接上文[【飞腾派4G版免费试用】2飞腾派 openkylin 进行IO控制-灯闪(https://bbs.elecfans.com/jishu_2405776_1_1.html)
红绿灯项目
GPIO1_12 归属于 gpiochip1,gpiochip1 对应的编号从 480 到 495,GPIO1_12 偏移 12,所以对应的编号为 480+12=492。绿
GPIO1_11 归属于 gpiochip1,gpiochip1 对应的编号从 480 到 495,GPIO1_11 偏移 11,所以对应的编号为 480+11=491。黄
GPIO3_1 的编号为 448+1=449。红
接ssh
编辑新脚本rgb.sh
#!/bin/sh
LEDr_GPIO=/sys/class/gpio/gpio449
LEDg_GPIO=/sys/class/gpio/gpio492
LEDy_GPIO=/sys/class/gpio/gpio491
if test -d $LEDr_GPIO; then
echo "GPIO449 already exported"
else
echo 449 > /sys/class/gpio/export
fi
if test -d $LEDg_GPIO; then
echo "GPIO492 already exported"
else
echo 492 > /sys/class/gpio/export
fi
if test -d $LEDy_GPIO; then
echo "GPIO491 already exported"
else
echo 491 > /sys/class/gpio/export
fi
echo out > $LEDr_GPIO/direction
echo out > $LEDg_GPIO/direction
echo out > $LEDy_GPIO/direction
while true; do
echo 0 > $LEDr_GPIO/value
echo 0 > $LEDg_GPIO/value
echo 0 > $LEDy_GPIO/value
echo 1 > $LEDr_GPIO/value
sleep 5
echo 1 > $LEDg_GPIO/value
sleep 5
echo 1 > $LEDy_GPIO/value
sleep 0.5
sleep 0.5
sleep 0.5
done
文件加X执行权
openkylin@openkylin:~$ cd /sys
openkylin@openkylin:/sys$ ls
block bus class dev devices firmware fs kernel kylin_authentication kylin_kmod module power
openkylin@openkylin:/sys$ cd class
openkylin@openkylin:/sys/class$ dir
ata_device devfreq gpio iommu nvme pps sas_device scsi_host udc
ata_link devfreq-event graphics lcd nvme-fabrics ptp sas_end_device sound uio
ata_port dma hwmon leds nvme-subsystem pwm sas_expander spi_master usb_role
backlight drm i2c-adapter mdio_bus pci_bus rapidio_port sas_host tcmdev vc
bdi drm_dp_aux_dev i2c-dev mem pci_epc regulator sas_phy tee virtio-ports
block extcon ieee80211 misc phy remoteproc sas_port thermal vtconsole
bluetooth fc infiniband mmc_host pktcdvd rfkill scsi_device tpm wakeup
bsg fcloop infiniband_cm mtd powercap rpmsg scsi_disk tpmrm watchdog
devcoredump firmware input net power_supply rtc scsi_generic tty
openkylin@openkylin:/sys/class$ cd gpio
openkylin@openkylin:/sys/class/gpio$ didr
-bash: didr:未找到命令
openkylin@openkylin:/sys/class/gpio$ ls
export gpiochip416 gpiochip432 gpiochip448 gpiochip464 gpiochip480 gpiochip496 unexport
Last login: Fri Aug 25 14:38:38 2023 from 192.168.2.201
openkylin@openkylin:~$ sudo ./rgb.sh
灯正常闪
达到预期。脚本rgb.sh编程相当简洁方便。红绿灯项目完成。
更多回帖
