/* Compute IFFT( CFFT( X ) ) = X */
#include
#define N_FFT 64
complex_fract16 in[N_FFT];
complex_fract16 out_cfft[N_FFT];
complex_fract16 out_ifft[N_FFT];
complex_fract16 twiddle[N_FFT/2];
int blk_exp;
void ifft_fr16_example(void)
int i;
/* Generate DC signal */
for( i = 0; i < N_FFT; i++ )
in[i].re = 0x100;
in[i].im = 0x0;
/* Populate twiddle table */
twidfftrad2_fr16(twiddle, N_FFT);
/* Compute Fast Fourier Transform */
cfft_fr16(in, out_cfft, twiddle, 1, N_FFT, blk_exp, 0);
/* Reverse sta
tic scaling applied by cfft_fr16() function
Apply the shift operation before the call to the
ifft_fr16() function only if all the values in out_cfft
= 0x100. Otherwise, perform the shift operation after the
ifft_fr16() function has been computed.
out_cfft[i].re = out_cfft[i].re << 6; /* log2(N_FFT) = 6 */
out_cfft[i].im = out_cfft[i].im << 6;
/* Compute Inverse Fast Fourier Transform
The output signal from the ifft function will be the same
as the DC signal of magnitude 0x100 which was passed into
the cfft function.
ifft_fr16(out_cfft, out_ifft, twiddle, 1, N_FFT, blk_exp, 0);
为什么fft函数在 bf592中运行 out_ifft 数据和in数据有区别??? 傅里叶变换和逆变换的 结果有差距呢
