model_deploy.py --mlir yolov5l.mlir --quan
tize INT8 --calibration_table yolov5l_cali_table --chip bm1684 --tolerance 0.85,0.45 --model yolov5l_bm1684_int8.bmodel
SOPHGO Toolchain v1.2.8-g32d7b3ec-20230802
2023/11/29 15:34:12 - INFO :
load_config Preprocess args :
resize_dims : [512, 512]
keep_aspect_ratio : True
keep_ratio_mode : letterbox
pad_value : 0
pad_type : center
input_dims : [512, 512]
mean : [0.0, 0.0, 0.0]
scale : [0.0039216, 0.0039216, 0.0039216]
pixel_format : rgb
channel_format : nchw
SourceURL:file:///home/jayen/下载/se5使用测试.docx
===group_idx: 13move tensor onnx::Pow_649_Mul from timestep 1 to timestep 6merge timestep 7 to timestep 6
merge timestep 8 to timestep 7
merge timestep 9 to timestep 8
merge timestep 10 to timestep 9
merge timestep 11 to timestep 10
===group idx: 48
merge timestep 1 to timestep 0
Run GroupDataMoveOverlapPass :
Overlap data move between two layer group
GmemAllocator use FitFirstAssign
[Success]: tpuc-opt yolov5l_bm1684_int8_sym_tpu.mlir --mlir-disable-threading --strip-io-quant="quant_input=False quant_output=False" --chip-tpu-optimize --weight-reorder --subnet-divide="dynamic=False" --op-reorder --layer-group="opt=2" --address-assign -o yolov5l_bm1684_int8_sym_final.mlir
[Running]: tpuc-opt yolov5l_bm1684_int8_sym_final.mlir --codegen="model_file=yolov5l_1684_int8.bmodel" -o /dev/null
bmcpu init: skip cpu_user_defined
Cannot open libusercpu.so, disable user cpu layer.
in cmodel, enable profile.
FW INFO: D4 without w stride case
FW INFO: n_slice 1, h_slice 24
FW INFO: n_slice 1, h_slice 64
ASSERT_FS /workspace/Sophgo/Codes/nntoolchain/TPU1684/firmware_core/src/atomic/atomic_tensor_arithmetic_fix8b_gen_cmd.c: atomic_tensor_arithmetic_fix8b_gen_cmd_: 140: tensor_dim[3] > 0
ASSERT info: none.
Obtained 10 stack frames.
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(print_trace+0x19) [0x7f2e6bb5e417]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(+0xc9740) [0x7f2e6b94c740]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(atomic_tensor_arithmetic_fix8b_gen_cmd_ext+0xad) [0x7f2e6b94d118]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(atomic_tensor_arithmetic_fix8b_gen_cmd+0xc8) [0x7f2e6b94d53d]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(+0x24c2f2) [0x7f2e6bacf2f2]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(general_binary_fix8b_local+0x414) [0x7f2e6bad0afa]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(+0x24f3ee) [0x7f2e6bad23ee]
/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684.so(nodechip_broadcast_binary_fix8b_forward_local+0x570) [0x7f2e6bad2c81]
tpuc-opt(+0x498648) [0x556568685648]
tpuc-opt(+0x411079) [0x5565685fe079]
Traceback (most recent call last):
File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/tools/model_deploy.py", line 288, in
tool.build_model()
File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/tools/model_deploy.py", line 202, in build_model
self.op_divide
File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/utils/mlir_shell.py", line 154, in mlir_to_model
_os_system(cmd)
File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/utils/mlir_shell.py", line 50, in _os_system
raise RuntimeError("[!Error]: {}".format(cmd_str))
RuntimeError: [!Error]: tpuc-opt yolov5l_bm1684_int8_sym_final.mlir --codegen="model_file=yolov5l_1684_int8.bmodel" -o /dev/null
