 7.403384] raid6: int64x1 xor() 1320 MB/s
[ 7.407912] raid6: using algorithm neonx8 gen() 6902 MB/s
[ 7.413559] raid6: .... xor() 5404 MB/s, rmw enabled
[ 7.418789] raid6: using neon recovery algorithm
[ 7.424491] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 7.430229] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 7.436344] fiq_debugger_probe: could not install nmi irq handler
[[ 7.442798] printk: console [ttyFIQ0] enabled
[ 7.451713] printk: bootconsole [uart8250] disabled
[ 7.456960] Registered fiq debugger ttyFIQ0
[ 7.457238] vcc5v0_sys: supplied by vcc12v_dcin
[ 7.457314] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 7.457381] vcc5v0_usb: supplied by vcc12v_dcin
[ 7.457450] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 7.457529] vcc5v0_host: supplied by vcc5v0_usb
[ 7.457797] vcc5v0_host3: supplied by vcc5v0_usb
[ 7.457871] vcc_sata_pwr_en: supplied by vcc12v_dcin
[ 7.463727] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 7.463946] iommu: Default domain type: Passthrough
[ 7.464000] rk_iommu fdab9000.iommu: version = 2
[ 7.464248] rk_iommu fdb50800.iommu: version = 2
[ 7.464431] rk_iommu fdb60f00.iommu: version = 2
[ 7.464559] rk_iommu fdb70f00.iommu: version = 2
[ 7.464682] rk_iommu fdb90480.iommu: version = 2
[ 7.464822] rk_iommu fdba0800.iommu: version = 2
[ 7.464959] rk_iommu fdba4800.iommu: version = 2
[ 7.465096] rk_iommu fdba8800.iommu: version = 2
[ 7.465238] rk_iommu fdbac800.iommu: version = 2
[ 7.465376] rk_iommu fdbb0800.iommu: version = 2
[ 7.465513] rk_iommu fdbdf000.iommu: version = 2
[ 7.465712] rk_iommu fdbef000.iommu: version = 2
[ 7.465927] rk_iommu fdc38700.iommu: version = 2
[ 7.466149] rk_iommu fdc48700.iommu: version = 2
[ 7.466247] rk_iommu fdd97e00.iommu: version = 2
[ 7.466459] usbcore: registered new interface driver usbfs
[ 7.466471] usbcore: registered new interface driver hub
[ 7.466482] usbcore: registered new device driver usb
[ 7.466507] mc: Linux media interface: v0.10
[ 7.466515] videodev: Linux video capture interface: v2.00
[ 7.466531] pps_core: LinuxPPS API ver. 1 registered
[ 7.466534] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 7.466540] PTP clock support registered
[ 7.466721] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 7.466748] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 7.467455] Advanced Linux Sound Architecture Driver Initialized.
[ 7.467596] Bluetooth: Core ver 2.22
[ 7.467606] NET: Registered protocol family 31
[ 7.467608] Bluetooth: HCI device and connection manager initialized
[ 7.467612] Bluetooth: HCI socket layer initialized
[ 7.467616] Bluetooth: L2CAP socket layer initialized
[ 7.467621] Bluetooth: SCO socket layer initialized
[ 7.468862] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 7.468865] rockchip-cpuinfo cpuinfo: Serial : e9e5db0d91301df3
[ 7.469086] clocksource: Switched to clocksource arch_sys_counter
[ 7.681895] NET: Registered protocol family 2
[ 7.681966] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 7.682829] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[ 7.682875] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 7.683014] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 7.683351] TCP: Hash tables configured (established 32768 bind 32768)
[ 7.683392] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 7.683463] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 7.683569] NET: Registered protocol family 1
[ 7.683720] RPC: Registered named UNIX socket transport module.
[ 7.683723] RPC: Registered udp transport module.
[ 7.683725] RPC: Registered tcp transport module.
[ 7.683728] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.684035] PCI: CLS 0 bytes, default 64
[ 7.684274] Trying to unpack rootfs image as initramfs...
[ 7.858419] Freeing initrd memory: 9016K
[ 7.858950] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 7.859337] kvm [1]: IPA Size Limit: 40 bits
[ 7.859348] kvm [1]: GICv3: no GICV resource entry
[ 7.859351] kvm [1]: disabling GICv2 emulation
[ 7.859354] kvm [1]: GIC system register CPU interface enabled
[ 7.859463] kvm [1]: vgic interrupt IRQ9
[ 7.859594] kvm [1]: VHE mode initialized successfully
[ 7.861371] Initialise system trusted keyrings
[ 7.861418] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 7.862933] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.863113] NFS: Registering the id_resolver key type
[ 7.863121] Key type id_resolver registered
[ 7.863124] Key type id_legacy registered
[ 7.863129] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 7.863502] Key type cifs.spnego registered
[ 7.863507] Key type cifs.idmap registered
[ 7.863511] ntfs: driver 2.1.32 [Flags: R/O].
[ 7.863550] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 7.863616] fuse: init (API version 7.32)
[ 7.863738] SGI XFS with security attributes, no debug enabled
[ 7.880870] NET: Registered protocol family 38
[ 7.880875] xor: measuring software checksum speed
[ 7.882018] 8regs : 8642 MB/sec
[ 7.882973] 32regs : 10373 MB/sec
[ 7.883682] arm64_neon : 13921 MB/sec
[ 7.883685] xor: using function: arm64_neon (13921 MB/sec)
[ 7.883689] Key type asymmetric registered
[ 7.883693] Asymmetric key parser 'x509' registered
[ 7.883705] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 7.883749] io scheduler mq-deadline registered
[ 7.883754] io scheduler kyber registered
[ 7.889314] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 7.890282] Firefly gpio driver init!
[ 7.890351] Firefly gpio driver register return : 0
[ 7.891040] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node
[ 7.891147] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 7.891175] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 7.891319] iep: Module initialized.
[ 7.891371] mpp_service mpp-srv: 789d8d341
[ 7.891375] mpp_service mpp-srv: probe start
[ 7.891419] rk-pcie fe190000.pcie: missing legacy IRQ resource
[ 7.891440] rk-pcie fe190000.pcie: IRQ msi not found
[ 7.891448] rk-pcie fe190000.pcie: use outband MSI support
[ 7.891457] rk-pcie fe190000.pcie: Missing *config* reg space
[ 7.891473] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges:
[ 7.891481] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 7.891497] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff -> 0x00f4000000
[ 7.891503] rk-pcie fe170000.pcie: IRQ msi not found
[ 7.891507] rk-pcie fe170000.pcie: use outband MSI support
[ 7.891511] rk-pcie fe170000.pcie: Missing *config* reg space
[ 7.891522] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 7.891530] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[ 7.891547] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000
[ 7.891555] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff -> 0x00f2000000
[ 7.891569] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff -> 0x00f2100000
[ 7.891574] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000
[ 7.891596] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff -> 0x00f2200000
[ 7.891601] rk-pcie fe190000.pcie: Missing *config* reg space
[ 7.891615] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000
[ 7.891628] rk-pcie fe190000.pcie: invalid resource
[ 7.891649] rk-pcie fe170000.pcie: Missing *config* reg space
[ 7.891680] rk-pcie fe170000.pcie: invalid resource
[ 7.892228] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 7.892247] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.892400] mpp_vdpu2 fdb50400.vdpu: probe device
[ 7.892483] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 7.892488] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 7.892554] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 7.892698] mpp_vepu2 jpege-ccu: probing start
[ 7.892702] mpp_vepu2 jpege-ccu: probing finish
[ 7.892781] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 7.892789] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.892899] mpp_vepu2 fdba0000.jpege-core: probing start
[ 7.892969] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 7.893028] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 7.893095] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 7.893104] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.893213] mpp_vepu2 fdba4000.jpege-core: probing start
[ 7.893278] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 7.893337] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 7.893402] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 7.893411] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.893538] mpp_vepu2 fdba8000.jpege-core: probing start
[ 7.893602] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 7.893659] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 7.893733] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 7.893741] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.893853] mpp_vepu2 fdbac000.jpege-core: probing start
[ 7.893917] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 7.893976] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 7.894169] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 7.894178] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.894287] mpp-iep2 fdbb0000.iep: probe device
[ 7.894370] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 7.894423] mpp-iep2 fdbb0000.iep: probing finish
[ 7.894577] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 7.894586] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.894744] mpp_jpgdec fdb90000.jpegd: probe device
[ 7.894875] mpp_jpgdec fdb90000.jpegd: probing finish
[ 7.895128] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 7.895164] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 7.895216] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 7.895225] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.895409] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 7.895486] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 7.895489] rkvdec2_init:1010: No niu aclk reset resource define
[ 7.895493] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 7.895495] rkvdec2_init:1013: No niu hclk reset resource define
[ 7.895510] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
[ 7.895552] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 7.895555] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 7.895683] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 7.895686] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 7.895689] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 7.895692] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 7.895695] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 7.895714] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 7.895774] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
[ 7.895782] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.895954] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 7.896028] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 7.896030] rkvdec2_init:1010: No niu aclk reset resource define
[ 7.896034] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 7.896036] rkvdec2_init:1013: No niu hclk reset resource define
[ 7.896049] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
[ 7.896079] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 7.896094] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 7.896240] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 7.896243] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 7.896245] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 7.896248] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 7.896251] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 7.896271] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 7.896393] mpp_rkvenc2 rkvenc-ccu: probing start
[ 7.896397] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 7.896475] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 7.896483] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.896621] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 7.896633] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 7.896729] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 7.896796] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 7.896833] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 7.896841] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.897026] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 7.897038] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 7.897153] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 7.897213] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 7.897573] mpp_av1dec: Adding child /av1d@fdc70000
[ 7.897622] mpp_av1dec: register device av1d-master
[ 7.897642] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 7.897655] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu
[ 7.897677] mpp_av1dec av1d-master: Adding to iommu group 15
[ 7.897686] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.897853] mpp_av1dec av1d-master: probing start
[ 7.897988] mpp_av1dec av1d-master: probing finish
[ 7.898009] mpp_service mpp-srv: probe success
[ 7.902369] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 7.902376] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 7.902952] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 7.902957] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 7.903509] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 7.903515] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 7.903772] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 7.903809] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 7.903842] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 7.903876] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 7.903907] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 7.904255] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 7.904567] firefly-gpio: -2 is invalid
[ 7.905109] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 7.905359] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 28, base_baud = 1500000) is a 16550A
[ 7.905652] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 92, base_baud = 1500000) is a 16550A
[ 7.905858] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 93, base_baud = 1500000) is a 16550A
[ 7.906054] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 94, base_baud = 1500000) is a 16550A
[ 7.906904] random: fast init done
[ 7.906993] random: crng init done
[ 7.907440] rockchip-vop2 fdd90000.vop: Adding to iommu group 14
[ 7.907452] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.911679] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 7.911689] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 7.911699] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 7.911705] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 7.911760] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -517
[ 7.911913] [drm] failed to init overlay plane Cluster0-win1
[ 7.911936] [drm] failed to init overlay plane Cluster1-win1
[ 7.911956] [drm] failed to init overlay plane Cluster2-win1
[ 7.911978] [drm] failed to init overlay plane Cluster3-win1
[ 7.918280] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops)
[ 7.918730] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 7.918848] rockchip-drm display-subsystem: bound fde80000.hdmi (ops dw_hdmi_rockchip_ops)
[ 7.919190] rockchip-drm display-subsystem: route-hdmi0: failed to get logo,offset
[ 7.919197] rockchip-drm display-subsystem: can't not find any logo display
[ 7.919202] rockchip-drm display-subsystem: failed to show kernel logo
[ 7.919236] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 7.919270] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 7.919601] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 7.924119] brd: module loaded
[ 7.926293] loop: module loaded
[ 7.926438] zram: Added device: zram0
[ 7.926547] lkdtm: No crash points registered, enable through debugfs
[ 7.926853] system_heap: orders[0] = 6
[ 7.926857] system_heap: orders[1] = 4
[ 7.926860] system_heap: orders[2] = 0
[ 7.927805] rockchip-spi feb10000.spi: no high_speed pinctrl state
[ 7.928195] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 7.928998] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 7.929124] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 7.930467] vdd_gpu_s0: supplied by vcc5v0_sys
[ 7.931452] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 7.931974] vdd_log_s0: supplied by vcc5v0_sys
[ 7.932509] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 7.933079] vdd_ddr_s0: supplied by vcc5v0_sys
[ 7.933412] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 7.933914] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 7.934363] vcc_3v3_s3: supplied by vcc5v0_sys
[ 7.934788] vddq_ddr_s0: supplied by vcc5v0_sys
[ 7.935292] vcc_1v8_s3: supplied by vcc5v0_sys
[ 7.935754] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 7.936256] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 7.936695] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 7.937137] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 7.937574] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 7.938093] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 7.938655] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 7.939157] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 7.939651] vcc_3v3_s0: supplied by vcc5v0_sys
[ 7.940092] vccio_sd_s0: supplied by vcc5v0_sys
[ 7.940550] pldo6_s3: supplied by vcc5v0_sys
[ 7.940957] rk806 spi2.0: no sleep-setting state
[ 7.940961] rk806 spi2.0: no reset-setting pinctrl state
[ 7.940964] rk806 spi2.0: no dvs-setting pinctrl state
[ 7.942544] register firefly_spi_init spi return v = :0
[ 7.942783] wireguard: allowedips self-tests: pass
[ 7.946385] wireguard: nonce counter self-tests: pass
[ 8.096904] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.096909] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.122443] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.122447] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.149111] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.149115] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.175780] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.202444] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.202448] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.207239] wireguard: ratelimiter self-tests: pass
[ 8.207322] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 8.207326] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 8.207439] (null): ------- begin register mdio bus, phy_mask[0]---------
[ 8.210805] mdio_bus fixed-0: Fixed MDIO Bus already probed
[ 8.211126] ------ rtk_gsw_probe ------
[ 8.211130] ------ can not find mdiobus stmmac-1 ------
[ 8.211150] tun: Universal TUN/TAP device driver, 1.6
[ 8.211239] CAN device driver interface
[ 8.211944] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 8.212070] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
[ 8.212075] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 8.212080] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x47).
[ 8.212083] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 8.212087] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
[ 8.212097] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 8.212103] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
[ 8.212107] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
[ 8.212116] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
[ 8.212331] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_RXID
[ 8.212405] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 8.212409] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 8.212422] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 8.212425] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 8.212429] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 8.212432] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 8.212461] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 8.212464] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 8.212469] rk_gmac-dwmac fe1b0000.ethernet: Enabled Flow TC (entries=2)
[ 8.212472] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 8.212476] rk_gmac-dwmac fe1b0000.ethernet: Using 32 bits DMA width
[ 8.212497] (null): ------- begin register mdio bus, phy_mask[ffffffff]---------
[ 8.229114] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
[ 8.345754] mdio_bus stmmac-0: stmmac already probed
[ 8.345759] mdio_bus stmmac-0: find addr 1 from dts
[ 8.348880] mdio_bus stmmac-0: registered phy at address 1
[ 8.349426] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 8.349530] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
[ 8.349535] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 8.349540] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x10).
[ 8.349544] rk_gmac-dwmac fe1c0000.ethernet: RX delay(0x5).
[ 8.349550] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 8.349555] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 8.349560] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 8.349569] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 8.349783] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII
[ 8.349848] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 8.349852] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 8.349857] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 8.349861] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 8.349864] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 8.349867] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 8.349890] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 8.349894] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 8.349898] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 8.349902] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 8.349906] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 8.349915] (null): ------- begin register mdio bus, phy_mask[ffffffff]---------
[ 8.422421] mdio_bus stmmac-1: stmmac already probed
[ 8.422425] mdio_bus stmmac-1: find addr 0 from dts
[ 8.425444] mdio_bus stmmac-1: registered phy at address 0
[ 8.426128] PPP generic driver version 2.4.2
[ 8.426202] PPP BSD Compression module registered
[ 8.426207] PPP Deflate Compression module registered
[ 8.426219] PPP MPPE Compression module registered
[ 8.426223] NET: Registered protocol family 24
[ 8.426273] usbcore: registered new interface driver asix
[ 8.426314] usbcore: registered new interface driver ax88179_178a
[ 8.426325] usbcore: registered new interface driver cdc_ether
[ 8.426336] usbcore: registered new interface driver net1080
[ 8.426347] usbcore: registered new interface driver cdc_subset
[ 8.426357] usbcore: registered new interface driver zaurus
[ 8.426371] usbcore: registered new interface driver cdc_ncm
[ 8.426382] usbcore: registered new interface driver qmi_wwan_q
[ 8.426393] usbcore: registered new interface driver qmi_wwan
[ 8.439557] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.439565] ehci-pci: EHCI PCI platform driver
[ 8.439587] ehci-platform: EHCI generic platform driver
[ 8.441749] ehci-platform fc800000.usb: EHCI Host Controller
[ 8.441799] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[ 8.441849] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
[ 8.455752] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 8.455817] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.455822] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.455825] usb usb1: Product: EHCI Host Controller
[ 8.455829] usb usb1: Manufacturer: Linux 5.10.110 ehci_hcd
[ 8.455832] usb usb1: SerialNumber: fc800000.usb
[ 8.455974] hub 1-0:1.0: USB hub found
[ 8.455985] hub 1-0:1.0: 1 port detected
[ 8.458288] ehci-platform fc880000.usb: EHCI Host Controller
[ 8.458340] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
[ 8.458382] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
[ 8.469091] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 8.469144] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.469149] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.469152] usb usb2: Product: EHCI Host Controller
[ 8.469156] usb usb2: Manufacturer: Linux 5.10.110 ehci_hcd
[ 8.469159] usb usb2: SerialNumber: fc880000.usb
[ 8.469279] hub 2-0:1.0: USB hub found
[ 8.469289] hub 2-0:1.0: 1 port detected
[ 8.469596] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 8.469603] ohci-platform: OHCI generic platform driver
[ 8.469724] ohci-platform fc840000.usb: Generic Platform OHCI controller
[ 8.469772] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
[ 8.469805] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
[ 8.529811] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 8.529815] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.529819] usb usb3: Product: Generic Platform OHCI controller
[ 8.529823] usb usb3: Manufacturer: Linux 5.10.110 ohci_hcd
[ 8.529826] usb usb3: SerialNumber: fc840000.usb
[ 8.529943] hub 3-0:1.0: USB hub found
[ 8.529954] hub 3-0:1.0: 1 port detected
[ 8.530168] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 8.530218] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
[ 8.530249] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
[ 8.589811] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 8.589815] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.589818] usb usb4: Product: Generic Platform OHCI controller
[ 8.589822] usb usb4: Manufacturer: Linux 5.10.110 ohci_hcd
[ 8.589825] usb usb4: SerialNumber: fc8c0000.usb
[ 8.589941] hub 4-0:1.0: USB hub found
[ 8.589952] hub 4-0:1.0: 1 port detected
[ 8.590369] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 8.590419] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[ 8.590497] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000082002010010
[ 8.590514] xhci-hcd xhci-hcd.5.auto: irq 120, io mem 0xfc000000
[ 8.590609] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.590613] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.590616] usb usb5: Product: xHCI Host Controller
[ 8.590620] usb usb5: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.590623] usb usb5: SerialNumber: xhci-hcd.5.auto
[ 8.590741] hub 5-0:1.0: USB hub found
[ 8.590752] hub 5-0:1.0: 1 port detected
[ 8.590834] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 8.590875] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[ 8.590882] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 8.590901] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.590933] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.590937] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.590940] usb usb6: Product: xHCI Host Controller
[ 8.590944] usb usb6: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.590947] usb usb6: SerialNumber: xhci-hcd.5.auto
[ 8.591060] hub 6-0:1.0: USB hub found
[ 8.591069] hub 6-0:1.0: 1 port detected
[ 8.591202] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 8.591249] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 7
[ 8.591308] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 8.591326] xhci-hcd xhci-hcd.6.auto: irq 121, io mem 0xfcd00000
[ 8.591410] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.591414] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.591418] usb usb7: Product: xHCI Host Controller
[ 8.591421] usb usb7: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.591424] usb usb7: SerialNumber: xhci-hcd.6.auto
[ 8.591538] hub 7-0:1.0: USB hub found
[ 8.591547] hub 7-0:1.0: 1 port detected
[ 8.591628] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 8.591670] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 8
[ 8.591675] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[ 8.591693] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.591724] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.591728] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.591731] usb usb8: Product: xHCI Host Controller
[ 8.591734] usb usb8: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.591738] usb usb8: SerialNumber: xhci-hcd.6.auto
[ 8.591848] hub 8-0:1.0: USB hub found
[ 8.591858] hub 8-0:1.0: 1 port detected
[ 8.591995] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode
[ 8.592000] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 8.592045] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 9
[ 8.592119] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 8.592134] xhci-hcd xhci-hcd.7.auto: irq 122, io mem 0xfc400000
[ 8.592226] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.592230] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.592233] usb usb9: Product: xHCI Host Controller
[ 8.592236] usb usb9: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.592240] usb usb9: SerialNumber: xhci-hcd.7.auto
[ 8.592355] hub 9-0:1.0: USB hub found
[ 8.592365] hub 9-0:1.0: 1 port detected
[ 8.592451] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 8.592531] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 10
[ 8.592555] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[ 8.592653] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.592778] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.592792] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.592803] usb usb10: Product: xHCI Host Controller
[ 8.592813] usb usb10: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.592823] usb usb10: SerialNumber: xhci-hcd.7.auto
[ 8.593241] hub 10-0:1.0: USB hub found
[ 8.593280] hub 10-0:1.0: 1 port detected
[ 8.593732] usbcore: registered new inLoading, please wait...
terface driver cdc_acm
[ 8.593744] cdc_acm: USB Abstract Control Mode/dlev/console is Ok
driver for USB modems and ISDN adapters
[ 8.593796] usbcore: registered new interface driver cdc_wdm
[ 8.593893] usbcore: registered new interface driver usbserial_generic
[ 8.593923] usbserial: USB Serial support registered for generic
[ 8.593977] usbcore: restarting version 237
gistered new interface driver ch341
[ 8.594004] usbserial: USB Serial support registered for ch341-uart
[ 8.594059] usbcore: registered new interface driver cp210x
[ 8.594084] usbserial: USB Serial support registered for cp210x
[ 8.594196] usbcore: registered new interface driver usb_ch9344
[ 8.594205] ch9344: USB serial driver for ch9344/ch348.
[ 8.594213] ch9344: V2.1Beta On 2023.11
[ 8.594258] usbcore: registered new interface driver ftdi_sio
[ 8.594284] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 8.594517] usbcore: registered new interface driver keyspan
[ 8.594544] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 8.594570] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 8.594595] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 8.594620] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 8.594680] usbcore: registered new interface driver option
[ 8.594706] usbserial: USB Serial support registered for GSM modem (1-port)
[ 8.595022] usbcore: registered new interface driver oti6858
[ 8.595050] usbserial: USB Serial support registered for oti6858
[ 8.595106] usbcore: registered new interface driver pl2303
[ 8.595131] usbserial: USB Serial support registered for pl2303
[ 8.595201] usbcore: registered new interface driver qcserial
[ 8.595227] usbserial: USB Serial support registered for Qualcomm USB modem
[ 8.595309] usbcore: registered new interface driver sierra
[ 8.595334] usbserial: USB Serial support registered for Sierra USB modem
[ 8.596357] [HXTP] himax_hx83102_init
[ 8.596368] [HXTP] himax_hx83102_probe:Enter
[ 8.596378] [HXTP] Himax common touch panel driver init
[ 8.596504] usbcore: registered new interface driver usbtouchscreen
[ 8.598158] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.3.auto/input/input0
[ 8.598698] i2c /dev entries driver
[ 8.602174] vdd_cpu_big0_s0: supplied by vcc5v0_sys
[ 8.610613] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 8.620130] vdd_npu_s0: supplied by vcc5v0_sys
[ 8.627587] pca953x 6-0023: supply vcc not found, using dummy regulator
[ 8.627705] pca953x 6-0023: using no AI
[ 8.630958] rtc-rx8010 6-0032: registered as rtc0
[ 8.631383] rtc-rx8010 6-0032: setting system clock to 2024-01-29T01:44:14 UTC (1706492654)
[ 8.632336] pca953x 7-0027: supply vcc not found, using dummy regulator
[ 8.632468] pca953x 7-0027: using no AI
[ 8.638417] usbcore: registered new interface driver uvcvideo
[ 8.638429] USB Video Class driver (1.1.1)
[ 8.640184] lm75 6-0049: supply vs not found, using dummy regulator
[ 8.640691] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 8.640706] lm75 6-0049: hwmon0: sensor 'lm75'
[ 8.643329] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 8.643928] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 8.644364] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 8.644455] Bluetooth: HCI UART driver ver 2.3
[ 8.644460] Bluetooth: HCI UART protocol H4 registered
[ 8.644463] Bluetooth: HCI UART protocol ATH3K registered
[ 8.644484] usbcore: registered new interface driver bfusb
[ 8.645095] cpu cpu0: bin=0
[ 8.645266] cpu cpu0: leakage=9
[ 8.646664] cpu cpu0: pvtm=1415
[ 8.646722] cpu cpu0: pvtm-volt-sel=1
[ 8.648570] cpu cpu4: bin=0
[ 8.648739] cpu cpu4: leakage=7
[ 8.655259] cpu cpu4: pvtm=1662
[ 8.659252] cpu cpu4: pvtm-volt-sel=3
[ 8.661853] cpu cpu6: bin=0
[ 8.662021] cpu cpu6: leakage=8
[ 8.668558] cpu cpu6: pvtm=1667
[ 8.672561] cpu cpu6: pvtm-volt-sel=3
[ 8.673982] cpu cpu0: avs=0
[ 8.674471] cpu cpu4: avs=0
[ 8.674962] cpu cpu6: avs=0
[ 8.675126] cpu cpu0: EM: created perf domain
[ 8.675154] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[ 8.675659] cpu cpu4: EM: created perf domain
[ 8.675680] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 8.684254] cpu cpu6: EM: created perf domain
[ 8.684578] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 8.699716] sdhci: Secure Digital Host Controller Interface driver
[ 8.699728] sdhci: Copyright(c) Pierre Ossman
[ 8.699736] Synopsys Designware Multimedia Card Interface Driver
[ 8.700146] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.705385] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 8.705455] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 8.706112] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 8.706465] cryptodev: driver 1.12 loaded.
[ 8.706540] hid: raw HID events driver (C) Jiri Kosina
[ 8.706865] usbcore: registered new interface driver usbhid
[ 8.706876] usbhid: USB HID core driver
[ 8.707155] ashmem: initialized
[ 8.711366] Firefly adc init
[ 8.711376] Firefly adc-->FIREFLY_ADC_SAMPLE_JIFFIES: 16
[ 8.711382] Firefly adc-->MSEC_PER_SEC: 1000
[ 8.711388] Firefly adc-->HZ: 300
[ 8.711638] Firefly adc-->ret: 0
[ 8.711911] optee: probing for conduit method.
[ 8.711935] optee: revision 3.13 (4542e1ef)
[ 8.712389] optee: initialized driver
[ 8.713396] usbcore: registered new interface driver snd-usb-audio
[ 8.731907] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 8.765619] mmc0: Host Software Queue enabled
[ 8.765645] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.766260] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[ 8.766426] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[ 8.766581] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[ 8.766675] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (234:0)
[ 8.769336] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 8.815961] rk3x-i2c feab0000.i2c: timeout, ipd: 0x90, state: 3
[ 8.815982] ES8323 3-0011: i2c recv Failed
[ 8.816089] ES8323: probe of 3-0011 failed with error -110
[ 8.822760] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card0/input1
[ 8.824728] Initializing XFRM netlink socket
[ 8.824973] NET: Registered protocol family 10
[ 8.825594] Segment Routing with IPv6
[ 8.825782] NET: Registered protocol family 17
[ 8.825800] NET: Registered protocol family 15
[ 8.825839] Bridge firewalling registered
[ 8.825846] can: controller area network core
[ 8.825878] NET: Registered protocol family 29
[ 8.825884] can: raw protocol
[ 8.825891] can: broadcast manager protocol
[ 8.825900] can: netlink gateway - max_hops=1
[ 8.826173] Bluetooth: RFCOMM TTY layer initialized
[ 8.826186] Bluetooth: RFCOMM socket layer initialized
[ 8.826199] Bluetooth: RFCOMM ver 1.11
[ 8.826209] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.826214] Bluetooth: BNEP filters: protocol multicast
[ 8.826222] Bluetooth: BNEP socket layer initialized
[ 8.826227] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.826235] Bluetooth: HIDP socket layer initialized
[ 8.826268] 8021q: 802.1Q VLAN Support v1.8
[ 8.826336] [BT_RFKILL]: Enter rfkill_rk_init
[ 8.826343] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 8.826697] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 8.826723] [WLAN_RFKILL]: can't find rockchip,grf property
[ 8.826731] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p
[ 8.826737] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 8.826743] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 8.826761] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 20 flags = 0.
[ 8.826783] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 10, flags = 0.
[ 8.826792] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 8.826798] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 8.826805] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 8.826811] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 8.827239] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 34.
[ 8.827262] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 22.
[ 8.827275] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 21.
[ 8.827288] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0.
[ 8.827296] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 8.827333] [BT_RFKILL]: Request irq for bt wakeup host
[ 8.827390] [BT_RFKILL]: ** disable irq
[ 8.827497] [BT_RFKILL]: bt_default device registered.
[ 8.827578] Key type dns_resolver registered
[ 8.828780] registered taskstats version 1
[ 8.828794] Loading compiled-in X.509 certificates
[ 8.830100] Btrfs loaded, crc32c=crc32c-generic
[ 8.830212] pstore: Using crash dump compression: deflate
[ 8.830999] rga3_core0 fdb60000.rga: Adding to iommu group 2
[ 8.831034] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.831217] rga: rga3_core0, irq = 34, match scheduler
[ 8.831510] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831.
[ 8.831565] rga: rga3_core0 probe successfully
[ 8.831897] rga3_core1 fdb70000.rga: Adding to iommu group 3
[ 8.831916] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.832070] rga: rga3_core1, irq = 35, match scheduler
[ 8.832319] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831.
[ 8.832371] rga: rga3_core1 probe successfully
[ 8.832726] rga: rga2, irq = 36, match scheduler
[ 8.833037] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[ 8.833050] rga: rga2 probe successfully
[ 8.833271] rga_iommu: IOMMU binding successfully, default mapping core[0x1]
[ 8.833413] rga: Module initialized. v1.2.23
[ 8.833421]
[ 8.833427] ********************************************************************
[ 8.833432] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.833438] ** **
[ 8.833443] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 8.833448] ** **
[ 8.833453] ** This means that this kernel is built to expose clk operations **
[ 8.833458] ** such as parent or rate setting, enabling, disabling, etc. **
[ 8.833463] ** to userspace, which may compromise security on your system. **
[ 8.833467] ** **
[ 8.833472] ** If you see this message and you are not debugging the **
[ 8.833477] ** kernel, report this immediately to your vendor! **
[ 8.833481] ** **
[ 8.833486] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.833491] ********************************************************************
[ 8.839107] usb 9-1: new high-speed USB device number 2 using xhci-hcd
[ 8.852839] vendor storage:20190527 ret = 0
[ 8.866005] mali fb000000.gpu: Kernel DDK version g15p0-01eac0
[ 8.866307] usb 1-1: New USB device found, idVendor=3763, idProduct=3c93, bcdDevice= 3.18
[ 8.866316] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.866322] usb 1-1: Product: Android
[ 8.866328] usb 1-1: Manufacturer: Android
[ 8.866333] usb 1-1: SerialNumber: c241f84
[ 8.866349] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 8.866958] mali fb000000.gpu: bin=0
[ 8.867123] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 8.867135] mali fb000000.gpu: leakage=13
[ 8.867179] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
[ 8.867822] option 1-1:1.0: GSM modem (1-port) converter detected
[ 8.868017] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 8.868211] option 1-1:1.1: GSM modem (1-port) converter detected
[ 8.868402] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 8.868588] option 1-1:1.2: GSM modem (1-port) converter detected
[ 8.868766] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 8.873066] mali fb000000.gpu: pvtm=868
[ 8.873687] cdc_ether 1-1:1.3 usb0: register 'cdc_ether' at usb-fc800000.usb-1, CDC Ethernet Device, ea:82:05:73:f9:53
[ 8.874348] mali fb000000.gpu: pvtm-volt-sel=3
[ 8.874534] option 1-1:1.5: GSM modem (1-port) converter detected
[ 8.874649] mali fb000000.gpu: avs=0
[ 8.874690] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 136; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 8.874765] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 8.874959] rockchip-dmc dmc: leakage=33
[ 8.874982] rockchip-dmc dmc: leakage-volt-sel=1
[ 8.875038] mali fb000000.gpu: GPU hardware issue table may need updating:
[ 8.875038] r0p0 status 5 is unknown; treating as r0p0 status 0
[ 8.875046] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 8.875074] mali fb000000.gpu: No priority control manager is configured
[ 8.875200] mali fb000000.gpu: No memory group manager is configured
[ 8.875212] mali fb000000.gpu: Protected memory allocator not available
[ 8.875460] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
[ 8.875478] rockchip-dmc dmc: avs=0
[ 8.875500] rockchip-dmc dmc: current ATF version 0x100
[ 8.875635] rockchip-dmc dmc: normal_rate = 1560000000
[ 8.875646] rockchip-dmc dmc: reboot_rate = 2112000000
[ 8.875656] rockchip-dmc dmc: suspend_rate = 528000000
[ 8.875665] rockchip-dmc dmc: video_4k_rate = 1560000000
[ 8.875675] rockchip-dmc dmc: video_4k_10b_rate = 1560000000
[ 8.875685] rockchip-dmc dmc: video_svep_rate = 1560000000
[ 8.875695] rockchip-dmc dmc: boost_rate = 2112000000
[ 8.875705] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
[ 8.875866] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model'
[ 8.875872] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 8.875939] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 8.875942] rockchip-dmc dmc: performance_rate = 2112000000
[ 8.875950] rockchip-dmc dmc: hdmirx_rate = 2112000000
[ 8.876005] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 8.876012] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 8.876068] mali fb000000.gpu: Error -22, no DT enBegin: Loading essenttial drivers ... ry: mali-simple-power-model.thermal-zone = ''
[ 8.876071] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 8.876621] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 8.876830] rockchip-dmc dmc: could not find power_model node
[ 8.876942] mali fb000000.gpu: Using configured powedone.
Begin: Rrunning /sc ripts/init-premount ... model mali-lodx-power-model, and fallback mali-simple-power-model
[ 8.877002] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 8.877863] mali fb000000done.
Begin: Mounting root file system ... .gpu: Probed as mali0
[ 8.882150] ------ rtk_gsw_probe ------
[ 8.882171] ------ rtl8367 init ------
[ 8.982638] uBegin: Running /scripts/locals-top ... b 9-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 8.982652] usb 9-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.040808] hub 9-1:1.0: USB hub found
[ 9.040862] hub 9-1:1.0: 4 ports detected
[ 10.377092] input: adc-keys adone.
s /devices/platform/aBegin: Rdunning /scripts/local-prec-mount k... eys/input/input2
[ 10.389279] input: gpio-keys as /devices/platform/gpio/input/input3
[ 10.389591] irq: type mismatch, failed to map hwirq-27 for gpio@fd8a0000!
[ 10.390034] typec_fusb302 6-0022: failed to redone.
quest gpio_int_n
[ 10.390145] typec_fusb302: probe of 6-0022 failed with error -2
[ 10.390352] pc9202: sw2001_read(0x1) return 0x1
[ 10.390359] status=0x1
[ 10.390364] ====== i2c detect success watchdog init ======
[ 10.390495] pc9202_wdt_probe(): wd_en_gpio: -2 is invalid
[ 10.391421] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 10.391451] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 10.391460] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 10.391491] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 79,32 bit host data width,256 deep fifo
[ 10.391903] RKNPU fdab0000.npu: Adding to iommu group 0
[ 10.391922] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 10.392027] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 10.393157] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
[ 10.393174] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
[ 10.393191] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
[ 10.393469] [drm] Initialized rknpu 0.8.2 20220829 for fdab0000.npu on minor 1
[ 10.399667] RKNPU fdab0000.npu: bin=0
[ 10.399858] RKNPU fdab0000.npu: leakage=8
[ 10.399911] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
[ 10.406554] RKNPU fdab0000.npu: pvtm=864
[ 10.407616] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 10.415688] RKNPU fdab0000.npu: pvtm-volt-sel=3
[ 10.416633] RKNPU fdab0000.npu: avs=0
[ 10.416820] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 10.424565] RKNPU fdab0000.npu: failed to find power_model node
[ 10.424580] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 10.424590] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 10.426864] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.432696] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 10.433940] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 10.435130] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 405; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '10:50:42', on 'Oct 26 2023'.
[ 10.435587] Mali:
[ 10.435590] Mali device driver loaded
[ 10.437062] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 10.437072] cfg80211: failed to load regulaBegin: Will now check root file system ... tory.db
[ 10.441870] ret 1024 0
[ 10fsck from. util-l4in4ux 2.36.1-4309-1irty
983] ALSA device list:
[ 10.441991] #0: rockchip-hdmi0
[ 10.445250] Freeing unused kernel memory: 7744K
[ 10.479[/sbin/fsck.ext4 (1) -- /4dev/mmcblk0p6] fsck.ext4 -a -C0 /dev/mmcblk0p6
/dev/mmcblk0p6: clean, 79406/196608 files, 643534/786432 blocks
15] Rundone.
/init as init process
[ 10.779095] rk-pcie fe170000.pcie: PCIe Lindone.
k Fail
[ 10.779107] rk-pcie fe17000Begin: Running /scripts/local-bottom ... 0.pcie: failed to initialize host
[ 10.779116] rk-pcie fe190000.pcie: PCIe Link Fail
[ 10.779126] rk-pcie fe190000.pdone.
ciBegin: Running e/script:s/init-bottom ... failed to initialize host
[ 12.238178] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts='dev=PARTLABEL=userdata,fstype=ext4,mkfs=1' per kernel cmdline
a0m] Finished Load Kernel Modules.: 4 orphan inodes deleted
ry Execu[ OK ] Finished Remount Roott and Kernael File Systems.
ble File Formats File S Mounting FUSE Control File System...yata mode. Opts: (null)
stem Automount Mounting Kernel Configuration File System...erdata,fstype=ext4,mkfs=1' using overlay per kernel cmdline
Point being skipped.d, no /lib/modules/5.10.110 in initramfs.
[ 13.439130] systemd Star[ting Platform Persi1stent Storage Archivalm...
: Reached targe Starting Load/Save Random Seedser 0ma...
nd Group Name Look Starting Applyu Kernel Variables..p.ered data mode. Opts: (null)
s. 12.729583] ext4 filesystem being mounted at /root/boot supports timestamps until 2038 (0x7fffffff)
[ 13.445727] sy Starting mCreate System Users...
temd[1]: Reached[0;32m OK 0m] Satarted Jourrnal Service.ng in system mode. (+PAM +AUDIT +SELINUX +IMA +AP
get Remote File Systems..6 LTS!
[ OK ] M[ounted FUSE Control File System.
1[ OK ] Mounted Kernel Configuration File System.GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
.451785] s[ OK ] Finished Platform Persistent Storage Archival.
ystemd[1][ OK ] Finished Load/Save Random Seed.0>.
: Reached[ OK ] Finished Apply Kernel Variables./systemd/system/vai.service is marked executable. Please remove executable permission bits. Proceeding anyway.
target Sl[ OK ] Finished Create System Users.tc/systemd/system/5G_server_njhy.service is marked executable. Please remove executable permission bits. Proceeding anyway.
ices.3.342820] systemd[1]: Configuration file /etc/systemd/system/5G_server_njhy.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.456757] Startsing Flush Journal to Persisystent Storage...
temd[1]: Reache Starting Crdeate Stattic Device Nodes in /dev..arge.
t Swap.] Created slice system-serial\x2dgetty.slice.
[ 13.461712] systemd[1]: Listening on Syslog Socket.
[ 13.466941] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.474167] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Finished 1;39mCreate Static Device Nodes in /dev.v/log).
13.48[[0;32m OK ] Reached target L4cal File Systems (Pre).
[ OK ] Reached target Local File Systems.
07] systemd[1]: Listen Startining Set consgole font and keymap...
Starting Tell PlymoutCompatibility Named Pipe.
[ OK ] Listening on Journal h To Write Out Runtime Data...
[ 13.491886] systemd[1 Starting 39mu:dev Kernel DeLvicei Manager[0m...
tening on udev Control Socket.Socket.
[ 13.497702] systemd[1]: Listening on udev Kernel Socket.
[ 13.505009] systemd[1]: Mounting Huge Pages File System...
[ 13.509696] systemd[1]: Mou[ OK ] Finished udev noldplugt all Devicesin.
g POSIX Message[ OK ] Finished Set console font and keymap.
Queue File System...nel Debug File System...
[ 13.515601 Starting Helper] to synchronize boot up for ifupdown s...
ystemd[1]: M[ OK ] Finished Tell Plymoouth To Write Ouut Runtnime Data.
ting Kernel Debug File System...rmting dSet the[console1 keyboard layout...
[ 13.520688] systemd[1]: Mounting Kernel Trace File System...r the current kernel...
[ 13.526513] system[ OK ] Finished Flush Journal to Persistent Storage...
d[1]: Starting Journ Startiang Create Volatile Files and Directories...
l Service...4] Starting Load Kernel Module pstore_ blk...
m...13.530823] systemd[1]: Starting Set the console keyboard layou0m.. .
vice: Succeeded.tatic device nodes for the current kern[ OK ] Started Save inietial kernel messagels after boot.
[ 13.644138] S tasrting LSyB: Agent daemon fsor Spice tguesets...
md[1]: Finished Load Kernel Module pstore_b Starting ;39mLogin Service...tadata Check Snapshots...
k.os_pstore.service: Succeeded. ] Finishe d Create Volatile Files and Directories.
[ 13.650792] systemd[1]: modprobe@pstore_zone.service: Succeeded.anagner0m...
[ 13.651208] s[ OK ] Startedy ;1;39mSwitch uart modes.ernor.n ization...
temd[1]: Finished Load K Starting Disk Manager... /etc/reso… the ppp link was shut down...
ernel Module pstore_zone.A engine... Starrting Update UTMP aboutt Systeming L Boot/Shutdown...
Starting WPA supplicant...eystem Logging Service
n 13.658729] systemd[1]: Finished Load Kernel Modules.nsole Directory Watch .
[ 13.66[ OK ] Started LSB: GNOME Display Manager.s for the current kernel.
5209] systemd[1]: F[ OK ] Finished 0;1;39mRestore /etc/reso…re the ppp link was shut down.
nish[ ] Finished stemd[1]: Starting Load Kernel Module pstore_zone...[
ck rem OdK ] Start ed System RLoggeing Service.mount n.e_zone.
Roo[ OK ] Sttarte d rkisp 3A engine.eck resulted in Load Kernel Module ramoops being skipped.
and Kernel File Systems.]: Condition check resulted i[ OK ] Starnted Network Tim e Synchronization
[[ OK ] Started enable ASYNC f or Debian Display. m.
13.674179] systemd[1]: Mounting FUSE Control File System...lization.
[ 13.680851] systemd[1]: Mounting Kernel Configuration File System...
[ 13.688965] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 13.690758] systemd[1]: Starting Platform Persistent Storage Archival...
[ 13.698355] systemd[1]:[ OK ] Finished Remove Stale SOnli…ext4 Metadata Check Snapshots.t
[ OK ] Reached target Paths. arting Load/Save Random Seed...
[ 13.705474] systemd[1]: Starting Apply Kernel Vari[ OK ] Started b;39mAvahi mDNS/DNS-SD Stack.
les... ] Reached targ5et System Time 7Synchronized.
[ 13.71[ OK ] Started LSB: Agent daemon for Spice gu2ests.ur.
373] systemd[ OK ] Started 39mLog1in Service.es.
]: Starting Create[ OK S ] Styartesd 0;1;39mLSeB: automatim Userc crash report generation.s...
[ 13.71873 Started Periodic ext4 Onli…ata Check for All Filesystems.
1] systemd[1]: Started Journal Service.card unused blocks once a week.
[ OK ] Started WPA supplicant.
[ OK ] Found device /dev/ttyFIQ0.
Starting Save/Restore Sound Card State...
[ OK ] Found device /sys/subsystem/net/devices/eth1.
[ OK ] Started ifup for eth1. mDNS/DNS-SD Stack Activation Socket.
Starting Authorization Manager...
[ OK ] Started Authorization Manager.ssage Bus Socket.
[ OK ] Started Accounts Service.ting Docker Socket for the API.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Load/Save RF Kill Switch Status....
Starting Hostname Service...mHost and Network Name eLookups.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Finished Helper to synchronize boot up for ifupdown.
Starting Raise network interfaces...
[ OK ] Started Disk Manager.
[ OK ] Started Hostname Service.Accounts Service...
Starting Network Manager Script Dispatcher Service...
[ OK ] Found device /sys/subsystem/net/devices/eth1.1.
[ OK ] Started ifup for eth1.1. Run anacron jobs.
[ OK ] Started Network Manager Script Dispatcher Service.ic crash re port generation...
[ OK ] Started Network Manager.
[ OK ] Found device /sys/subsystem/net/devices/eth1.2.lay...
[ OK ] Started ifup for eth1.2. SIarting Avahi mDNS/DNS-SD Stack...
[ OK ] Found device /sys/subsystem/net/devices/eth1.3.
[ OK ] Started ifup for eth1.3.d Kernel Debug Fil[ OK m] S tartSed Regular backgrounyd prsogram processing daemon.
[ OK ] Finished Raise network interfaces.
[ OK ] Reached target Network.ed Kern[;32m OlK ] Sta rted D-BusT Sysrtem Message Buas.
[ OK ] Reached target Network is Online.
Starting containerd container runtime...le keyboard layout.
Starting Net-Smp-Affinity... Starting Network Manager
Starting OpenVPN service...
Starting /etc/rc.local Compatibility...
Starting OpenBSD Secure Shell server...
[ 9.445830] rc.local[1516]: run rc.local
Starting Permit User Sessions...
[ 9.453925] rc.local[1519]: Adding user hyst to group docker
Starting Ubuntu FAN network setup...
[ OK ] Started Net-Smp-Affinity.
[ OK ] Finished OpenVPN service.
[ OK ] Finished Permit User Sessions.
[ OK ] Finished Ubuntu FAN network setup.
[FAILED] Failed to start Adbd for linux.
See 'systemctl status adbd.service' for details.
[ OK ] Started Setup rockchip platform environment.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Started containerd container runtime.
Starting Docker Application Container Engine...
[ 12.294739] rc.local[2058]: RS485-1 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-1 -> /dev/ttyCH9344USB0
[ 12.301701] rc.local[2058]: RS485-2 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-2 -> /dev/ttyCH9344USB1
[ 12.313784] rc.local[2058]: RS485-3 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-3 -> /dev/ttyCH9344USB2
[ 12.325666] rc.local[2058]: RS485-4 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-4 -> /dev/ttyCH9344USB3
[ OK ] Started /etc/rc.local Compatibility.
[ 12.337254] rc.local[2058]: /dev/ttyCH9344USB8 is not exist !
[ 12.349307] rc.local[2058]: /dev/ttyCH9344USB9 is not exist !
[ OK ] Started 4G2 Server.
[ 12.354994] rc.local[2058]: /dev/ttyCH9344USB10 is not exist !
[ OK ] Started 4G1 Server.
[ 12.365591] rc.local[2058]: /dev/ttyCH9344USB11 is not exist !
[ OK ] Started 5G Server.
[ 12.376064] rc.local[2058]: LORA alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/LORA -> /dev/ttyS0
Starting Hold until boot process finishes up...
[ 12.391226] rc.local[2058]: BLE alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/BLE -> /dev/ttyS1
Starting Terminate Plymouth Boot Screen...
[ 12.407893] rc.local[2058]: EC-BLE alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/EC-BLE -> /dev/ttyS5
[ OK ] Finished Hold until boot process finishes up.
[ 12.424611] rc.local[2058]: Create uart interface end.
[ OK ] Finished Terminate Plymouth Boot Screen.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme...
[ OK ] Finished Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Docker Application Container Engine.
[ OK ] Started connection-control-hyst service.
[ OK ] Started console-display-hyst service.
[ OK ] Started rule-engine service.
[ OK ] Started video ai service.
Starting video ai service...
[ 19.256120] of_dma_request_slave_channel: dma-names property of node '/serial@fd890000' missing or empty
[ 19.265432] of_dma_request_slave_channel: dma-names property of node '/serial@feb40000' missing or empty
[ OK ] Stopped connection-control-hyst service.
[ OK ] Stopped console-display-hyst service.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
Ubuntu 20.04.6 LTS HYG330 ttyFIQ0
HYG330 login: [ OK ] Finished Update UTMP about System Runlevel Changes.
[ 198.430293] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:6 count 1 cur_task 00000000f9c88f15 id 24638
[ 198.431812] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:10 count 3 cur_task 000000008b7fb047 id 24636
[ 198.431901] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:2 count 3 cur_task 000000003328425d id 24635
[ 198.432932] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:9 count 2 cur_task 000000009e35de57 id 24641
[ 243.280315] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 243.280360] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 243.280474] rkvdec2_soft_ccu_reset:1747: soft reset fail, int 00000020
[ 243.280489] rkvdec2_soft_ccu_reset:1753: bus busy
[ 243.787077] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 243.787123] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 243.787252] rkvdec2_soft_ccu_reset:1747: soft reset fail, int 00000020
[ 243.787259] rkvdec2_soft_ccu_reset:1753: bus busy
[ 273.002923] rga_job: reset core[1] by request abort
[ 273.003168] rga_job: core[0x1] running job has been cleanup.
[ 273.003196] rga: isr thread invalid job!
[ 273.003222] rga_job: request[3898] abort! finished 0 failed 0 running_abort 1 todo_abort 0
[ 279.837949] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:10 count 3 cur_task 000000006195ae49 id 39635
[ 279.838022] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:2 count 2 cur_task 00000000f0cbf15f id 39634
[ 279.838079] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:6 count 2 cur_task 000000006015c538 id 39639
[ 279.838687] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:9 count 3 cur_task 0000000090bde85f id 39637
[ 279.840051] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:11 count 1 cur_task 0000000087d99aa2 id 39633
[ 436.374311] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:9 count 3 cur_task 00000000649de07f id 61560
[ 436.374413] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:1 count 1 cur_task 000000000785432d id 61559
[ 436.374463] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:3 count 1 cur_task 00000000b098a93a id 61563
[ 436.374612] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:5 count 2 cur_task 00000000fa8d3d68 id 61564
[ 436.375505] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2682 session 2682:11 count 1 cur_task 00000000c57cb194 id 61562
[ 488.561883] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 488.562027] rkvdec2_soft_ccu_reset:1747: soft reset fail, int 00000020
[ 488.562036] rkvdec2_soft_ccu_reset:1753: bus busy
[ 585.542873] rkvdec2_ccu_link_timeout_work:1566: task timeout
PANIC at PC : 0x00000000000602a8DDR V1.09 a930779e06 typ 22/11/21-17:50:56 ---------------重启卡死
更多回帖
