write_add(0x3,0x9);//设置输出格式16bit、422 16位接口 | ||
write_add(0x5,0x6);//选择主模式,HDMI-GR | ||
write_add(0x1D,0x40);//外部的晶振频率=28M,DISABLE TRI_LLC | ||
write_add(0x47,0xA); | ||
write_add1(0x9a,0xff);// | ||
write_add(0x68,0xF0);//ypbpr out | ||
write_add(0x6B,0xF3);//write_add(0x6B,0xE3);//mode6 | ||
write_add(0xBA,0xA0);//Enable HDMI and Analog in | ||
write_add(0x73,0xCD);// | ||
write_add(0x74,0xC4);// | ||
write_add(0x75,0x01);// | ||
write_add(0x76,0x00);// | ||
write_add(0x7B,0x2f);//Outputs progressive timing | ||
write_add(0x81,0xD0);//Enable GR_AV_BL_EN | ||
write_add2(0xF0,0x10); | ||
write_add2(0xF1,0x0F); | ||
write_add2(0xF4,0x20); |
更多回帖
