下载官网上adc中断程序到
开发板,但dac并没有相应的输出。
程序如下:
Author : ADI - Apps
Date : Sept. 2005
File : Mul
tint.c
Hardware : Applicable to ADuC702x rev H or I silicon
Currently targetting ADuC7026.
Description : Example program using two IRQs and 1 FIQ.
Timer1 causes an IRQ which compliments P4.2.
XIRQ0 causes an IRQ which compliments P4.2.
ADC causes an FIQ which outputs the value on ADC0
to DAC1.
#include // Include ADuC7026 Header File
// Function Prototypes
void My_IRQ_Function(void); // IRQ Function Prototype
void My_FIQ_Function(void); // FIQ Function Prototype
void ADCpoweron(int);
void delay(int);
void DemoConfig(void);
long ADCconvert(void);
int main (void) {
DemoConfig(); // set up ADC, DAC, reference
IRQ = My_IRQ_Function; // Specify Interrupt Service Rountine
FIQ = My_FIQ_Function; // Specify Interrupt Service Rountine
GP0CON = 0x00100000; // Enable ADCbusy on Pin 0.5
GP4DAT = 0x04000000; // Configure P4.2 as output
GP3DAT = 0xff000000; // Configure port 3 as output
// Timer 1 configuration
T1LD = 0x20000; // Counter Value
T1CON = 0xC4; // Enabled,Periodic,Binary and CLK/16
IRQEN = XIRQ0_BIT+GP_TIMER_BIT; // Enable XIRQ0 and Timer1 IRQ
FIQEN = ADC_BIT; // Enable ADC FIQ
while(1) {
GP3DAT ^= 0x00ff0000; // Compliment P3
ADCCON = 0x6E3; // single conversion
delay(0x2000); // Delay Blinking of P3
return 0 ;
void delay (int length) {
while (length >=0)
length--;
void DemoConfig(void) { // ADC, DAC and Reference configuration
ADCpoweron(20000); // power on ADC
ADCCP = 0x00; // conversion on ADC0
DAC1CON = 0x13; // AGND-AVDD range
REFCON = 0x01; // internal 2.5V reference
return;
void ADCpoweron(int time) {
ADCCON = 0x20; // power-on the ADC
while (time >=0) // wait for ADC to be fully powered on
time--;
/* Interrupt Service Rountine */
void My_IRQ_Function() { // example with two IRQ
if ((IRQSTA GP_TIMER_BIT) != 0) { // Timer1 IRQ?
T1CLRI = 0; // Clear Timer IRQ
GP4DAT ^= 0x00040000; // Complement P4.2
if ((IRQSTA XIRQ0_BIT) != 0) { // external IRQ?
while(GP0DAT 0x00010){} // wait for XIRQ to be low again
return ;
void My_FIQ_Function() { // example with one FIQ
if ((FIQSTA ADC_BIT) != 0) // ADC FIQ ?
DAC1DAT = ADCDAT; // Output ADC0 Value onto DAC1
return ;
