单片机/MCU论坛
直播中
李晓鹏
7年用户 1200经验值
私信 关注
[问答]
adsp21479仿真不能单步运行怎么解决?
我在一个项目中使用了ADSP-21479 100pin 管教的芯片,在参照手册做了一个板子,现在也没找到关于这个的一些软硬件资料!软件写了个测试的!但每次下载后就自动运行了!也跳不到main 处!并且下载后看不到 setp over F10 !想请问一下!有无参考的例程 !和硬件资料!
      以下是我的测试代码!软件环境VDSP5.1 ! 想请专家们帮我看看,是什么问题! 谢谢!
debugNWC   其他选项是默认的!
硬件 boot cfg 是spi  flash !  clk _cfg 8:1
* 21479 TEST.c
#include
#include
#include
#include "cs4272.h"
#define NOP asm volatile("nop;")
void initPLL_SDRAM(void);
void  main()
  /* Begin adding your custom code here */
initPLL_SDRAM();
   //Init_PLL_SDRAM_AMI();
  // printf("hello wordn");
InitCS4272();
for (;;)
     asm("nop;");
     //asm("idle;");
void initPLL_SDRAM(){
  int i, pmctlsetting;
  // Set INDIV bit in PMCTL register
pmctlsetting = *pPMCTL;
pmctlsetting |= INDIV;
*pPMCTL= pmctlsetting;
  // Program PLL multiplier to same value as CLK_CFGx pins/previously programmed value in software厖
*pPMCTL = pmctlsetting;
  // then place PLL in bypass mode
pmctlsetting |= PLLBP;
     //Wait for recommended number of cycles
    for (i=0; i<4096; i++)
          NOP;
  // Bring PLL out of bypass mode by clearing PLLBP bit
    *pPMCTL ^= PLLBP;
  for (i=0; i<16; i++)
          NOP;
// Clear the previous PLL multiplier
pmctlsetting  = ~PLLM63;
// Clear the INDIV bit
pmctlsetting  = ~INDIV;
// or set the INDIV bit
// *pMCTL |= INDIV;
// CLKIN = 16.625 MHz, PLLM=32, PLLD = 1, INDIV= 1 => fINPUT = 16.625/2 = 8.3125 MHz
// CCLK = 2*PLLM*fINPUT/2*PLLD = (2*32*8.3125)/(2*1) = 266 MHz, SDCLK = CCLK/2 = 133 MHz
// VCO frequency = 2*fINPUT*PLLM = 2*8.3125*32 = 532 <= fVCOmax (532 MHz)
// CLKIN = 12 MHz, PLLM=32, PLLD = 1, INDIV= 1 => fINPUT = 12/2 = 6 MHz
// CCLK = 2*PLLM*fINPUT/2*PLLD = (2*32*6)/(2*1) = 192MHz, SDCLK = CCLK/2 = 133 MHz
// VCO frequency = 2*fINPUT*PLLM = 2*6*32 = 384<= fVCOmax (532 MHz)
    pmctlsetting= SDCKR2|PLLM16|INDIV|DIVEN;
     pmctlsetting|= PLLBP; //Setting the Bypass bit
    pmctlsetting^= DIVEN; //Clearing the DIVEN bit
    *pPMCTL= pmctlsetting; // Putting the PLL into bypass mode
     //Wait for around 4096 cycles for the pll to lock.
    for (i=0; i<5000; i++)
          NOP;
pmctlsetting ^= PLLBP;          //Clear Bypass Mode
     //Wait for around 15 cycles for the output dividers to stabilize.
          NOP;
#include
#include
#include "cs4272.h"
#ifdef CS4272
#define SPIB_MODE (CPHASE | CLKPL)
#define CS4272_CS DS0EN
//#define AD1939_CS DS1EN
#define SELECT_SPI_SLAVE(select) (*pSPIFLG  = ~(spiselect<<8))
#define DESELECT_SPI_SLAVE(select) (*pSPIFLG |= (spiselect<<8))
// NOTE: To select ADC/DAC Sample Rate of either 48 kHz, 96 kHz or 192 kHz, choose one
//       of the following 3 macros to set the sample rate (only one at a time).
#define USE_48_KHZ_SAMPLE_RATE
//#define USE_96_KHZ_SAMPLE_RATE
//#define USE_192_KHZ_SAMPLE_RATE
/* Setup the SPI parameters here in a buffer first */
unsigned char ConfigParamCS4272[] = {
            (CS4272_ADDR), MODE_CONTROL_2, MODE_CONTROL_2_PDN | MODE_CONTROL_2_CPEN,
            (CS4272_ADDR), MODE_CONTROL_1, MODE_CONTROL_ONE_DEFAULT_PAYLOAD,
            (CS4272_ADDR), DAC_CONTROL, DAC_CONTROL_DEFAULT_PAYLOAD,
   (CS4272_ADDR), DAC_VOLUME, DAC_VOLUME_DEFAULT_PAYLOAD,
   (CS4272_ADDR), DAC_VOLUME_A, 0x00,
   (CS4272_ADDR), DAC_VOLUME_B, 0x00,
   (CS4272_ADDR), ADC_CONTROL, ADC_CONTROL_DITHER16,
   (CS4272_ADDR), MODE_CONTROL_2, MODE_CONTROL_2_CPEN,
unsigned char CS4272_Regs_Read[sizeof(ConfigParamCS4272) / 3];
volatile int spiFlag ;
int LockCount = 0;
unsigned int LockTest;
void Delay(int i);
// Set up the SPI port to access the ADCS4272
// Call with SPI flag to use
void SetupSPICS4272(unsigned int SPI_Flag)
    // Configure the SPI Control registers // First clear a few registers
*pSPICTL = (TXFLSH | RXFLSH) ;
    *pSPIFLG = 0;
    // Setup the baud rate to 1MHz *pSPIBAUD = 100;
    *pSPIBAUD = 25;
    // Setup the SPI Flag register using the Flag specified in the call
    *pSPIFLG = (0xF00|SPI_Flag);
    // Now setup the SPI Control register
    *pSPICTL = (SPIEN | SPIMS | WL8 | MSBF | TIMOD1 | CPHASE | CLKPL | SMLS|GM);
// Disable the SPI Port
void DisableSPICS4272(void)
    *pSPICTL = (TXFLSH | RXFLSH);
// Send a word to the CS4272 via SPI Call with the CS4272 address, register address, register data, and SPI flag to use
void ConfigureCS4272Register (unsigned char rwaddr,unsigned char regaddr,unsigned char regdata, unsigned int spiselect)
    int i,j;
    unsigned char val[3];
     SELECT_SPI_SLAVE(spiselect);
     val[0]=WR(rwaddr);
    val[1]=regaddr;
    val[2]=regdata;
    for(i=0;i<3;i++)
        j=0;
        *pTXSPI = val[i] ;
       // Delay(136);
        //Wait for the SPI to indicate that it has finished.
        while ((*pSPISTAT   TXS))
        {j++;}
     j=0;
    while (!(*pSPISTAT   SPIFE))
    {j++;}
    Delay(10);
     DESELECT_SPI_SLAVE(spiselect);
// Receive a register setting from the ADCS4272
// Call with the register address, and SPI flag to use; returns register data
unsigned char GetCS4272Register (unsigned char regaddr, unsigned int spiselect)
    int i,j;
    unsigned int tmp;
     val[0]=RD(CS4272_ADDR );
    val[1]=regaddr;
    val[2]=0;
    for(i=0;i<3;i++)
        j=0;
        *pTXSPI = val[i] ;
        {j++;}
     j=0;
     while (!(*pSPISTAT   SPIF))
    {j++;}
    {j++;}
    Delay(10);
    tmp = *pRXSPI;
    return tmp;
// Set up all ADCS4272 registers via SPI
void InitCS4272(void)
  int configSize = sizeof(ConfigParamCS4272);
    int i,j=0 ;
    unsigned char tmpA[sizeof(ConfigParamCS4272) / 3];
     //Set up ADCS4272
    SetupSPICS4272(CS4272_CS);
     //Write register settings
    for(i = 0; i < configSize-6; i+=3)
        ConfigureCS4272Register(ConfigParamCS4272[i], ConfigParamCS4272[i+1], ConfigParamCS4272[i+2], CS4272_CS);
        Delay(272);
        //Read back register settings for debugging
        CS4272_Regs_Read[j++] = GetCS4272Register(ConfigParamCS4272[i+1], CS4272_CS);
        Delay(272);
    // Make sure the PLL is locked before enabling the CODEC.
    for(i = configSize-6; i < configSize; i+=3)
        Delay(272);
        Delay(272);
      DisableSPICS4272();
#if 0
void enableADCHpf(bool enable)
   unsigned char dither16State;
    if (bridgeADCGainFactor == 0) // if we are going to use bits lower than the 16 MSB, we cannot dither to 16 bits
        dither16State = ADC_CONTROL_DITHER16;
    else
        dither16State = 0;
  if (enable)
    ConfigureCS4272Register(CS4272_ADDR, ADC_CONTROL, dither16State, CS4272_CS);
    else
ConfigureCS4272Register(CS4272_ADDR,ADC_CONTROL, ADC_CONTROL_HPF_DISABLE_B | ADC_CONTROL_HPF_DISABLE_A | dither16State, CS4272_CS);
#endif
//Delay loop
void Delay(int i)
    for(i ; i > 0; --i)
        asm("nop;");
#endif
回帖(1)
刘丹
2024-1-15 13:50:03
从您的描述来看,有以下一些可能的解决方案:
1. 检查硬件连接和配置:确保您的硬件连接正确,并且与芯片的引脚分配和配置一致。确保使用正确的时钟和复位源。
2. 检查软件设置:确认您的软件项目正确地设置为使用ADSP-21479芯片,并且与硬件配置一致。您可能需要检查芯片的设备描述文件和仿真器驱动程序。
3. 检查下载和调试设置:确保您的下载和调试设置正确。这可能包括设置调试模式、调试器驱动程序和目标设备的连接方式。
4. 检查编译设置:确认您的代码正确编译,并且生成的可执行文件正确映射到目标硬件的内存地址空间。
5. 检查调试命令和快捷键:确认您正在使用正确的调试命令和快捷键。您可能需要查看相关的文档或手册,以了解如何设置断点和单步调试。
举报
更多回帖
