在使用你们的ADRV9009+ZCU102的开发套件,基于你们制作的Boot.bin(SD卡里面自带的),整个Linux系统可以跑起来,并且IIO软件可以正常使用;然而我自己制作的Boot.bin老是显示错误如下:
root@analog:~# [ 15.459970] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restar
ting link
[ 15.467641] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 1 desynced, restarting link
[ 16.579971] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restarting link
[ 16.587638] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 1 desynced, restarting link
然后IIO软件没有波形出来,显示一条横线。
我的Boot.bin是这样制作的:
1、使用你们SD卡里面的bl31.elf、uboot、自己用sdk2017.4生成了系统比特文件、fsbl.elf、pum.elf一共五个文件。使用sdk的Create Boot Image工具制作,bif文件内容如下:
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
[fsbl_config]a53_x64
[bootloader]F:Workhdl-master2017projectsadrv9009zcu102-blankadrv9009_zcu102.sdkfsblDebugfsbl.elf
[pmufw_image]F:Workhdl-master2017projectsadrv9009zcu102-blankadrv9009_zcu102.sdkpmuDebugpmu.elf
[destination_device = pl]F:Workhdl-master2017build_boot_binsystem_top.bit
[destination_cpu = a53-0, exception_level = el-3, trustzone]F:Workhdl-master2017build_boot_binbl31.elf
[destination_cpu = a53-0, exception_level = el-2]F:Workhdl-master2017build_boot_binu-boot-zcu.elf
最后结果就是这个样子的,
[ 11.584427] ALSA device list:
[ 11.587301] #0: DisplayPort monitor
[ 12.099967] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restarting link
[ 12.107628] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 1 desynced, restarting link
[ 12.144454] EXT4-fs (mmcblk0p2): recovery complete
[ 12.150477] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 12.158510] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 12.171046] devtmpfs: mounted
[ 12.174042] Freeing unused kernel memory: 512K (ffffffc000da0000 - ffffffc000e20000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
[ 13.219994] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restarting link
[ 13.227687] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 1 desynced, restarting link
* Setting up X socket directories... [ OK ]
[ 14.339986] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restarting link
[ 14.347679] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 1 desynced, restarting link
* STARTDISTCC is set to false in /etc/default/distcc
* /usr/bin/distccd not starting
* Starting IIO Daemon iiod [ OK ]
Last login: Sun Oct 7 12:06:55 UTC 2018 on tty1
Welcome to Linaro 14.04 (GNU/Linux 4.9.0-g2398d50 aarch64)
0 packages can be updated.
0 updates are security updates.
New release '16.04.5 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
root@analog:~# [ 15.459970] axi-jesd204-rx 84aa0000.axi-jesd204-rx: Lane 0 desynced, restarting link
请问是什么问题?该怎么解决。
