电路设计论坛
直播中
李晨灵
8年用户 1530经验值
私信 关注
[问答]
AD7150 + MSP430G2553如何编码?
想做一个简单的 微电容位移传感器  采用AD7150 来获得电容值
AD7150 是I2C传送数据,因为想做的简单,就用MSP430G2553单片机做主控,模拟I2C通信方式,来获取输入
程式语言部分该如何编码?
底下是我参考open source
msp430g2xx3_uscib0_i2c_12.c
进行修改
但不了解各个状态要如何设定 (寄存器位址等)?
请各位大大协助
#include
#include "msp430g2553.h"
#define NUM_BYTES_TX 1                         // How many bytes?
#define NUM_BYTES_RX 1
int RXByteCtr, RPT_Flag = 0;                // enables repeated start when 1
volatile unsigned char RxBuffer[128];       // Allocate 128 byte of RAM
unsigned char *PTxData;                     // Pointer to TX data
unsigned char *PRxData;                     // Pointer to RX data
unsigned char TXByteCtr, RX = 0;
unsigned char MSData = 0x55;
unsigned int RxWord;
unsigned int RxByteCtr;
unsigned char i;
float        pFdata;
float        chRange;
void Setup_TX(void);
void Setup_RX(void);
void Transmit(void);
void Receive(void);
float AD7150_Cap(void);
void main(void)
WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
   P1SEL |= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
   P1SEL2|= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
   while(1){
   //Transmit process
   Setup_TX();
   RPT_Flag = 1;
   Transmit();
   while (UCB0CTL1   UCTXSTP);             // Ensure stop condition got sent
   //Receive process
   Setup_RX();
   Receive();
// The USCI_B0 data ISR is used to move received data from the I2C slave
// to the MSP430 memory. It is structured such that it can be used to receive
// any 2+ number of bytes by pre-loading RXByteCtr with the byte count.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
   if(RX == 1){                              // Master Recieve?
   RXByteCtr--;                              // Decrement RX byte counter
   if (RXByteCtr)
     *PRxData++ = UCB0RXBUF;                 // Move RX data to address PRxData
   else
     if(RPT_Flag == 0)
         UCB0CTL1 |= UCTXSTP;                // No Repeated Start: stop condition
       if(RPT_Flag == 1){                    // if Repeated Start: do nothing
         RPT_Flag = 0;
     *PRxData = UCB0RXBUF;                   // Move final RX data to PRxData
     __bic_SR_register_on_exit(CPUOFF);      // Exit LPM0
   else{                                     // Master Transmit
       if (TXByteCtr)                        // Check TX byte counter
     UCB0TXBUF = MSData++;                   // Load TX buffer
     TXByteCtr--;                            // Decrement TX byte counter
   else
     if(RPT_Flag == 1){
     RPT_Flag = 0;
     PTxData =  MSData;                      // TX array start address
     TXByteCtr = NUM_BYTES_TX;                  // Load TX byte counter
     else{
     UCB0CTL1 |= UCTXSTP;                    // I2C stop condition
     IFG2  = ~UCB0TXIFG;                     // Clear USCI_B0 TX int flag
void Setup_TX(void){
   _DINT();
   RX = 0;
   IE2  = ~UCB0RXIE;
   while (UCB0CTL1   UCTXSTP);               // Ensure stop condition got sent// Disable RX interrupt
   UCB0CTL1 |= UCSWRST;                      // Enable SW reset
   UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
   UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
   UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
   UCB0BR1 = 0;
   UCB0I2CSA = 0x48;                         // Slave Address is 048h
   UCB0CTL1  = ~UCSWRST;                     // Clear SW reset, resume operation
   IE2 |= UCB0TXIE;                          // Enable TX interrupt
void Setup_RX(void){
   _DINT();
   RX = 1;
   IE2  = ~UCB0TXIE;
   UCB0BR1 = 0;
   IE2 |= UCB0RXIE;                          // Enable RX interrupt
void Transmit(void){
     UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
     __bis_SR_register(CPUOFF + GIE);        // Enter LPM0 w/ interrupts
void Receive(void){
     PRxData = (unsigned char *)RxBuffer;    // Start of RX buffer
     RXByteCtr = NUM_BYTES_RX-1;              // Load RX byte counter
     UCB0CTL1 |= UCTXSTT;                    // I2C start condition
if(RxByteCtr < 0x3000)
RxByteCtr = 0x3000;
else if ( RxByteCtr >0XD000)
RxByteCtr = 0XD000;
pFdata =(((RxByteCtr)-0x3000)*1)/0x9FF0;
return pFdata;
更多回帖
