发送端代码:
int main(void)
int data[12]={0};
RIE_Responses RIE_Response = RIE_Success;
WdtGo(T3CON_ENABLE_DIS);
//uart-----start
Urt_Init(UART_BAUD_19200);
Urt_PinSetup(FALSE);
printf("**************************rn");
printf("rn TX发送端初始化完成 rn");
//uart-----end
// Ini
tialise the Radio
if (RIE_Response == RIE_Success)
RIE_Response = RadioInit(DR_38_4kbps_Dev19_2kpbs);
// Set the Frequency to operate at 915 MHz
RIE_Response = RadioSetFrequency(915000000);
// Set the PA and Power Level
RIE_Response = RadioTxSetPA(DifferentialPA,PowerLevel15);
RIE_Response = RadioTxPacketFixedLen(12, "HELLO WORLD");
printf("n输入要发送的数据:");
while (1)
Delay1();
RadioTxPacketFixedLen(12, "hello 123456");
接收端代码:
int main(void)
unsigned char Buffer[0x20];
RIE_U8 PktLen;
RIE_S8 RSSI;
RIE_U8 flag=0;
//---------------UART code start---------------------
printf("rn**************************rn");
printf("rn RX接收端初始化完成!nr");
//-----------------UART code end---------------------
// Initialise the Radio
RIE_Response = RadioRxPacketFixedLen(12);
printf("nr正在接收数据nr");
while (!RadioRxPacketAvailable());
RIE_Response = RadioRxPacketRead(sizeof(Buffer),
PktLen,
Buffer,
RSSI);
printf("nr-> %s @ RSSI %d",Buffer,(int)RSSI);
else
printf("nr-> ERROR");
while(1)
//-------------接收数据----------------
PktLen,
Buffer,
RSSI);
printf("nr收到的数据:%s RSSI:%d",Buffer,(int)RSSI);
发送端和接收端的代码如上所附,通信时通信距离只有十几厘米,是不是有需要
注意的地方我没有注意到,期待解答。
